#26 |
Member#: 9972
E. Canada
Vehicle:2007 Jetta grey |
Hope you find the problem Jaxx. I am planning the same thing with my car... a 96 jdm swap. Can't decide if I am going to swap tranny also or keep the original. Lachute will probably do the swap.
#27 |
Member#: 24956
Vehicle:1997 Impreza WRX Steel Blue Mica |
can u give some details about the a/w i/c setup u had. u didnt run a seperate radiator? PM me if you have to, i wanna know all the details.
also, whats the efficiency of the air-to-air i/c without a hood scoop? Brent |
#28 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
no not really iit came with the motor .. i pondered using the a/c condenser as a heat exchangre but found an air to air i/c .... never fired the car with the air to water on it.. the air to water is for sale (BUY IT!!! )
air to air dunno still getting base line tuning down .. hit 25 mph at .5 bar today for the first time (think baby steps) then my right front wheel berring sezed so i guess ill have to fix that first.. |
#29 |
Member#: 24956
i have the an a/w i/c, but i dont wanna take the time to do all that work. u think i'd be safe using an a/a with an EJ18 with a TD04 running around .4 bar boost?
#30 |
Member#: 3357
Vehicle:2002 WRX Black |
Hey Jaxx nice setup you got going their buddy..
I am curious to what clutch setup you are running, I willing to believe that you kept the cable setup instead of going with a push type WRX. I will be shortly going down this road as well.. Thanks, Imprezd~ |
#31 |
Member#: 177
NWIC
the clutch ah yes...
turns out that there are 2 sizes of subaru push clutch (either will work) with a cable-push or hydrolic-push i bought both my flywheel and clutch used .. proublem is that i got a 8 7/8 clutch and a 8 1/2 fly wheel ended up using another 8.5 inch clutch that we have no idea what it came from. it is definatly stiff but the friction disk we used is to thick so it does not like to dis-engage edit:more on the air to water here look at the bmp files they are from the AU srevice manual click here Last edited by Jaxx; 06-03-2003 at 01:11 PM. |
#32 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
Stupid front wheel bearings. Who needs those?? I hope it wasn't a traumatic experience...
-Jon |
#33 |
Member#: 177
NWIC
so in the quest for bankruptcy last fall i bought an 96 ej20k(vf-22) w/ a 4.44
so yes i am starting with an working ej20g w/ standalone but i want a stock like drive-ability so today i started the wiring i am using what i have started calling the "rich" method -unless he comes up with a better name the idea is that you keep the stock harness intact and create a standalone harness that runs the engine .. you then splice in the wires you need any way i stated with this diagram and this excel sheet so after sitting for 3 months (busy time of year at work) today i stripped the harness down to what i think i need |
#34 |
Member#: 66739
Vehicle:2002 WRX wagon silver |
jaxx- was the flywheel the EZ3.0 MT one from ebay?
--keith |
#35 |
Member#: 177
NWIC
highly unlikely .. look at the date of the post, i still have it in the garage .. no idea what it is for
#36 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
old threads FTW...
#37 |
Member#: 66739
im a douche!
old threads = arch nemesis |
#38 |
Member#: 132385
AKIC
Vehicle:94 RHD Legacy w/wrx swap. White |
how hards the Tec2 to wire, compared to using my OEM computer (ive got a RHD 94 Legacy with EJ20 swap, and im down to just the wiring and plumbing an exhaust)
#39 | |
Member#: 3362
Vehicle:1985 I've wired a Few cars in my day |
Z |
#40 |
Member#: 832
RMIC
#41 |
Member#: 177
NWIC
yes but now i have maps ... its not getting it to run, its getting it to idle especially when its cold
do you have the vishnu wiring guide? |
#42 |
Member#: 2692
SCIC
I've used the tec II, tec III multiple times and wired quite a few swaps let me know if you guys need any help.
#43 |
Member#: 2692
SCIC
Jaxx it seems you have the wiring diagram for your EJ20g why not just use that ecu?
#44 |
Member#: 832
RMIC
#45 |
Member#: 177
NWIC
my G didn't have a harness or ecu ..it was only $600 plus it was a 200 ps version
once you have a good TOG the tec is actaully pretty easy (w/ a wideband and correction turned off) target 11.2 under boost add advance till it knocks then back off a few |
#46 |
Member#: 2692
SCIC
I love the tec, I have no idea where my old tec II maps are though. I'm still using the t3 on one of my cars, just hate mafs on a 4" intake
, and I don't see any benefit on adding a blow-through maf and flashing when it runs just fine.Last edited by kaos200; 02-02-2007 at 10:15 PM. |
#47 |
Member#: 177
NWIC
yeah the tec3 is light years ahead of the 2 though
in hind site it was a very good ecu to learn on |
#48 |
Member#: 177
NWIC
well time has come to take the G out
final shot ![]() tec2 in a box ![]() |
#49 |
Member#: 177
NWIC
and after a 3.5 quarts of shockproofrookiemistake
gone ![]() i was counting the number of non factory harness that went through the firewall 1 boost gage map sensor 2 fuel pressure sensor 3 EGT sensor 4 vacuum hose for boost control 5 boost control solenoid 6 wideband 7 tec uplink cable changing the peddle box will be interesting .. |
#50 |
Member#: 78658
Vehicle:2005 LGT Limited Black/Black |
so wait...why are you going ej20k???
| Thread Tools | |
| Display Modes | |
| my swap progress EJ20G | homemade | Rocky Mountains Impreza Club Forum -- RMIC | 63 | 06-01-2010 05:06 PM |
| My swapped flared wagon progress | ProjectL | Member's Car Gallery | 204 | 03-10-2010 12:10 AM |
| RR's Swap Progress pt. 2 | RR02wrx | Subaru Conversions | 87 | 05-03-2007 08:26 PM |
| my swap progress | ImprezaRSfan! | Subaru Conversions | 23 | 05-31-2004 11:54 PM |
| Silvia swap progress | Blugin | Texas Impreza Club Forum -- TXIC | 29 | 05-01-2003 11:10 PM |
