Old 05-27-2003, 12:47 PM   #1
onesillyracer2k2
Member#: 19338
05 Legacy GT
GRP
Default ecutek possible problem?
Hey everyone,
Back in february, i had shiv tune my car with the ecutek for stage 1. It dynoed at 229hp and 238 lbs of torque and the air/fuel was tuned perfectly. This past saturday i dynoed my car without any mods since the last dyno, and it only put out 221hp and 228 lbs of torque and the car was so rich that the line graph basically was off of the dyno sheet. Now the weather conditions were much different,temps in the 60s and it was rainy but is it possible my car was tuned for the cold weather and will run like ass until it turns cold again? Should i send the ecu back to shiv to possibly reflash it again or am i just worrying too much?
onesillyracer2k2 is offline   Reply With Quote
Old 05-28-2003, 12:21 PM   #2
ryjerk
Member#: 16393
2003 WRX / 03 EVO8
02 Aprilia RSVmille
It sounds like your ECU is compensating for temp as normal. I would use the Live User 'adjustability' feature the adjust the trim levels (if you have that option/delta dash). Then you can get it reflashed with the up-dated values. It dosen't seem that your losing 'too' much power for me to think there is a problem.
Ryan
ryjerk is offline   Reply With Quote
Old 05-28-2003, 12:40 PM   #3
teiva-boy
Member#: 22825
Colder weather will almost always offer better performance. Colder air is denser plain and simple.
The difference in power levels is so negligible that I wouldn't worry at all about anything. Infact you could attribute the changes to not only weather, but also dyno correction factors as well.
teiva-boy is offline   Reply With Quote
Old 05-28-2003, 02:03 PM   #4
NSR500
Member#: 19576
2002 Subaru WRX
Platinum Silver
Did you reset your ECU during your latest Dyno session? Couldn't hurt to reset it and have it learn for your current weather conditions.
NSR500 is offline   Reply With Quote
Old 05-28-2003, 02:07 PM   #5
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
I notice a fairly major varience in performance between the Florida cooler/less humid mornings and the much warmer/humid afternoons.
I have trouble reaching ~15psi in the afternoons but when the temps drop I can easily hit ~16psi. This is al using the FBC with an AccessECU Stage II and supporting mods.
lstepnio is offline   Reply With Quote
Old 05-29-2003, 10:25 AM   #6
MastroWRX
Vendor
Member#: 12262
The Ecutek job will compensate for external inputs such as temp, altitude, or more typical, a cheap tank of gas or whatever.
Was it the same dyno?
It's tough to compare numbers from different dynos as well.
We've rechecked early Ecutek jobs and they are very stable. It can't really "change".
Can't comment on Access, not sure how they do things.
Just some ideas....
Bill
MastroWRX is offline   Reply With Quote
Old 05-31-2003, 04:57 AM   #7
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
It was the same dyno, they actually had his old graph and you can see that he lost some power pretty much throughout the revband. It was alot warmer and it was raining on/off all day though.
PaulRex is offline   Reply With Quote
05 ecutek ecu problem thisisthenewsic Southern California Impreza Club Forum -- SCIC 2 08-19-2008 03:16 PM
EcuTEK reflash problems Jim Payne Commercial ECU Reflashes 1 09-16-2006 01:24 PM
ecutek boost problem dgp2003wrx Engine Management & Tuning 6 01-10-2005 02:24 PM
ecutek boost problem dgp2003wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-08-2005 02:54 AM
vf34/Vishnu Ecutek Reflash Problem Tuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-19-2004 02:48 AM
