Old 03-12-2007, 08:50 AM   #51
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
because the standalone made for good power but crappy transportation .. i coundn't drive it to work it was also half as old 4/1990 vs 5/1997
i wanted a stock ecu for cold starts
plus it came with a 4.44 (old tranny has 167k miles on it
Old 03-12-2007, 09:15 AM   #52
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
is standalone that much of a pain in the ass?
civic2scooby is offline   Reply With Quote
Old 03-12-2007, 12:55 PM   #53
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yup 1234
cold start temp correction sucks i played for a long time
no IAC was the big proublem
my engine had a 30% change in compression cold to hot
Old 03-16-2007, 08:09 PM   #54
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
cleaning
painted engine bay, hydro conversion, gda throttle cable
Old 03-16-2007, 08:37 PM   #55
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Looks like quite the project you've got going there!
I'm not trying to be rude or sound like a jackass but whats the big deal with the JDM stuff? Is all the trouble to get it working right worth it?
mxpunk is offline   Reply With Quote
Old 03-16-2007, 08:51 PM   #56
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
yes it is very much worth it.
Old 03-17-2007, 05:56 PM   #57
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
maybe .. the transmission is .. the 20k vs a 205 .. maybe not
Old 03-18-2007, 12:09 PM   #58
jamesfacts
Member#: 51282
98 RS
black & blue from parking
You need a new camera.
jamesfacts is offline   Reply With Quote
Old 03-19-2007, 11:37 AM   #59
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You joking, right? The 20K is far superior to the 205 if you compare engine to engine. The 205 heads are really just old Ej20G parts with a newer camshaft design. And just the fact that the EJ20K is 280ps out of the box with plenty of room still left on the turbo is worth the price of admission (especially when it was half of current market on an Ej205 swap!). I literally watched and waited for more than 2 years to grab my Ej20K...
mxpunk,
Maybe you don't get it, but a JDM swap is no more and no less work than a USDM swap. There are little differences to what's required to make them work, but I fail to see how you have got it into your head that a JDM swap is MORE work...
Old 03-20-2007, 10:02 AM   #60
kheff46
Member#: 66739
2002 WRX wagon
Edit!!
kheff46 is offline   Reply With Quote
Old 03-20-2007, 10:58 AM   #61
Matt Monson
Member#: 832
99 2.5RS, '85 911
pm me and we'll chat without sidetracking Jared's thread...
Old 03-22-2007, 10:33 PM   #62
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
hmm so i thought that Subarus never had separate engine harnesses ....
not so
4 more wires to label need to pick up some more heat shrink
Old 03-23-2007, 08:08 PM   #63
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
harness done!
Old 03-23-2007, 08:19 PM   #64
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Originally Posted by Matt Monson View Post
mxpunk,
Well..I would think JDM swap is easier on a pre OBD-II vehicle but from what I understand OBD-II and JDM stuff is tricky, which is why I think that the JDM swap stuff is more of a hassle then doing a regular USDM one..
I guess the idea of dealing with emissions makes me think doing a JDM conversion is not worth it..but if im wrong (probably am) please tell me..im always willing to learn
Old 03-23-2007, 09:12 PM   #65
poormansporsche
Member#: 79798
The EJ20k is way cooler than a 205. I own both now. While the EJ20k isn't running yet I already know it's going to beat the pants off my swapped RS with a EJ205. As stated above the heads are way better. The short block is similar to the 205 but in my case it's an STI and is forged internally and the STI v3 and v4 have some of the hottest cams from the factory. It's no joke.
Jaxx wassup with the GDA throttle cable? Is this a requirement. i was going to use the EJ18 cable will it not fit?
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 03-23-2007, 10:59 PM   #66
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
dunno the throttle is in the same place as the 205.. i was under the impression it was needed for the 205 too
what have people been doing with the ej20k egt sensor? any one know what resistor to put in?
wish mine had been a STI mmmm 8000 rpm would fun
Old 03-24-2007, 02:13 AM   #67
poormansporsche
Member#: 79798
How different are the heads between the STi 20k and the non STI 20k? I know the STI is rated for like 3 lb-ft more torque but thats about it. With a power fc you'd probably rev to 7.5k just fine. Also even with the STI motor and 7.9k rev limiter, its still a 7k rpm motor just has a higher ceiling to avoid hitting the wall.
Sounds like another surprise coming. Hopefully the EJ18 TC works. I don't want to buy anything else. I gots no money left he he.
cheers
garrett
Old 03-24-2007, 01:15 PM   #68
jamesfacts
Member#: 51282
98 RS
It's not really a requirement for either the 205 or the 20K, but it sure does fit a lot better.
Old 03-25-2007, 09:59 AM   #69
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
any one know the resistance for the egt sensor for an ej20k?
Old 03-25-2007, 10:34 AM   #70
kheff46
Member#: 66739
2002 WRX wagon
i can rev past 8k with my SYMS ECU(V4 STi). and let me tell you, it feels like its at 3,4,5K RPM. it's silly fast, and makes boost from 2K on.
i could've used my L cable or the STi one. same length etc. STi just came from opposite side, but same length fwiw.
i will findout resistance later tonight JAXX
--keith
Old 03-25-2007, 11:11 AM   #71
GripGC8
Member#: 110653
87 FC3S
harness done!
damn..nice...you wanna do mine?
GripGC8 is offline   Reply With Quote
Old 03-25-2007, 11:19 PM   #72
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
sure how about $1500
Old 03-26-2007, 01:40 PM   #73
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
a list just for list sake things to do as of 3-26
get left front wheel bearing fixed done $185
bleed MC-done
buy/change spark plugs -using copper bkr7e at .30 (will change to the sock once its running smoothly)
find ej20k plug wires? -done-magencores
install left front hub -done
install firm bushings in to 01 rear subframe - can't find them
move over lat links to 01 subframe-done
install rear subframe-done
move over flange to 4.44-unnneed
fill rear dif -done
install rear diff -done
install spiffy external braces x3-only 1
install rear axels/hubs-done
fix rear heat shield-done
test fit harness-done
decide if i want to run greddy fp/egt/boot sensors in harness-done not gonna
tape/cover harness-done
find way to secure RHD ecu to car -done
test fit power steering hoses-done
cut power hoses to length-done
take lines to work, press on fittings-done
install ps lines-done
recenter steering wheel-done
check peddle positions-done
plug holes to ac box-done
examine shift linkage-done
find 2002+ linkage? -done used 97 linkage which is the same as the RS
buy tranny bushings?[-done
crush washer for tranny? leaking? -done just loose
install engine-done
decide on 93 or 97 tranny mount-done 97
install front axles/tighten down hubs-done
figure out heater hoses-done
move over brake vacuum hose-done
install new radiator/hoses (new clamps?)-done
overflow? -bought in fender over flow
add coolant-done
add oil-done
add tranny fluid-done
reconnect SC/ground/reverse/nuteral/speed sensor
choose and install shift linkage[color="Red"]-done 97/COLOR]
install drive shaft/heat shield -half done
install exhaust
install IC
install starter (not sure which one)
install alturnator -done
clean air intake filter -sorta done want to clean it again
fab bracket to hold MAF
start?
reinstall seats /glove box
bleed brakes
change oil
get alignment
more later
Old 03-26-2007, 07:08 PM   #74
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
01 subframe
whats with that separate engine harness?? 93 thing?
havent been in this thread yet
Hurley 2.5 WRS is offline   Reply With Quote
Old 03-26-2007, 10:36 PM   #75
jamesfacts
Member#: 51282
98 RS
The 93-97 cars had seperate harnesses. Wierd.
my swap progress EJ20G homemade Rocky Mountains Impreza Club Forum -- RMIC 63 06-01-2010 05:06 PM
My swapped flared wagon progress ProjectL Member's Car Gallery 204 03-10-2010 12:10 AM
RR's Swap Progress pt. 2 RR02wrx Subaru Conversions 87 05-03-2007 08:26 PM
my swap progress ImprezaRSfan! Subaru Conversions 23 05-31-2004 11:54 PM
Silvia swap progress Blugin Texas Impreza Club Forum -- TXIC 29 05-01-2003 11:10 PM
Message Board Statistics All times are GMT -4. The time now is 05:08 PM.
