#1 |
Member#: 7888
Vehicle:02 wrx WR Blue |
Okay so I have a '96L that is starting to be down on power pretty bad. What straight swap can I do. or what is the swap with the least harness changes?This car is a nice RS replica with carbon hood 17" tarmacs lowering springs. Looks the part & then fails when it counts.
#2 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
I've heard that a DOHC EJ25 would be a direct swap including ecu and engine wiring. Remove engine, put in new engine, remove old ecu, put in new ecu... done. However, I have not personally verified this. Here is the thread.
-Jon |
#3 |
Member#: 1135
BAIC
Vehicle:2005 WRX WAGON Silver |
Hey Vince,
You can buy my EJ25 after I do the JDM STI Ver 6 swap on my car. I'll let you have it for cheap. I'll probably throw in the rear diff. and entire front clip since I'll be replacing all of it. The car has less than 40K miles on it. -JOE |
#4 |
Member#: 2272
BAIC
Vehicle:95 L AWD LIFTED!!! 1970 Subaru FF-1 Coupe |
Hey you (homerjay), ive been waiting for an engine longer than just about anyone
How much? (I only care cause im local, LOL) |
| Thread Tools | |
| Display Modes | |
| Need Help, Need Help | nicholas112481 | Factory 2.5L Turbo Powertrain | 8 | 11-10-2010 01:24 PM |
| Need help!! Need to find a +12v switched wire NOW! Please help! | nxwrxfx | Electrical & Lighting | 16 | 04-25-2006 05:29 PM |
| Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! | 2k2 | Off-Topic | 63 | 12-24-2003 10:35 PM |
| Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line | STR8OUT | Factory 2.0L Turbo Powertrain | 7 | 04-18-2003 12:11 PM |
| Need help!Need flywheel bulletin from SOA.Please help. | RallyeX | General Forum Archive | 3 | 06-01-2000 07:57 AM |
