Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 11-11-2000, 06:58 AM   #1
Gary Thomas
Member#: 1832
Post Finding "Check Engine" light codes
Wonder what is making your "check engine" light come on?
Here's how to find out: Remove the small carpeted panel on the wall by the driver's foot. You will see two blue wires that can be plugged into the black diagnostic plug. You can then read the blinking codes on the check engine light.
To know exactly where to plug in the two blue wires, check out
http://ia.yimg.com/a/65d42580/h/2858aac1/diagterm.bmp
You are in the "read memory mode" if you use hole 2 and keep the engine off (key on, engine off). You can go a step farther in your diagnosis if you warm up the engine and then use hole 1. Then hold the rpms over 2000 (2100 or so) for over 40 seconds.. Then it should start to blink out codes on the check engine light.
Long blink is 10's and short is 1's...
Error Codes:
11 Crank Angle Sensor1
13 Cam Angle Sensor
14-19 Fuel injectors 1-6 in order
21 H2O Temp Sensor
22 Right knock sensor
*23 MAF Sensor
24 Bypass air control solenoid valve
28 Left knock sensor
29 crank angle sensor2
31 TPS
32 O2 Sensor right
33 VSS 2
34 EGR Solenoid Valve
35 Purge Control solenoid valve
37 O2 Sensor left side
38 Engine Torque Control
41 A/F leaning control
45 Atmosphere sensor
Gary Thomas is offline
HTML code is On
