Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 06-24-2000, 08:57 AM   #1
immortal_suby
Member#: 1711
140 rogue points!
2013 GBS BRZ Limited 6MT
Question Front main seal, timing belts -oil pump&water pump?
I'm gettin ready to bite the bullet and drop off the beast to have the front main seal replaced. I am also going to have the timing belts done since there's 109k on the car and I don't know when they were last changed. So, is it a good idea to have the oil pump and water pump done while they are in there? The local suby tech has seen quite a few svx's so I trust he can handle them competently. I know on the 1.8L it was a good idea to do this. Any thoughts?
sorry if this is a faq, kc's search function is down and yahoo is a pita to search.
immortal_suby is offline
Old 06-24-2000, 09:33 AM   #2
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
Yes, have it all done at the same time. Most of the cost involved is the labor to get to that stuff, so while they have access to it, you might as well get it done. Do the water pump for sure. I'm not sure I've heard a lot about doing the oil pump also, but I would imagine it'd be a good idea. Anyone else have thoughts on that?
Rich
richeich is offline
Old 06-24-2000, 03:14 PM   #3
AZ-GT
Member#: 192
2011 WRX
WR Blue
Post
I just bought a 92' last month with 88k miles.
Since I was planning to do the timing belt we
also did the following while we were in there:
new waterpump, new seals for oil pump and powersteering pump. We also replaced the tranny filter below the battery and added a tranny cooler. Also added an oil cooler and changed out the fuel filter. Finished it off with synthetic fluid in the tranny, diffs, and engine.
AZ-GT is offline
Old 06-25-2000, 07:15 PM   #4
billsSVX
Member#: 1690
Post
Let me know what they want to do all this. I am looking at the same thing soon.....
Thanks
Bill
billsSVX is offline
HTML code is On
FS: ej25 water pump/cam seals/oil pump seals/timing belt cover gaskets sti charles Engine/Power/Exhaust 24 11-02-2008 02:10 PM
oil leak front main seal? burm Service & Maintenance 3 04-15-2008 01:03 AM
How deep should front main seal be installed? Patrick Olsen Service & Maintenance 6 06-22-2007 12:20 AM
Cam and front main seals leak more since replacement???? logoguy General Community 0 09-09-2005 10:06 PM
Replaced front main seal and oil pump o-ring archer Normally Aspirated Powertrain 4 12-28-2001 03:28 AM
