Old 05-24-2003, 04:31 AM   #1
dingo dave
Member#: 33177
2000 Impreza RS coup
white
Default should first mod be front strut bar, CAI, or Short shifter??
I am looking to mod my '00 rs. I can only do one of these at the present time. On the strut bar i would like to spend <$125 and on the CAI <$150.
With that in mind, which one would give me more bang for the buck? I don't drive my car too hard, but i would like to enhance performance for the heck of it. If a CAI would improve gas mileage that would be a definite factor in the decision. However, if a CAI means loss of low end torque then that may not be acceptable. i do a lot of city driving.
Another option i just thought of could be a Kart-boy short shifter along with their bushings.
If i go with the CAI, is there going to be a problem resetting the ECU?
dingo dave is offline   Reply With Quote
Old 05-24-2003, 06:40 AM   #2
Slack
Member#: 17548
If you haven't already, buy yourself some high performance tires. Buy a WRX sedan rear sway bar($40~60) and upgrade the mounts($75) and end links($80~110). A CAI won't do you much good this time of year in TX. Also a strutbar won't do much at all for you unless you at least have upgraded struts and springs.
Try this:
WRX sway - $50~
Whiteline sway mounts - $75
hi-flow panel filter (k&n/amsoil/etc) - $40
__________________________________
Total $165
Should open up the flow of the engine and improve handling a bit.
Mick
Slack is offline   Reply With Quote
Old 05-24-2003, 08:47 AM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Unless you've done something to the suspension to stiffen it up I doubt you'll notice any difference w/ a front strut bar. The strut towers are pretty close to the fire wall and it's already stiff up front. You'd be better served w/ new tires or a rear sway bar followed by a rear strut tower brace rather than a front one.
Peaty
Peaty is offline   Reply With Quote
Old 05-24-2003, 09:02 PM   #4
dingo dave
Member#: 33177
white
I saw an FHI rear sway bar for a WRX that "improves the oversteer on Imprezas", according to subaruwrxparts.com. It sells for $79 dollars. It is 20 MM. Is this what Slack is talking about?
Can someone please explain what "improved oversteering" would do?
Old 05-25-2003, 02:05 AM   #5
MattDell
Member#: 16803
Definitely go with the Kartboy. It makes the car 10x more fun to drive!
-Matt
MattDell is offline   Reply With Quote
Old 05-25-2003, 03:09 AM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Check over in the suspension forums, there are alot of rather detailed threads about swaybars. The one he is talking about specifically is just a used WRX sedan swaybar, which you have to get from another club member who has one for sale (which is the cheapest way to do it, I got mine for $35 that way)
Old 05-25-2003, 05:02 PM   #7
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
My rear sway bar was the best single mod I've ever bought. I have the whiteline 24mm adjustable.
jasona is offline   Reply With Quote
What should my first mod be? Greg B.(blue 06 WRX) General Community 32 05-20-2009 10:19 PM
FS: Cusco front Strut bar for BE BH Legacy Jason Private 'For Sale' Classifieds 0 09-29-2003 05:50 PM
STrut bar or CAI? NeuBluScoobyBoi Bay Area Impreza Club Forum -- BAIC 11 08-01-2002 11:34 PM
Which first: tires, or rear sway/front strut bar/ganzflow? TreyV Brakes, Steering & Suspension 29 05-10-2001 08:11 AM
