Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 05-27-2003, 10:04 AM   #1
Member#: 9689
1998 Legacy GT
Question Tire Replacement?
My GF decided that it was time to replace her tires....since two of them have NO TREAD at all!!!
Anyway it's a '00 Outback Sedan with OEM Firestone Wilderness Tires (225/60/r16). Looking at Tire Rack best sellers include the Kumho Ecsta HP4 716's and the Dunlop Sport A2's. I have the Dunlop's on my 98 GT and they seem to be wearing rather quickly.
Anyone here running the Kumho's that can comment? If not what did you replace the OEM with? Please keep in mind that the driver will not be driving spiritedly like most of us here and price is always a factor.
Thanks for your help!
Oquipah is offline   Reply With Quote
Old 06-03-2003, 11:32 PM   #2
Dave G
Member#: 4738
2006 Baja Turbo
I have a 2002 Legacy Outback, with the same size tires, and I live just a little bit east of you in Chester County PA. I have the original equipment tires, plus I use Dunlop Wintersport M2 tires for the winter. I know that may not be an answer to your question right now, but I wanted to give you my thoughts.
My wife drives the Outback, and she also does not drive aggressively (unlike most of us on these boards). She was very uncomfortable in the Outback with the original tires (Bridgestone RE92) in snow, so I ordered the winter tires. They are great in the snow. The winter tires were only $100 each at TireRack.
Here is what you may be more interested in:
I also have a '97 Legacy GT, and I do not put winter tires on it. After my third set of RE92's, I wanted something that was good in both summer AND winter.
I bought Dunlop SP5000 tires (the size is 205-55-16, but that doesn't matter). I grew up in Buffalo NY, and I've driven in a lot of snow all over the country. These SP5000 tires are the best all-season tires I've ever driven on in the snow. They are certainly no match for dedicated winter tires, but for an all-season tire, I have to say they were terrific in snow. They are terrific in rain as well. The dry pavement grip is great too. The only downside is that they have soft sidewalls, so for an aggressive driver, they take some getting used to. I initially hated the soft feel of them in the summer. I grew to really like them in the winter, and I am now used to them, so I am back to driving aggressively with confidence; I just had to adapt to them.
I've had the SP5000's for almost two years, and I now have over 32,000 miles on them, and they probably have another 10,000 miles to go. The max pressure listed on the sidewall is 51psi, and I can tell you that you'll need at least 45psi to get them to feel right, and to avoid underinflated wear patterns. This is all due to the very soft sidewalls (which give a softer ride than the RE92's).
If you only want one set of tires, I cannot recommend the Dunlop SP5000 highly enough.
I checked TireRack.com minutes ago, and size 225-60-16 (WR rated) is available at $91 each.
(Oddly enough, the lower speed rated HR version is priced at $111).
Good luck.
Dave G
For those who want to flame me on the tire pressure issue noted above, don't bother. I know what I know, and the whole story was chronicled on AudiWorld, and I got confirmation from a Dunlop engineer. The tire pressures with SP5000 tires have to be far higher than what you are used to. Its that simple.
Dave G is offline   Reply With Quote
Old 06-12-2003, 07:50 AM   #3
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
I have to weigh in on the SP5000s.
THEY ARE THE BEST ALLSEASONS I've ever owned. Probably one of the top 5 tires including summer tires I've owned.
I'll put it this way....
Last year during the 48hrs of Tri-state we drove from Albany-> Buffalo in nearly 6-10" of snow on the NYS Thruway. I was running 245-45-16s on my SVX and didn't have a whole lot of trouble in the snow.
48hrs. of Tristate II
48hrs of Tristate I
Then I had them on the SVX @ 2 days on the track at VIR and a warm day at Limerock Park with the BMW Club, passed an M5, and pulled on the M Coupe. Tires never ever gave out on me!
Paisan is offline   Reply With Quote
Toe-In & Tire Wear, Warranty Tire Replacement, HELP! duck_man General Community 4 08-24-2005 10:34 AM
Need to replace a blistered tire... (tread depth/single tire replacement question) reaubideux Tire & Wheel 3 11-05-2004 01:28 PM
Flat tire, replace all tires? whitet777 Newbies & FAQs 13 06-25-2002 09:04 AM
Where do you go to get tires replaced? xstar Brakes, Steering & Suspension 5 10-11-2001 11:59 AM
Problems with scratched stock WRX rims after tire replacement??? D-WRX Brakes, Steering & Suspension 7 03-29-2001 11:43 AM
