Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 05-27-2003, 10:13 AM   #1
Member#: 35301
2002 Impreza WRX
Question noise coming from left front suspension
I've been hearing some noise coming from my left front suspension. Everytime I brake and turn into a parking spot or my drive way I hear this clanking sound. I don't know if its my coil springs or my calipers.
Anybody have an idea?
mugsy is offline   Reply With Quote
Old 05-27-2003, 02:57 PM   #2
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default CV joint
Sounds like a Constant Velocity (CV) Joint could be bad. Other things to consider, which come straight from a Haynes Manual could be:
Lack of lubrication at the ball joints and tie rod ends
Damaged strut mounting
Worn Control Arm bushings or tie-rod ends
Loose Anti-roll bar (swaybar)
Loose wheel lug nuts (lol, let's not hope)
Loose suspension bolts (could be one of many)
ImprezaVA is offline   Reply With Quote
Old 05-27-2003, 05:58 PM   #3
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
My first guess would be the three most common (mentioned above)
1. Loose/bent sway bar mount
2. Bad CV-Joint
3. Loose strut top bolt
Old 05-28-2003, 04:55 AM   #4
Member#: 14909
Yeah, definitely check that strut top bolt (the one in the middle under the little plastic/rubber cap). I've gotten that sound before and found it to be that.
If you have aftermarket springs, they could just not be seated properly, too so they shift and clunk when you turn...
JSiwek is offline   Reply With Quote
Noise coming from Left Rear Wheel MykeM Brakes, Steering & Suspension 8 05-08-2010 11:27 AM
Weird hissing noise coming from left side of the engine on WOT bnr34rb26dett Newbies & FAQs 7 08-10-2009 12:24 PM
strange grinding noise coming from my rear suspension on both sides when i make turns db97 Service & Maintenance 0 06-23-2006 09:18 PM
Chirpping noise coming from right front tire? ImprezedRS Brakes, Steering & Suspension 1 08-21-2001 01:44 PM
mystery noises coming from the front Flashboy Normally Aspirated Powertrain 5 08-11-2001 06:50 AM
