Old 05-27-2003, 12:43 PM   #1
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
Default No Tweeter Brackets in STi!
Anybody know if they can be ordered? Does anyone have another way to mount tweets? I tried using the bracket from my '00RS and they are a different shape. Any reccomendations or part numbers would be greatly appreciated. (Also, you need the little square inserts to mount the door speakers). Thanks much.
Christian
Chin is offline   Reply With Quote
Old 05-27-2003, 01:44 PM   #2
elsanto
Member#: 34832
1989 M3
I'd say avoid the hassle of dealing with subaru parts service and make your own out of some plumbing strapping.. Really cheap, and would do what you need just fine (i take it your mounting in the factory location? there should be 2 holes, the bracket is just that, a bracket that goes between the 2 kinda looks like __/--\__ something like that and the tweeter mounts in the center of the /--\ . this way you can adjust it a little although the factory cutout in the door panel is rather limiting..
if your tweeter has a screw hole in the back then you can utilize that, if not i've had good sucess with hot glue, and zip ties.. just make sure to put the glue on the bracket first, so it cools a second before you ptu the tweeter on..
elsanto is offline   Reply With Quote
Old 05-27-2003, 02:51 PM   #3
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
Thanks, Elsanto. I went down to the dealership over lunch and they don't even sell a bracket. Apparently, the bracket is integrated into the factory tweeters, therefore, not available without buying the tweeters. I guess your idea is the best for this situation. Off to Home Depot...
Christian
Old 05-27-2003, 02:57 PM   #4
de Rookie
Member#: 27636
I haz 183
IggPoints
I'm not sure how the STi door panel looks, but I did a flush mounting in my '92 Accord with the brackets that came with the tweeters. All I had to do was measure and cut a small circle out for the kit on mount into. I have Polk component speakers and they came with everything to do the flush mount installation. I placed it just in front of the door handles.
Mike
http://kanedasrealm.net
de Rookie is offline   Reply With Quote
Old 05-27-2003, 05:20 PM   #5
Charge
Member#: 3313
Mike
While I'm sure he could do that, he probably would rather keep the "stock" look. It'd obviously be much cleaner unless he does some serious custom work to make the grill that comes with the tweeters match his interior color. Unless you are creating a truly balls-to-the-wall high-end car stereo system, the stock location is more than adequate.
I'd also say fabricating your own bracket is your best route.
Charge is offline   Reply With Quote
Old 05-27-2003, 10:33 PM   #6
tdxflex
Member#: 13634
Originally posted by elsanto
I'd say avoid the hassle of dealing with subaru parts service and make your own out of some plumbing strapping.. Really cheap ...
plumbing strap (sometimes called backstraps) would be the way to go, that's basically what the stock mounting bracket is anyways. you can also use good velcro to hold the tweeter in place, probably a better alternative if you don't have a glue gun. double sided tape could work also, but i prefer velcro because it's removable.
tdxflex is offline   Reply With Quote
Old 05-27-2003, 10:53 PM   #7
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Might have to custom fab something. I'll let you know in a couple days when I tackle my install.
dsmperformance is offline   Reply With Quote
Old 05-28-2003, 09:48 AM   #8
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
A solution was found! I went to Menards and found a 1" X 0.032" X 12" piece of metal. After a few trial and error attempts, I made a bracket that works great. It looks a bit like this: _/---\_ (a little crude, but you get the idea). I will try to get some dimensions of the ones I made.
Christian
No cd player in sti, help. . . imlachg1 Car Audio, Video & Security 2 05-11-2005 04:39 PM
Custom Tweeter Brackets w/Aftermarket Tweeters WRXerist Car Audio, Video & Security 0 05-19-2004 04:28 PM
No A/C In STI (according to Impreza lit.) akm3 STi Forum Archive 17 04-18-2003 04:09 PM
No tweeter brackets! TwoPointFive Car Audio, Video & Security 1 03-23-2000 06:33 AM
