Old 05-23-2003, 04:12 PM   #1
anaakel
Member#: 37275
1997 legacy
grey
Default quick help needed with ecu replacement
can I replace my legacy 97 2,0 ecu with other ecu that has different number? or should the number be exactly the same?even if the cars year and engine is the same?both cars are without the immobilaizer.
anaakel is offline   Reply With Quote
Old 09-03-2007, 02:04 PM   #2
FTWNeon
Member#: 130047
1997 Legacy GT
Red
Hate to resurrect this old of a thread but I've been searching and I've had no luck finding an answer.
Do I need the same number ecu or will a different one work? Will it matter if the computer came out a car with an auto and is going in a manual?
Ex, I think mine is a 5N, could I use a 4N computer?
FTWNeon is offline   Reply With Quote
Old 09-03-2007, 10:25 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
In the few that I have swapped around, it hasn't been a problem. I don't know what the differences would be within a model with the same trans but auto/manual would likely have different timing and fueling curves to better suit the shifting of the transmission.
You won't blow anything up....if that's any concern.
Jay Storm
Quick Help Needed (CRUISE CONTROL/ECU/SWITCHES) pezcore General Community 4 04-24-2010 11:02 PM
Quick help needed! Should I replace 1 tire only? enXiks Tire & Wheel 6 03-03-2007 01:35 AM
Quick help needed! Should I replace 1 tire only? enXiks Newbies & FAQs 17 03-02-2007 09:45 AM
quick help needed with o2 sensor dire Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-08-2006 11:06 AM
