Old 05-26-2003, 12:09 PM   #1
DDImpreza
Member#: 34525
1999 impreza rs
white/ carbon fiber
Default help my car wont start
i have a 99 rs. i have apex n1 cat back a weapon r intake and apex safc. heres the problem i was driving down the street last night it was raining and i was screwing around with a bmw i was in third gear and everything just cut out. iwas at wot. i pulled into a parking lot. i tried to restart it but it just start and stalls. i give it gas and nothing happens just stalls out faster. i disconnected the mass air flow and tried to start. but even with it disconnected it does the same thing. reset the ecu same problem. i have a bout 1/3 tank of gass. about two months ago the wiring harness for the maf broke the wires connecting the maf. because of the intake i guess it was too tight. so i extended them and made my own custom plug. so the harness could have some slack. im almost positive thats not the problem because it worked mint for two months. im thinking it might have something to do with fuel. any ideas???? i had it towed to the dealer because i couldnt get it started. this sucks !!!!!
DDImpreza is offline   Reply With Quote
Old 05-27-2003, 09:34 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
It could be caused by a number of problems. But, check for these:
1) Check if the engine is getting sparks. Ignition coil can be faulty.
2) Check for the fuel pressure. Fuel pump may be faulty.
3) You said you had a SAFC. Make sure the connections at the ECU are tight and good.
tmat3 is offline   Reply With Quote
Old 05-27-2003, 11:57 PM   #3
DDImpreza
Member#: 34525
1999 impreza rs
white/ carbon fiber
got it back from the dealer it was the mass air flow sensor. i guess because i have a carbon fiber hood and the vent is open i have a foam filter on a elbow style intake it was getting real wet and the moisture or water screwed up the maf .. oh well thts my third one. its weird because the first time it went it was totally different problem.. i dont know not a mechanic... but thanks for the help and ideas.. oh yeah to solve the problem i took the plate off my stock hood and closed up the hole on the hood.
help...my car wont start! akcel Electrical & Lighting 14 02-13-2008 02:17 PM
help, my car wont start Ronaldo Vancouver Impreza Club Forum -- VIC 27 11-11-2004 09:29 PM
Please help ---My car wont start. drtaka Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-13-2003 04:48 PM
help my car wont start DDImpreza New England Impreza Club Forum -- NESIC 2 05-27-2003 11:58 PM
