Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 05-27-2003, 12:25 AM   #1
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Default Best bang for the buck...(aftermarket for 2.5rs)
So, I know I've been going the wrong way, but in 2 weeks my stereo will be complete and I need to start on other parts to make up for the added weight =P
What have 2.5rs owners found to give them the most bang for your buck? I've heard that CAI is a waste, leans you out and just makes it louder...
Perhaps CAI +Injectors/pump/rails and a chip to make up for the leaner burn?
Which is the most restrictive on the stock config? intake or exhaust? Which should be changed first?
I've heard lots about cobb cams working wonders...
I'm open to all ideas...but no turbo, I've heard lots of stories of RS-T's tearing the stock tranny to pieces...
-- AcquaCow
AcquaCow is offline   Reply With Quote
Old 05-27-2003, 12:36 AM   #2
nySulli
Member#: 32617
2008 STi
well, the CAI might be a waste on wrx's, it seems to help everyone out on the 2.5's, like 5-8 hp, cat backs are generally dyno'd at 6 whp gains for 2.25", and headers seem to add 10-15 whp given their equal length and the catback's been done, but stainless headers/cat run about 900 bucks, mrt sells a mild steel header back system for 700 and its dyno'd at +14 whp, but brullens setup has shown +21 whp
i've heard more then one person claim they got more power with a different muffler on the mrt headerback setup, so maybe thats your best bet
nySulli is offline   Reply With Quote
Old 05-27-2003, 02:34 AM   #3
joefocker20
Member#: 13745
2015 STI
Best bang for the buck would be the MRT headerback. You won't need to change your fuel rail or injectors anytime soon, RS's run terribly rich to begin with. Right now, I have a Ganzflow CAI, 1.19lb crank pulley, Borla Headers, trackpipe, Stromung Exhaust, a PROECM Chip, and an Exedy Clutch and 13lb flywheel on its way. I don't really know how much of a difference any of my more recent mods made due to a slipping clutch, but I'll be driving ALOT to break my new clutch in so I can find out how my car feels now.
joefocker20 is offline   Reply With Quote
Old 05-27-2003, 08:09 AM   #4
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Start with a DIY intake.
3" brake duct tubing from the stock air box. Use some weatherstriping stuck a couple turns on the box inlet and the ducting goes on really tight (sealed). Run the tubing inside the fender openning, down to behind the vent below the pass side marker light. Contrary to poplular belief, water does not like to go up 2 feet and around corners to get to the stock airbox. I ran this for 2 years. If you make a fitting, you can scoop up the air and have a ram-air effect. The computer will learn and does not lean out the mixture. Total price was about $16.
2nd bang....free....remove weight bearing items that you don't need. 3 tie down hooks....2 front, 1 back are bolted on. Unless you plan on putting your car back on the ship, they're useless. Also, there's the famous bricks. One inside the glovebox cover, one under the engine transverse mount. Unbolt the 4 bolts where you'd put the jack and it drops out. Exhaust shielding, about 8 pounds of guards and un-needed brackets in the engine compartment, bolts and hooks for rear seat child tether straps (if you don't put in a child seat), front and rear brake backing plates. Blocking plates on the scoop and hood grills. If you feel you must have plates there, replace them with thin fiberglas or something else light. Stock ones are steel. There's enough stuff that can be removed for free. Go looking and you'll find them.
jack
Old 05-27-2003, 12:20 PM   #5
kickin_81
Member#: 16679
2004 Forester XT
If you want the best bang for the buck, I'm going to suggest a CAI (in order of least expensive: PDM, Ganz, Cobb, Injen, Gravel Sports). There are many other beginning grade mods that you can do that are not really expensive. ...such as the Single Point Ground mod. Fuel modifications/upgrades are not really necessary under ~200 horsepower. Once you start, you probably won't stop.
kickin_81 is offline   Reply With Quote
Old 05-27-2003, 01:04 PM   #6
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
I have to concur w/ CAI being an excellent initial "best bang/buck" mod. There is a significant increase of engine noise. This, I like. If you choose a CAI which utilizes the existing intake filter box... a low resistance air filter panel (e.g.: K&N,Amsoil,Perrin), really makes a difference. Also, the '00 model seem particularly prone to running rich... sooty tailpipe.
-Ken
Dr Ken is offline   Reply With Quote
Old 05-27-2003, 10:57 PM   #7
Brento
Member#: 24485
02 RS
buy a used WRX rear sway bar for $40-$45. it will do wonders for your suspension.
edit oops messed the go fast part for the extra weight but hey the rear sway bar will help with the rolls from the added weight.
if you go for the intake tubing don't forget the K&N or amsoil filters. does wonders and still cost less than the CAI total package.
Brento is offline   Reply With Quote
Old 05-27-2003, 11:18 PM   #8
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
My car runs stupid rich with an intake. So much it spits flames out my catless exhaust and works with an 80 shot of nitrous. Don't worry about running lean.
Best bang for the buck mod I ever bought was a whiteline adjustable rear sway bar. I know what you're thinking, it's just a bar, I must be exaggerating or placebo effect or something. I thought the same thing before I got mine. Honestly, it feels like a whole new car.
jasona is offline   Reply With Quote
Old 05-28-2003, 12:46 AM   #9
TheDonPerignon
Member#: 30299
jack
Alot of these havent been mentioned in the weight reduction threads...someday i wish they would compile all pieces....
TheDonPerignon is offline   Reply With Quote
Old 05-28-2003, 12:55 AM   #10
joefocker20
Member#: 13745
2015 STI
I made the suggestion of having a weight reduction sticky, but I guess it isn't appealing.. I have a goal of making my car weigh around 2500lbs, and I believe its possible once I can get the balls to start stripping my car.. Right now, my only weight reduction mods so far are LW crank pulley, a 13lb flywheel on order, a 13lb battery, stripped trunk, tiedowns removed, glove box weight removed, and a few other minute items removed. Get some lw rims, inverted suspension, race seats, steering wheel, remove the airbag system, remove the AC, ditch the PS and get a manual quickrack, get rid of the rear seat and all hardware, replace bumper beams with JDM, replace hood and trunk with cf units w/o a spoiler, remove the sound deadening, remove the exhaust shielding, and find other odds and ends and I think removing 400lbs wouldn't be too hard.. It would require alot of labor though..
Old 05-28-2003, 07:03 PM   #11
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
no kidding on the glovebox "brick" thing weighed 2x as much as what I had in the compartment...Now for under the engine? the transverse mount? what?
I also pulled the rear hook and vent panels in the engine, combined with the stock air assembly its a bit of weight, still able to lift with one hand though...perhaps 5lbs max...
I'll get the new sub box cut and keep it light weight, put holes in the new floor and such...
Can anyone point me to the weight reduction thread?
-- AcquaCow
Old 05-28-2003, 07:05 PM   #12
joefocker20
Member#: 13745
2015 STI
Search for my name and weight reduction and there was a pretty lengthy thread way back..
Old 05-29-2003, 12:52 PM   #13
dingo dave
Member#: 33177
2000 Impreza RS coup
white
I live in texas and i've been told that CAIs don't offer much in the summer time in hot climates. True?
Also, what does it mean when a car "runs rich"?
dingo dave is offline   Reply With Quote
Old 05-29-2003, 04:31 PM   #14
nySulli
Member#: 32617
2008 STi
running rich is relating to the air/fuel ratio, rich is to much gas, lean is to little
Old 05-29-2003, 05:12 PM   #15
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
nah... still works...
yeah rich means too much fuel... more fuel = less power (not less than no intake...) less fuel = detonation = bad... you gotta find the sweet spot known as stoich...
DanzBorin is offline   Reply With Quote
Old 05-29-2003, 06:45 PM   #16
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
#1 underdrive
#2 cobb CAI .. or ganz flow
#3 brand X cat back
Old 05-29-2003, 07:32 PM   #17
DoinkMobb
Member#: 3787
-- AcquaCow
Do a search on "weight reduction" and you'll find a couple of good threads.
There's free weight reduction - taking stuff out of your car that you don't need.
...and there's dollar intensive weight reduction - carbon fiber or aluminum hoods/trunk lids, featherweight rims, racing seats.
A home made intake, pullies and weight reduction will make a noticeable difference, for little $$$ output.
DoinkMobb is offline   Reply With Quote
Old 05-29-2003, 08:11 PM   #18
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
DIY CAI indeed, however I'm having problems tracking down 2-3" tubing...I'm about ready to get some PVC, rubber joints and some hose clamps....sanford & son style....
-- Cow
Old 05-30-2003, 10:27 AM   #19
doobie
Member#: 6570
04 WRXSW
9.3 TRB0 CNV
Any muffler shop can bend a 3" piece of aluminized steel for an intake. Get a 3" to 2.5" adapter at any performance shop, paint you pipe and your in business for about $20.- Just as good as a ganzflow for $100.- less. And it does look good.
I just did mine.
Steve
doobie is offline   Reply With Quote
Old 05-30-2003, 10:35 AM   #20
joefocker20
Member#: 13745
2015 STI
If you would have taken the time to search, you would know that PVC shouldn't be used underhood..
Old 05-30-2003, 11:20 AM   #21
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
Default tubing...
Go to Jegs.com for mandrel bent tubing. They have all different diameters, bends, and lengths - fairly cheap.
I made my intake with 3" OD AL tubing I bought from a local machine shop, but mine is all straight. I kept my "torque box" but have the 3" tubing from fender- to MAF - to inside the "torque box" (ie. full 3" cold air intake).
After driving I can open my hood and the intake tubing is COLD!!
made a very noticeable difference in power - it does have a dip around 4500rpm - but that's the tradeoff for paying only $60 for a true 3" CAI. pulls hard up on top!
maybe I'll get a "real" intake someday, but I think my money would be best spent elsewhere right now.... clutch/flywheel, cams, bumper beams, lightweight wheels, Cobb reflash (if it ever comes out)
-chad
Farfrumwork is offline   Reply With Quote
Best bang for the buck headers for 2005 STI WR05STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 09-20-2006 09:32 AM
best bang of the buck alpine? qax Car Audio, Video & Security 16 11-08-2005 12:02 AM
Need help ranking bang 4 the buck enginemods on 2.2L ashwinearl Normally Aspirated Powertrain 7 12-04-2004 05:01 PM
best bang 4 the buck mod mxspl807 Bay Area Impreza Club Forum -- BAIC 10 10-06-2004 06:20 PM
What are some good bang-for-the-buck mods for my00? Fusion Technical Forum Archive 12 07-22-2000 08:57 PM
