Old 01-20-2003, 06:54 PM   #301
eyehate
Member#: 10223
A new one for me added on to my old one.
* manual
* 34000
* P0153 The PCM has determined that the response time for oxygen sensor 1 in bank two was too slow during testing
* autozone
* i have yet to take it to the dealer.
again... any ideas??
eyehate is offline   Reply With Quote
Old 01-21-2003, 05:47 AM   #302
weeeee
Member#: 30420
2003 WRX
Unhappy CE light
Manual Tran.
1025 Mi.
Came on when I turned the car on this morning. Stayed on for the 30mi drive home from work. Gas cap is tight.
weeeee is offline   Reply With Quote
Old 02-06-2003, 01:59 AM   #303
bb_12d
Member#: 31273
2003 WRX Wagon
* Manual 2003 WRX Wagon
* 350miles; 12/20/2002
* P1443 (city driving, level ground)
* Carlsen
* Vent hose for evap system was realigned
Code came up again 12/23
*750miles
* Dealer cleared; no other action
Code came up again 1/5/2003
*appox 1500miles
*Found moisture contamination in evap system; installed new drain valve; rerouted two vacuum hoses;
Code came up again along with P0447 1/20/03
*appox 4000 miles (going down a hill coasting)
*currently in shop; possibly bad fuel valve? (I wasn't listening).
bb_12d is offline   Reply With Quote
Old 02-08-2003, 12:59 AM   #304
weeeee
Member#: 30420
2003 WRX
Question CEL updated
Manual Tran.
1025 Mi.
P0480
Came on when I turned the car on. Stayed on for the 30mi drive home from work. Gas cap is tight
Went to Stolhman who pulled the code for me. They told me the code is for the gas cap. I was a little bit suspicious because I have made it a point to tighten the crap out of it. I looked up the actual code P0480 and it turns out to be the code for Fan 1 relay low input.
So, today (2000 miles) the light comes on again with the same symptoms. I pull open the hood and push down on my relays. The one for Fan 1 had some play and I was able to push it down a little bit. Turned engine back on and CEL is now off.
Strange that Stohlman BS'd me with the engine code.
Old 02-08-2003, 03:21 AM   #305
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
Default Incompetance/Apathy
Sadly, your experience at Stohlman seems fairly typical. It is getting to the point where we must all educate ourselves because the average tech doesn't know or doesn't care (or both).
sajohnson is offline   Reply With Quote
Old 03-09-2003, 03:54 PM   #306
BlueDemon
Member#: 10173
2005 WRX STi
Default Unknown Code!
transmission: manual
what date/mileage: March 9th/approx. 28,3xx miles
what code: p3110 (Unknown Code)
dealer: Pulled myself, scanner did not recognize the code
Cleared code myself
I drove 215 miles on a full tank of gas with Turbo 108 Octane Booster in the tank, while using Amaco 93. On the way home I filled up with 93 octane at 1/4 tank. No Octane Booster was added.
Code came on while cruising in 4th at approx. 3-4K RPM.
Anyone know what the Code is?
BlueDemon is offline   Reply With Quote
Old 04-01-2003, 01:13 AM   #307
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
5 spd
18,200 miles
village subaru acton, ma
lights been on for 500 miles
DTC PO448 - EVAPORATIVE EMISSION CONTROL SYSTEM VENT CONTROL HIGH INPUT
Took it in and they told me it was the "gas cap code". Why do they feel the need to lie? They cleared it, well see if it comes back.
santofontana is offline   Reply With Quote
Old 05-02-2003, 12:05 PM   #308
Wheeldog
Member#: 19848
2002 WRX Wagon
Default First CEL
Transmission: Manual
Mileage: CEL on @21,440 miles, CEL went off @ around 21,550
Code: P0301 - misfire in cylinder #1
Dealer: Mitchell Subaru, Canton, CT
Maintenance Action: Recorded the freeze-frame (is that the right term?) data. Cleared ECU memory. Will call Subaru Tech line to inquire about known issues.
Wheeldog is offline   Reply With Quote
Old 06-05-2003, 03:25 AM   #309
k2snow
Member#: 10449
03 Legacy BH
Default CEL code 1443
I got another CEL for the third time. How is subaru going to remedy this situation? What should i do?
I took it to the dealership they put a call into their specialist. any info would be helpful
Thanks
PJ
k2snow is offline   Reply With Quote
Old 07-15-2003, 05:50 PM   #310
midnight
Member#: 12074
2002 WRX sedan
Midnight Black Pearl
Default P0457 and TSB 09-36-03
* 2002 WRX automatic transmission
* approx. 16800 miles (27000 kms)
* P0457
* mechanic tightened gas cap, test drove car, cleared code
Came up again in the same week:
* approx. 16840 miles (27100 kms)
* P0457
* tightened exhaust hose from TSB 09-36-03
Immediately after the CEL came on I noticed a significant decrease in the car's performance. Later the mechanic said that this is because the car goes into "safe mode" with that particular code.
The first CEL happened only a few days after the same garage performed the work on TSB 09-36-03 "Fuel Smell in Cold Weather". In the end it turned out that they had incorrectly installed the hose mentioned in the bulletin and this was triggering the P0457. Wish they had checked that the first time instead of telling me I wasn't tightening the gas cap properly!
For more info on that TSB, check out this topic:
http://forums.nasioc.com/forums/show...hreadid=131755
midnight is offline   Reply With Quote
Old 07-15-2003, 09:16 PM   #311
rss600
Member#: 20436
2012 WRX
Trans: 5 MT
Miles: 37,857
Date: 7/11/03
Code: P0302 (Misfire in cylinder 2)
First CEL for the car purchased 10/01.
I let Auto Zone pull the code for me since they do it for free.
It was about 85 degrees and fairly humid when it went on. The car displayed no unusual behavior. I'm going to pull the plugs this weekend for replacement so I'll see what #2 looks like and determine if further investigation is needed.
My only engine mods are the intake silencer removal and the 3/16" mod.
I'm still over this car.
rss600 is offline   Reply With Quote
Old 07-27-2003, 08:36 PM   #312
bmtbandit
Member#: 40575
2002 WRX Wagon
*P0102 - Mass Air Flow Sensor Low Input
*TXS Stage 2
*Hyper Ground
*PDE Uppipe
*Took to dealer - Reported Bad Mass Air Flow Sensor
Replaced the sensor problem remained
*Turned out to be a loose screw connecting the Utec to the factory ECU
bmtbandit is offline   Reply With Quote
Old 08-02-2003, 10:36 PM   #313
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
* (Manual)
* this is like the (7th time)
* what code was retrieved by the dealer (P0457)
* name of dealer (Exclusively Subaru Ontario, Ca)
* what action the dealer took (the first time the mechanic tightend the gas cap...etc. Like the third time, they had the ECU shipped to NJ and "reprogramed"....now it came on again. About 800 miles later...I dont want to take it to Exclusively again, but I dont want to drive to Irvine.
drew
Drews_WRX is offline   Reply With Quote
Old 09-25-2003, 10:22 AM   #314
LSFwrx
Member#: 43953
Default CEL twice in 2 weeks
* transmission (auto, manual) - Manual, MY02 WRX
* what date/mileage it went on/off - Went off twice between 23,500 and 23,600 miles
* what code was retrieved by the dealer (e.g. P1443)- P0327, Knock sensor circuit low input.
* name of dealer - Anchor Subaru in RI
* what action the dealer took (e.g. ordered O2 sensor, drain solenoid) Replaced knock sensor and it was covered under warranty.
LSFwrx is offline   Reply With Quote
Old 12-11-2003, 07:46 AM   #315
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
date: 25/11/2003 last, mutliple times b4
mileage: 30000
code: P0340
dealer reset ecu
date: 02/12/2003 last, multiple times b4
mileage: 31000
code: p0420
reset ecu
runner19 is offline   Reply With Quote
Old 02-20-2004, 03:13 PM   #316
SleeperWRX
Member#: 8179
What is P1180 on a WRX? It seems to be a subaru specific code and I can't find what it is.
SleeperWRX is offline   Reply With Quote
Old 03-22-2004, 06:04 PM   #317
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
tranny: manual
date on : 03/18/04
mileage on: 40,500
date off: 03/22/04
mileage off: 40,650
code: P1443
Didn't do anything. CEL went off 30 mins after I had the code pulled
thrasher is offline   Reply With Quote
Old 04-18-2004, 07:57 PM   #318
GotPsi?
Member#: 52176
Have a Nice Day?
date: 4/18/2004, first time
mileage: 31000
code: P1443
Code pulled, reset, has yet to return... dont know what to do about it...
GotPsi? is offline   Reply With Quote
Old 04-18-2004, 08:01 PM   #319
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Was your gas cap tight?
If not do not worry.
If so, check your connections to the charcoal canister under the passenger side rear bumper. Check the wiring and the hoses. Also check the the vacuum "t" fitting under the alternator. It is the blue conector. Make sure they are all tight.
Old 04-18-2004, 08:11 PM   #320
GotPsi?
Member#: 52176
I'll check that out... thanks
-Mike
Old 07-06-2004, 09:38 AM   #321
whatishe
Member#: 65711
2004 WRB WRX Wagon
2.5 Hybrid STI Conversion
*2004 WRX Wagon
*200 and 262 Miles when CEL came on
*Gas cap is tight
*Bone stock
*Is it cuz I put 89 octane in it? I can't find any 91, do I have to go to 93?
*Droping at dealer thursday, I just friggen bought this car too.
whatishe is offline   Reply With Quote
Old 07-06-2004, 09:38 AM   #322
whatishe
Member#: 65711
2004 WRB WRX Wagon
I hear a chirping noise from the exhaust too, any idea what that could be?
Old 07-06-2004, 04:13 PM   #323
supermarkus
Member#: 6971
2008 WRX STi
SSM
Don't ever do this, ever. The car NEEDs a minimum of 91 here in the states. This is a stupid and potentially costly error. Lots of people will argue to the contrary, but there is a reason Subaru insists on premium gas in these cars. Unless your car is specifically mapped to use 89, NEVER put that crap in your car.
supermarkus is offline   Reply With Quote
Old 07-06-2004, 04:16 PM   #324
LSFwrx
Member#: 43953
Default agreed
I also agree to never put in 89 octane. When I bought my WRX in 2002, the dealer practically drilled it into my head that NOTHING below 90 octane was acceptable. You may be causing some serious damage if you continue to use a lower grade of gas than recommended!
Old 11-05-2004, 07:33 PM   #325
hype-R-29
Member#: 67431
i had a cel 1443 yesterday in the rain....what should i look for??...2002 wrx just bought it 2 months ago
hype-R-29 is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 10:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 05:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 04:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 11:45 AM
