#76 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Yep. Those 2 white connectors in the middle of it act kind of like an SMJ handing everything else that it has to hook to over on the dash side of the car...
#77 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
yep only 2 wires that i had to go elsewhere for
oil pressure and 1 wire temp the next harness would be alot easier |
#78 |
Member#: 11620
Vehicle:1997 GF4 -STiV3 Saab 93 TX sportcombi |
#79 |
Member#: 79798
The coil pack is the same on the 94 Legacy turbo. I would guess if you did some research the plug wires are probably the same as well. Just taking a shot in the dark tho.
cheers garrett |
#80 | |
Member#: 177
NWIC
dam magnacores are expensive coil pack is not the issue .. and have the number for that and it is in the parts system Last edited by Jaxx; 03-27-2007 at 05:35 PM. |
#81 |
Member#: 79798
Yeah I'm saying if the coil pack is the same on the EJ20K and the EJ22T then mabbe the plug wires for the EJ22T are the same as the EJ20K. I don't know this for certain just conjecture.
cheers garrett |
#82 |
Member#: 11620
The accel ones that I made from a universal kit work well. Measured about 1-2 ohm resistance. The down side is that they allow dirt to accumulate in the spark plug wells. The price was right.
I can see if a Canuck dealer can access those OEM ones if you like? |
#83 |
Member#: 177
NWIC
20k and 22t
dohc vs sohc = different lengths Canadian dealer ya please give her a shot |
#84 |
Member#: 56345
Vehicle:93 Swapped L Green |
Maybe i'm talking out of my ass but wouldn't DOHC EJ25 wires work?
#85 |
Member#: 43916
RMIC
Vehicle:2001 Impreza 4.7 Blue Ridge Pearl |
dogleg on one wire, fits super tight if it fits at all
#86 |
Member#: 177
NWIC
#87 |
Member#: 177
NWIC
so left work early yesterday and took today off
work completed rear subframe installed rear diff w/ fluid installed axles (you cant put the dual spline axles in the wrong side) installed beatrush diff bushing deal found that these don't work with beat rush deal any one want a set paid $65 for them this weekreassembled everything from the axel joint back test fit and marked hanress wrapped harness installed harness !!! moved ej20k ecu into ej18 ecu case thinking that i might be able to start it this weekend pictures ver 3 vs fxt ic pipe i am thinking you could move the ver 3 pipe to a fxt intercooler and bolt it up to a ej20G Last edited by Jaxx; 03-30-2007 at 10:52 AM. |
#88 |
Member#: 43916
RMIC
you should be able to.
what are those braces? like, where do they go? |
#89 |
Member#: 51282
Vehicle:98 RS black & blue from parking |
Yea, what's the deal with those braces?
#90 |
Member#: 79798
They like connect to the rear subframe some how. GT Spec has installed pic's on their site. It's an interesting design. Would like to hear how they work when someone can A/B with and without them.
That harness is a biotch aye mate? ![]() cheers garrett |
#91 |
Member#: 177
NWIC
braces go from an unused hole in the subframe to under the swaybar mounts someone buy them ill ship on monday...
harness: not too bad a second one would be allot less stressfull what i ment to say |
#92 |
Member#: 832
RMIC
Of course the braces don't work. They are bent.
#93 |
Member#: 177
NWIC
could be .. they are ebay pieces .. the beatrush diff isolator uses the same unused holes
one is bent to clear the exhaust |
#94 |
Member#: 43916
RMIC
get them welded to the beatrush.....
itd be defacing some nice parts, but itd be a sick brace..... ![]() |
#95 |
Member#: 832
RMIC
Oh noes. Jaxx is stressing this morning and didn't get my joke...
#96 |
Member#: 177
NWIC
no worse than you mr cheap seat buy
#97 |
Member#: 177
NWIC
took the transmission off again and put the engine in the car to cut the ps lines to length
i looked and the pilot berring is flopping around inside the clutch 1 step forward 2 steps back ![]() |
#98 |
Member#: 2958
NWIC
Vehicle:2001 WRX (GC8) |
What flywheel do you have? My findanza is doesnt fit a standard pilot bearing. The hole in the center is too big. I went to Clutchworld and got a slightly larger pilot bearing and had them press it into the flywheel.
#99 |
Member#: 177
NWIC
that probably what is going on it just fit a little loose ...
that sounds like a good idea maybe a resurface at the same time.. monday project PS lines are done ![]() |
#100 |
Member#: 79798
| Thread Tools | |
| Display Modes | |
| my swap progress EJ20G | homemade | Rocky Mountains Impreza Club Forum -- RMIC | 63 | 06-01-2010 05:06 PM |
| My swapped flared wagon progress | ProjectL | Member's Car Gallery | 204 | 03-10-2010 12:10 AM |
| RR's Swap Progress pt. 2 | RR02wrx | Subaru Conversions | 87 | 05-03-2007 08:26 PM |
| my swap progress | ImprezaRSfan! | Subaru Conversions | 23 | 05-31-2004 11:54 PM |
| Silvia swap progress | Blugin | Texas Impreza Club Forum -- TXIC | 29 | 05-01-2003 11:10 PM |
