Old 11-05-2004, 08:46 PM   #326
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
Originally Posted by hYpE-R-29
i had a cel 1443 yesterday in the rain....what should i look for??...2002 wrx just bought it 2 months ago
I had this problem soon after I bought my '02.
If you don't know already, 1442 relates to the 'vent control solenoid'. It is under the right rear fender, close to the rear bumper.
The local dealer initially just reset the ECU.
Second time, they cleaned the connector and packed it with dielectric grease.
Third time, my ECU was sent to NJ to be reflashed.
If I were you, I would have the VIN run through Subaru's computer to see what hs been done on your car previously.
sajohnson is offline   Reply With Quote
Old 11-07-2004, 06:51 PM   #327
Flesher
Member#: 7921
Sliver
They put zip-ties on many of the hose connections on mine in addition to the reflash. No problems since.
Nathan
Flesher is offline   Reply With Quote
Old 12-22-2004, 02:10 PM   #328
DieselClown
Member#: 36135
2005 WRX
* transmission - manual
* 3100 miles, 2 months after purchase (oct 04)
* P301, 303
* Universal Subaru at Northern BLVD in Queens, NY
* replaced coilpack. Problem came back.
DieselClown is offline   Reply With Quote
Old 03-22-2005, 12:50 PM   #329
jhall
Member#: 30787
2003 WRX
* Tran: 5MT (2003 WRX Sedan)
* On: ~ 17590 (while driving uphill in 2nd gear, ~2500 rpm)
* Off: ~17600
* Code: P0303 (cylinder 3 misfire)
* Dealer: Bloomington Subaru (MN)
* Dealer response: checked sparkplugs, fuel injectors, & coils; no problems found - judged to be an ECU problem; dealer recommended a factory reflash. Haven't done this yet.
*Relevant mods: Cobb AP Stage 1, 93 Octane map
jhall is offline   Reply With Quote
Old 09-04-2005, 01:31 AM   #330
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
* Tran: 5MT (2005 WRX Sedan)
* On: ~9,000 miles, following a restart after a short (< 1 min) trip.
* Off: ~9,100 miles, cleared using OBD scan tool (self)
* Code: P0304 (x2), Cylinder 4 misfire
* Dealer: Carlsen Subaru (CA)
* Dealer response: Watching for now; will go to dealer if I see another CEL.
* Notes: I have a vague suspicion that this is due to a bad tank of gas. I went through 10 gallons of ARCO 91 with no problems, then about 3 gallons into a tank of Shell 91 is when the CEL tripped. I've been filling with Shell or Chevron pretty much since getting the car, and filled with the ARCO in a pinch. Could this be due to the ARCO gas?
FromageTheDog is offline   Reply With Quote
Old 09-07-2005, 06:50 PM   #331
Gixxer1K
Member#: 81631
Default Cel P0301, P0302, P0303
* Tran: 5MT (2002 WRX Sedan)
* On: ~45,000 miles
* Code: P0301, PO302, P0303 (1,2,3 misfire)
* Dealer: Greg's Japanese Auto (bellevue,wa)
* Dealer response: Fuel-fouled plugs. Changed plugs. Found coil & igniter assembly #1 to be loose. Tightened assembly and test drove.
Note: This is a Cobb "stage 2" car.
Gixxer1K is offline   Reply With Quote
Old 12-12-2005, 06:07 PM   #332
Wylan
Member#: 97854
2005 Impreza WRX STi
I am perpetually gettin the gas cap loose CEL. I have had it checked and the dealership says that the cap is fine. '05 STi btw
Wylan is offline   Reply With Quote
Old 02-04-2006, 09:11 PM   #333
ghschirtz
Member#: 96670
Post persistent CEL
Total Miles: 37400
CEL's: 6
Codes: P0457 Evaporative system leak (gas tank)
Happens consistently. No change in performance, so I ignored the thing. Tighten the gas cap as much as possible, had tank dropped and sensor replaced, had tank replaced (due to accident) but light still comes on. Last check was at 34,705 and light was back within 500 miles. Tank was holding pressure, all systems go. Light will not go out without a dealer reset.
BTW, 2002 WRX, manual trans, built in 7.01. Running car now on track days in CA, no change in CEL behavior.
ghschirtz is offline   Reply With Quote
Old 02-14-2007, 11:10 PM   #334
willpack_03
Member#: 77683
2003 WRX
PLATINUM SILVER
I bought my car 3 years ago and i was installing led lights on my cluster and i discovered that my check engine light had been on and it had black electrical tape covering the section that prevented me from seeing the light on.
willpack_03 is offline   Reply With Quote
Old 02-14-2007, 11:12 PM   #335
tt_ttf
Member#: 4431
MY07 STi and '06 WRX
Urban Grey & WRC Blue
mmmm - if you bought it from a dealer........
tt_ttf is offline   Reply With Quote
Old 02-25-2007, 12:46 PM   #336
kevjo
Member#: 141795
Default Check engine light
I have a 2004 WRX with 40500 miles.
For the last three weeks my check engine light has been turning on and off. The first time (approx. 40000 mi.) it came on for a few hours after an oil change. The next time (40050 mil) it stayed on for a week (200 mi). It was off for a week and since has turned on and off every day.
The car seems to run normally, but I've noticed the gas mileage drop some. I can't take it to the shop to have the code read without the light on and never seem to make it that far.
Does anyone have a thought on what's causing this?
Thanks
kevjo is offline   Reply With Quote
Old 02-25-2007, 01:58 PM   #337
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
Thanks
I thought some codes were stored in memory even after the CE light goes out.
If not, you might consider buying an inexpensive code reader and keeping it in the car.
Old 02-25-2007, 06:30 PM   #338
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Yes sometimes you can read the stored codes.
If you keep getting the loose gas cap code, replace the gas cap.
blackfang is online now   Reply With Quote
Old 03-23-2007, 02:32 PM   #339
benaru
Member#: 115228
Default P0301, P0303
* 03 WRX
* manual
* 3/22/07 - 80,XXX mi
* P0301, P0303
* Nikki Rattanavong's Pkg Lot Service
* Reset
benaru is offline   Reply With Quote
Old 04-27-2007, 08:14 AM   #340
robby001
Member#: 145625
2002 WRX Stage 2
02 WRX
Manual
4-26-07 / 84,869 Miles
Didn't get code checked reset my self.
Thinking this is since I put a cobb intake and the down pipe on last weekend. I was entering the interstate and was in 5th gear and going 60 and pressed the gas ever so slightly and BAM CEL. Up to this point I have never had a CEL. I am thinking that it is either the mass airflow sensor or the O2 sensor... Will keep an eye on it...
robby001 is offline   Reply With Quote
Old 04-27-2007, 09:39 AM   #341
Mr.Sparkle
Member#: 83725
2015 WRX
03 WRX MT
on 4/26/07/ hasn't gone off yet even with a reset.
Code P0031 (front 02 sensor)
I ordered a new 02 sensor and will be putting it in when it arrives in a few days. Cost $149 shipped.
Mr.Sparkle is offline   Reply With Quote
Old 04-27-2007, 09:40 AM   #342
Mr.Sparkle
Member#: 83725
2015 WRX
Originally Posted by robby001 View Post
02 WRX
Manual
Do you have engine management? If not than I believe you can throw a cel with a DP and no EM.
Old 04-27-2007, 09:07 PM   #343
robby001
Member#: 145625
2002 WRX Stage 2
No I am not running any kind of EM. I was going to but so far have not done it. I have been running it how it is for over a thousand miles before it happend after I reset it I have had no problems yet. Does seem the car has issues with cruise control at lower speeds around 65 compared to 82...
Old 04-29-2007, 08:40 PM   #344
robby001
Member#: 145625
2002 WRX Stage 2
Mr. Sparkle will the Engine Management take care of the CEL or do you think I need to do something else with it?
Old 04-30-2007, 02:07 PM   #345
Mr.Sparkle
Member#: 83725
2015 WRX
I know that Cobbs AP will take care of the CEL from an aftermarket DP, so yes it probably will.
Old 05-01-2007, 12:01 AM   #346
robby001
Member#: 145625
2002 WRX Stage 2
Thanks I will be ordering that ASAP...
Old 05-18-2007, 04:10 PM   #347
Herbie
Member#: 415
2002 WRX Wagon
2002 BMW Z3 3.0i Coupe'
Originally Posted by Herbie View Post
AAAaaargh! Guess who finally threw a CEL this weekend?
Man, I thought I'd dodged the bullet and got a first-allocation WRX that WASN'T going to code-out like many others have.
Well, it finally happened:
~4400Miles
First Allocation WRX Wagon 5MT
Going ~70 light cruising (off boost)
Code: 1443 (yep...)
Blast from the past...
Well I've thrown this code for the second time (first time 7/2001!), and I thought I'd add some new info to the long-ass thread:
~56000Miles
Code: 1443 (yep...)
New twist: I'm 3 months off my extended warranty, so now the local dealership wants to charge $142.50 for the recommended ECU reflash that everyone seems to be getting to fix the little bugger. Started a new thread about the warranty implications of this, but wanted to keep this up to date, as it may start affecting others as they fall off warranty.
Herbie is offline   Reply With Quote
Old 05-18-2007, 06:30 PM   #348
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
I HAVE A 2002 WRX MANUAL...
Code: P0545 Exhaust gas temperature sensor circuit low input
P1544 High exhaust Temperature
I fix this problem by changing the EGT sensor in the uppipe and the Cel goes away...
But I usually get this cell about one or twice a year.. This could not be normal.. THIS IS MY 5 EGT SENSOR since I got my car back in 2003...
Has any body have this problem in their car?
Jose
AXA is offline   Reply With Quote
Old 11-01-2009, 07:42 PM   #349
KarasWRX
Member#: 227862
Angry Wrx 03
* 03 WRX
* manual
* August 2007
* After Jiffy Lube change, they did not change the oil properly
** Cityside Subaru, MA reset the code and refilled the oil.
* January 2009
* TVG sensor on
* Wakefield Subaru, MA reset the code, said the TVG has to be replaced($1000) if the code happens again
* a week later the code appears again
* Replaced the TVG (the code disappeared)
* Oct 2009
* Jiffy Lube Oil change
* The CEL came one a day later. Discovered the radiator leaking(it cost me $500 to replace it - ~$300 part ~$200 labor)
* Wakefield Subaru change O2 sensor ($500)
* a week later the CEL came on again
* Wakefield Subaru replaced Air Flow sensor($500)
** When I asked how come two sensors went out in the same week the answer was that the car has 150 sensors and it is OK. I asked are the sensors bad or there is some other explanation, and the answer was that the sensors have to be replaced before doing other changes. Diagnostics was done through replace and see what happens rather than actual thought process. Jiffy Lube guys said it could be old spark plugs.
* a week later the CEL came on again... I put on the electric tape over the CEL
KarasWRX is offline   Reply With Quote
Old 01-06-2010, 06:03 PM   #350
jimmytt01
Member#: 232905
2008 WRX Sedan
2008 WRX 2.5L Sedan 37,254 miles
* manual
* Date: 1/2/2010 Miles: 37,254
* Didnt get the code number thrown (will get)
* Colonial Subaru in Feasterville, PA
* Replacing tumble generator valves
Jim
jimmytt01 is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 10:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 05:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 04:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 11:45 AM
