Closed Thread
Old 05-26-2003, 04:22 PM   #1
mRgUnN
Member#: 14115
2003 Impreza WRX
WR Pearl Blue
Default How to read the stock turbo boost gauge?
Dear Subie Pals:
I have done several searches of this forum and on the internet at large. No where could I find a simple FAQ on how to read the stock Subaru WRX gauges, turbo, oil Temp etc. In this case in particular, I want to know if I am getting the optimal performance from my WRX sedan's turbo.
So my question is: How do I read the stock Turbo boost gauge, and convert that number to Pounds Squar Inch or PSI? Is there an FAQ that explains all of this that I missed?
Note, the stock gauge reads as follows:
- .1
- .05
0
+.05
+.1
+.15
I rarely if ever see any result above +.09, I have seen it peak out at about +.11 but only for a split second, is this correct for a car that is all stock except for the Boost solinoid mod?
Thanks,
mRgUnN
PS If the Mods see this and it is not in a n00b FAQ section I missed, it might be a good idea to put this question in a FAQ.
mRgUnN is offline
Old 05-26-2003, 04:56 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Your gauge reads in MPa - to convert to psi, multiply by145.04, so 0.09 MPa is around 13psi, which is close to the max boost of 13.5psi for a WRX. It is pretty normal to see a little bit of a boost spike on hard acceleration.
DrD is offline
Old 05-26-2003, 05:49 PM   #3
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
Boost also depends on the climate and weather you are experiencing. In optimal weather, I often see readings of .1MPa out of my stock WRX, which is ~14.5psi. Not bad, if you ask me
DrD hit it right on the nose.
gjhsu is offline
Old 05-26-2003, 11:03 PM   #4
krazedant
Member#: 21218
Baby has been sold
krazedant is offline
Old 05-27-2003, 08:16 PM   #5
03WRXMA
Member#: 35081
2012 WRX
I have seen peaks as high as 1.07, is this normal at all?!
03WRXMA is offline
Old 05-27-2003, 11:34 PM   #6
digitaltekniq
Member#: 18029
On a stock WRX?
digitaltekniq is offline
Old 05-28-2003, 02:15 PM   #7
03WRXMA
Member#: 35081
2012 WRX
Originally posted by digitaltekniq
On a stock WRX?
Yes sir!
03WRXMA is offline
Old 05-29-2003, 01:16 AM   #8
crazy_sherm
Member#: 30954
2003 WRX Wagon
Sonic Yellow
I don't think my boost gauge goes up that high? wouldn't 1.07 mPa = 155.2 psi?
crazy_sherm is offline
Old 05-29-2003, 01:03 PM   #9
Lordhowe
Member#: 35265
hahahaha that's alot of boost i think he means 0.107 which is 15.5, but still, that seems a little high for a complete rex
Lordhowe is offline
Old 05-29-2003, 01:06 PM   #10
Lordhowe
Member#: 35265
* complete STOCK rex, sorry i forgot a word
Lordhowe is offline
Old 05-29-2003, 02:11 PM   #11
03WRXMA
Member#: 35081
2012 WRX
you guys are correct, damn decimal point
03WRXMA is offline
Old 05-30-2003, 08:30 AM   #12
mRgUnN
Member#: 14115
2003 Impreza WRX
WR Pearl Blue
Default Thanks Every One!!!
Dear Subie Pals:
Thanks to everyone who took the time to reply, very helpful!
Regards,
mRgUnN
PS Mods any word on this making to the newbie FAQ?
mRgUnN is offline
Old 05-31-2003, 06:07 AM   #13
xjohnx
Member#: 18975
2013 BRZ Limited
Satin White Pearl
my friend has hit 1.09 peak on his bone stock rex, it's not a consistant thing, but it peaks there ever now and again.
xjohnx is offline
Old 05-31-2003, 12:30 PM   #14
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
Boost spikes no son bueno. I think the ECU retards timing or cuts off fuel if boost gets to a certain level. What is it, around 18psi?
gjhsu is offline
Closed Thread
how to read the stock turbo gauge hagood22 Newbies & FAQs 6 03-24-2008 11:31 PM
How to modify the stock dummy water temp gauge to real water temp gauge? SuperTurbo Normally Aspirated Powertrain 14 02-01-2008 06:38 PM
How to read an Apexi Turbo Timer TimBeeno Electrical & Lighting 4 08-06-2007 01:37 PM
how to read Oil and Fuel Pressure Gauges? ac23 Newbies & FAQs 5 05-07-2006 02:56 AM
How to open up stock turbo gauge... msun2000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-14-2003 03:08 PM
