Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 05-31-2003, 04:03 PM   #1
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
Angry P0420 CEL veterans? Stock exhaust/engine. Perm. fix?
Okay, so I lit up a P0420 code this week.... catalyst threshold exceeded on the rear sensor bank1
BONE STOCK 2.5 RS... I think the only thing I changed was I put some 97 octane gas in instead of her usual 87... ????
I did a search and the only answers were for aftermarket mid-pipe/catalytic guys, nothing about stock problems.,,,, many say it comes on every now and then like its normal, they just reset the ECU and get a few 1000 miles till it pops on again...
or is my catalytic conv. just shot? I did run a week or two w/ a bad front O2 sensor about a month ago before I was able to replace it....
anybody out there stock get rid of a P0420 permanently? Thanks guys!!!
Cujo31 is offline   Reply With Quote
Old 05-31-2003, 09:32 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
how many miles on your car?
the warranty on the cat is 8 years 80,000 miles.
If it keeps comming back sounds like the cat will need to be replaced.
Jay
munkis is offline   Reply With Quote
Old 05-31-2003, 10:55 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Jay
amen brotha!
HndaTch627 is offline   Reply With Quote
Old 06-01-2003, 10:59 AM   #4
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
Thumbs up
I had several problems with this error code. I had a stock exhaust and kept getting this light over the period of a few months. It just came on and off at random regardless of fuel type and driving conditions. My dealer (local at the time in Miami) ordered and replaced the cat. Smelled really bad for a few days, but it disappeared. 19, 000 miles later I have yet to see the light again.
Matt is offline   Reply With Quote
Old 06-01-2003, 11:20 AM   #5
Cujo31
Member#: 19843
2000 2.5 RS Sedan
awesome... music to my ears. I just reset the CU and we'll see if it comes on again soon.
but yeah I'm nowhere near 80,000 miles so
thanks again!
Old 06-01-2003, 07:53 PM   #6
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Default Re: P0420 CEL veterans? Stock exhaust/engine. Perm. fix?
leaded or unleaded...
if your ran leaded race fuel through your car, your cat is most likely toast.
AO
m750 is offline   Reply With Quote
Old 06-01-2003, 10:42 PM   #7
Cujo31
Member#: 19843
2000 2.5 RS Sedan
nearest leaded race gas around here is 50 miles away at GIR. ....
unless Citgo is stocking some firewater for the soccer moms around here now...
heh. like I wouldn't know I dumped in race gas jk
Old 06-02-2003, 04:30 PM   #8
m750
Member#: 2278
8Sti | 07 allez
White | Comp
heh...
People do the stoopidest things, and noting that, there is very little one can assume that someone did, or didn't do.
I believe the CAT's in your RS are covered under warentee.
Old 06-03-2003, 12:44 PM   #9
Julian
Member#: 1182
MY00 RS
BRP
Also, concerning running with no front O2, this could result in either excessively lean or rich conditions at the cat, either of which could raise the temp of the cat to the point of failure. Did you get a lot of popping during shifts with no O2?
Julian is offline   Reply With Quote
Old 06-03-2003, 05:36 PM   #10
Cujo31
Member#: 19843
2000 2.5 RS Sedan
well, It was hard to tell if the O2 sensor was completely offline, or if it was actally still doing anything. for example, preiodically the car would drive normally, and then out of nowhere the rpms would drop and I'd have to struggle to keep the car alive by feathering the gas.
there was not really any popping from the exhaust during that period, but the chugging idle and constant feathering at stoplights and between gears on a sluggish-at-best fluctuating voltage from the sensor I know were probably my converter's worst nightmare.
update today is 6/3 and since the original post / reset it hasn't come on again....
P0420 CEL Mechanical Fix Impulsivegoat23 Normally Aspirated Powertrain 10 06-04-2007 04:57 AM
DC metro --- Has anyone fixed their P0420 CEL under warranty? impRSa Mid Atlantic Impreza Club -- MAIC 5 08-08-2005 10:37 PM
04+ WRX/STi Helix Electric P0420 CEL Fix J-Rex2004 Mid Atlantic Impreza Club -- MAIC 0 06-23-2005 02:32 PM
anyone use the PDM O2 Sensor Extension to fix P0420 cel? criz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-17-2004 03:13 PM
P0420 Cel fix resistor value? Speedwagon Normally Aspirated Powertrain 6 12-31-2003 09:35 PM
