Old 04-05-2001, 03:53 PM   #1
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Exclamation WRX Check Engine Light Log
ONLY people who have had the problem may reply and post their history of:
* transmission (auto, manual)
* what date/mileage it went on/off
* what code was retrieved by the dealer (e.g. P1443)
* name of dealer
* what action the dealer took (e.g. ordered O2 sensor, drain solenoid)
If you reply with a question, or something unrelated to your CE problem, I will edit delete your reply and send you a rude PM.
Reminder: DO NOT reset it yourself. Take it to the dealer, ask them what code they pulled.
ANZAC_1915 is offline   Reply With Quote
Old 04-05-2001, 04:04 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Post
*Manual trans
*On 167 / Off (w/o reset) ~300 (the day I filled it up after the factory tank)
* I didn't get the code, since I picked it up late, but it was listed as an Evap System problem.
*Livermore Subaru
*Dealer checked and reset ECU since the CE light was already off when I gave it to them.
Concillian is offline   Reply With Quote
Old 04-05-2001, 04:58 PM   #3
Blugin
Member#: 5270
2008 EvoX MR
Red
Thumbs down
*Manual
*on ~300/off ~320 on ~900/off ~950
*code 1: p0340 (camshaft sensor??)
*code 2: p1443 (unknown code)- pulled codes
myself but left them in memory for proof
*Westway Imports
*didn't go to the dealer
[This message has been edited by Blugin (edited April 05, 2001).]
Blugin is offline   Reply With Quote
Old 04-05-2001, 05:17 PM   #4
KungFuGrip
Member#: 5114
Post
*Manual trans
*On 1399 / Off (w/o reset) after 3-4 trips around town.
* Code: P0303
*Morries Subaru
*Dealer checked and reset ECU since the CE light was already off when I gave it to them. Said also that they would put a call in to SOA and get to the source of the trouble.
KungFuGrip is offline   Reply With Quote
Old 04-05-2001, 06:55 PM   #5
JAH
Member#: 3923
02 WRX
Post
5spd
Dealer=Van Bortel
CE light went on around 200-300 miles. Dealer on 3/21, codes:
P1443 (vent control selenoid)
P0303 (misfire in #3)
I had filled the tank with the engine running 1 day before the light came on.
CE light again on 3/22. Dealer again on 3/23 at 725 miles. This time P0303. The dealer contacted SOA and was told to swap the injectors in cylinders 1 and 3. No problem since then, currently at 1800 miles.
Both P0303 codes occured at idle. I was sitting in a parking lot in both cases.
-john
JAH is offline   Reply With Quote
Old 04-05-2001, 07:40 PM   #6
jjameson
Member#: 4986
2002 BlzYel JDMSTiv7
GRP 08 FXT
Post
*Manual Trans
*4/5/01 ~270mi On/ ~310 Off when I filled up with gas after dealer filled tank. Light came on during alarm install. Don't know all the details of when it came on as it wasn't in my posession.
*Dealer has not checked
*picked up at Colonial in Danbury, CT service will be at Tri-State in Webster, Ma
*N/A Dealer has not seen car yet.
jjameson is offline   Reply With Quote
Old 04-05-2001, 09:03 PM   #7
NYCPimP
Member#: 4282
Post
Transmission: Manual
Date: Wed, April 5th. On-1385 miles, Off-1420 miles (w/o reset)
Code: P0303 - Code for Misfire
Dealer: Colonial Subaru - Danbury, CT (this is not the dealer I am bringing it to for service though)
Action: Cleared Code and Road Tested - Everything checked out fine
Well my CE light came on at 1385 miles while accelerating (in first gear), and then turned off (w/o reset) at 1420 miles when I started up the car.
[This message has been edited by NYCPimP (edited April 06, 2001).]
NYCPimP is offline   Reply With Quote
Old 04-05-2001, 09:04 PM   #8
Koua Jones
Member#: 3806
2010 MX-5 Touring
Post
* manual
* 3/21 52 miles
* P1446
* Pipkin's Motors (GA dealership)
* (FL dealership) ordered vent control solenoid
Koua Jones is offline   Reply With Quote
Old 04-05-2001, 09:23 PM   #9
hsolo
Member#: 5483
Pearl Black
Post
Transmission = manual
Date / Mileage on = 03/16/01 100 miles
Date / Mileage off = 03/18/01 140 miles (w/o reset
Code = Called dealer but didn't take it in because light went off. Will retrieve code at first service.
Dealer = Frank's Subaru Irvine
Action = n/a
hsolo is offline   Reply With Quote
Old 04-06-2001, 06:38 AM   #10
MRT
Member#: 3897
2004 STI
WR Blue
Post
*Manual
*First CEL at 50 miles (reset my self)
Second CEL at 70 miles (took to a dealer near my office)
Third CEL at approx. 350 miles (took to the dealer I purchased the car from)
*PO131 at 70 miles; PO171 at 350miles
*Burke Motor Group, Cape May Ct House NJ
*PO131 - dealer didn't find any thing and reset the light
PO171 - replaced the front O2 sensor, dealer still has car b/c "performance is not what it is supposed to be"
The car has been at the dealer for almost 3 weeks.
MRT is offline   Reply With Quote
Old 04-06-2001, 06:55 AM   #11
orbit03
Member#: 2300
2002 Impreza WRX
Banana Pudding
Post
-5spd
-Came on at 97miles went out at 140miles
-Code: P1443 (retrieved a couple of days after it went out)
-Took to New Motors, Erie, PA
-Retrieved code, followed shop manual instructions, didn't find anything, cleared code, sent me on my way.
Also, a regional rep was at the dealer that day and he followed/helped through the whole process. I know the mechanic faxed a sheet describing the problem to SOA.
orbit03 is offline   Reply With Quote
Old 04-06-2001, 08:41 AM   #12
j00z
Member#: 3801
'02 WRX
WR Blue
Post
* trans: manual
* date: 04/03/01
* mileage: ~2200 miles
* code: P1443
* dealer: Eger Subaru, PA
* action: reset error codes, checked hoses, told me to call back if it happens again.
the car has been running fine even with CEL. so i'm fine with the action taken. i won't be too excited if it happens again...
j00z is offline   Reply With Quote
Old 04-06-2001, 09:00 AM   #13
Aquavir
Member#: 4428
2005 JeepRubicon LWB
Post
Trans: Manual (EDIT: sorry I forgot to put this down)
Date: Middle of night on drive home from pickin up car in AL (March 20th).
Miles: About 400. After second fill-up.
Resolution: Tightened cap and light went off after a few miles and several starts periodically while I slept at a rest area (Had to start it to heat up cabin every hour or so for a few hours). Will have code checked at next service. (EDIT: Actually I might just wait till I get it tuned...if I remember. I'm pretty sure it was a gas cap problem.)
Dealer: Madison Square Imports, Huntsville, AL. Will have it serviced while living in MD at Heritage Motors, Owings Mills, MD.
Sorry about not having a code, but at least maybe this will help you get a count of the number of CE problems.
[This message has been edited by Aquavir (edited May 02, 2001).]
Aquavir is offline   Reply With Quote
Old 04-06-2001, 09:07 AM   #14
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
trans: manual
ON: 1336 miles
OFF: 1476 miles
code : P1443 (what a surprise)
dealer: Carter has ordered the valve.
[This message has been edited by Glenn Wallace (edited April 09, 2001).]
Old 04-06-2001, 10:06 AM   #15
wrxclnt
Member#: 5029
2002 WRX Wagon
WRBlue
Post
* manual
* 120 miles
* P0303 - misfire cylinder 3
* White Bear Subaru
* Tested with computer and listened for misfire. Reset the light. Hasn't come back on yet. I am at 680 miles.
wrxclnt is offline   Reply With Quote
Old 04-06-2001, 10:52 AM   #16
LttLDGN
Member#: 5478
Cool
*manual
*602 miles on...right before 2nd fill up
*off some 20 miles later(drive to dealer)
*fitzgerald subaru(white flint, MD).great dealership btw...
*they couldn't find problem, called SOA, and reset computer, no problems since
LttLDGN is offline   Reply With Quote
Old 04-06-2001, 11:01 AM   #17
FUBAR
Member#: 2132
11 STi Sdn
Sparkling Slvr Met
Post
* transmission - manual
* mileage it went on - 1466
* Error code was retrieved by the dealer - P1443
* Puyallup Subaru
* what action the dealer took - water found in solenoid, tech cleaned water out and have had no CE lights since.
FUBAR is offline   Reply With Quote
Old 04-06-2001, 01:25 PM   #18
MRT
Member#: 3897
2004 STI
WR Blue
Post
Update from my dealer:
The dealership brought in two techs from Subaru's tech facility in Morestown to look into the rough idling and poor acceleration. (The CEL did not come back on after the new O2 sensor went in but performance was still lacking) They started switching out parts to see if they identify the cause - which turned out to be the Fuel Pressure Regulator. One of the techs will be running to Cherry Hill on Monday to pick up a new one.
Old 04-06-2001, 01:43 PM   #19
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Post
*Manual
*1100 on
*Evap code, no number yet
*Don Beyer Subaru, Alexandria, VA
*Reset computer and are periodically test driving the car with tool to diagnose the problem.
I had poor idle, ie rough, hesitation, difficulty starting, egg smells.
motoxphil is offline   Reply With Quote
Old 04-06-2001, 03:22 PM   #20
WRoX
Member#: 5061
2003 VW Golf TDI
2007 Honda Fit
Post
Manual, On @ 450 miles, went off at 550.
Returned at 800, now at Bell Subaru, Rahway, NJ for the CE and a gas tank replacement.
Haven't got the codes yet.. Will post when I get the car back.
WRoX is offline   Reply With Quote
Old 04-06-2001, 04:01 PM   #21
wregex
Member#: 4345
2002 Impreza WRX
B. Yellow
Post
[*]manual[*]480 miles[*]P1443[*]Melody's Kirkland Subaru; Kirkland, WA[*]Replace vent valve (at Carter Subaru)
wregex is offline   Reply With Quote
Old 04-06-2001, 04:25 PM   #22
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
Post
Manual
70 - 450 - 670 - 850 - 970 miles
didn't take it to the dealer yet.
hard enough making appointment when thats your only vehicle and I don't feel like leaving them with my $$$ stereo.
blkwag is offline   Reply With Quote
Old 04-07-2001, 07:03 AM   #23
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
ttt
Old 04-07-2001, 07:54 AM   #24
Tuning Factory Inc.
Vendor
Member#: 3600
Post
* Manual
* 2170-ish miles
* cleared code myself
* has not returned yet and car driving normally. Sorry but it was friday and didn't want to wait till next week just to grab the code. We'll see if it returns. If so I'll take her in.
Tuning Factory Inc. is offline   Reply With Quote
Old 04-08-2001, 12:16 AM   #25
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
Post
transmission: manual
date: 04/08/2001
mileage: 1350
code: none yet
hopefully deal with a tech on monday.
Akirasoft is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 10:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 05:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 04:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 11:45 AM
