Old 06-03-2003, 04:42 PM   #1
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
Default options for rear toe adjustment?
Well I hit a rock a while ago and after replacing the struts it appers that the toe is way off on the right rear. I went ahead and adjusted the eccentric bolt to full toe-in but I still have toe-out. Does anybody offer eccentric bolts that are more eccentric? I checked out whitelines offerings but they just have adjustable control arms. I cant see what might be bent or moved, it looks just like the other side.
Chris
biggreen96 is offline   Reply With Quote
Old 06-03-2003, 05:01 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If toe is still off doesnt that tell you something else is bent? Id fix that problem first, who knows when it will fail.
Otherwise look at MRT or Whiteline or (forgot the third company) rear replacement lateral links.
Toe and Camber are adjustable, plus you get new bushings.
ciper is offline   Reply With Quote
Old 06-03-2003, 07:07 PM   #3
Farfrumwork
Member#: 10202
'07 Spec B
'07 fozzy/'85 EJ22 Westy
I did something similar, but it was my own jackassed driving that caused it... anyway, my '98 GT has a terminal toe-in in the rear passenger side. The toe is adjusted all the way out too, but I still have ~.4" toe-in.
nothing looks bent. And it actually drives ok, and hasn't eaten tires... but it used to handle better!
so I am going to, someday, start pulling it all apart and see if I can find something bent I am thinking it is the long 7" bolt that connects the lateral links to the hub, or possibly mangled bushing in the front linkeage (your would more likely be the rear linkeage) if I can't find anything I will replace the front lat link and hope for the best.
my cross toe is fine, and the camber is not off either... I WILL find the culprit
-Chad (who learned the hard way, twice , about driving like an ass
haha
Farfrumwork is offline   Reply With Quote
Rear toe adjuster frozen Lee MD Legacy Forum 3 10-03-2011 02:10 PM
what other options do i have for rear view camera? 06D Car Audio, Video & Security 1 06-02-2010 12:04 PM
Frozen Rear Toe Adjustment Bolt six3jag Brakes, Steering & Suspension 4 01-07-2010 09:30 PM
Anyone figure out a loooooong extension for rear Koni adjustments? Patrick Olsen Brakes, Steering & Suspension 12 11-02-2005 12:38 AM
GC6 Alignment: Is rear toe adjustable? Suba_Roo Brakes, Steering & Suspension 1 03-25-2003 04:29 PM
Message Board Statistics All times are GMT -4. The time now is 01:52 PM.
