Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 05-23-2003, 09:11 PM   #1
Member#: 37177
Default Need help on STI HID projector headlamp
I have successfully to make a plug n play wiring harness for sti non-HID projector.
However, I have a question when I install a HID version sti projector. Is the homemade harness ( uses 18 guage wires) is good enough to connect a high current HID ballast from stock plug( 9007).
Also, there was a negative wired from bulb to the ballast. Currently I didn't connect it to the ground, just leave it alone cuz the harness has negative wire already. So do I still have to connect the extra negative wire to the ground.
The harness I am using for non-HID is work on HID's, but the HID is not bright as I expected. Will the wire affect the brightness?
suprawrx is offline   Reply With Quote
Need help rewiring JDM HID projectors kenny08 Southern California Impreza Club Forum -- SCIC 7 01-29-2007 10:26 PM
Need help on STi pink color code EvoLWrx Interior & Exterior Modification 21 05-31-2006 06:02 PM
Need help installing JDM HID projector headlamp facs Vancouver Impreza Club Forum -- VIC 7 01-15-2006 01:36 AM
question on sti hid projectors BlueWRX Interior & Exterior Modification 1 03-15-2004 03:32 AM
need help installing sti hid... David Glasscock North West Impreza Club Forum -- NWIC 11 03-22-2003 07:29 AM
