Old 06-28-2001, 10:28 AM   #101
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
6/27/01: first time p1443
1st allocation
5340 miles
EDIT: automatic wagon hehe
notes: car still ran fine at 130MPH
Pulled it myself, cleared it myself...
Frankly I'm not going to put my car out of commision for 3-5 days while they send my ECU off to be burned... I'll wait for the inevitable bulletin to come out then they'll have some on hand.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 06-28-2001, 04:08 PM   #102
eaz
Member#: 4403
2002 WRX SportWagon
Sedona Red
Thumbs up
Got my check engine light at 2110 miles went out at 2227 miles.
Brought it to dealer. I believe the code was PO1443. They gave me a loaner car. The ECU has been removed and sent back to Subaru via Fed-Ex to be reprogrammed. I was told it would take 3 business days for it to be sent back to the dealer. I was told that this was the second WRX that they have done this for with no further problems after the re-install.
Maybe this is the definitive cure for the CE Light Problem.
Loaner car is a Legacy GT.
Nice car but it's an automatic. No Fun!
eaz is offline   Reply With Quote
Old 06-30-2001, 02:53 PM   #103
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Default damnit, again!
2nd CE light
1250 miles
I'm sure is probably the same code (1443)
I'm just gonna pull the batterly cable and let it sit to reset the computer. And jack up the car and double check the lines going to the evap box. Sugar said something about adding a clamp, might try that.
djerickd is offline   Reply With Quote
Old 06-30-2001, 06:11 PM   #104
puzurinshushinak
Member#: 3646
Angry
Transmission: Manual
Mileage on/off: 5476 / 5640
Code: P1443
Dealer: Jim Reed Subaru, Nashville, TN (serviced)
Tony Moore Subaru, Decatur, AL
(purchased)
Action: Dealer reset the ECU and informed me
that the gas cap was left loose. Of course, this is sheer nonsense; the problem is a design defect in the ECU, as this thread plainly establishes. Either the dealer did not ship the ECU to Subaru because it does not want to do warranty work (possible -- Jim Reed is known for this), or Subaru has failed to inform all dealers of the defect. Either way, Subaru had better fix this problem, or they face legal action.
puzurinshushinak is offline   Reply With Quote
Old 06-30-2001, 06:21 PM   #105
BruceC
Member#: 4962
2002 WRX Wagon
Sedona Red Pearl
Manual trans.
CEL on at about 680 miles for no apparent reason.
Went off following week (about 200 miles later) for no apparent reason.
Cancelled service appointment at dealer (Suburban Nissan Subaru, Troy, MI)
Hasn't come back on. Car performs well. Currently at 1300 miles.
Will take in for service if it comes back.
BruceC is offline   Reply With Quote
Old 07-02-2001, 03:55 PM   #106
bWRX
Member#: 6672
Default CEL log
Mileage: @3300
Code: P0303 - misfire in cylinder #3
Dealer: Tischer Subaru, Silver Spring, MD
Maintenance Action: Checked plug, wire, and coil. Cleared ECU memory. Test drove and problem did not re-occur.
Technician suspected fuel contamination, in particular water in the fuel, suggested I use a different fuel station.
bWRX is offline   Reply With Quote
Old 07-02-2001, 04:03 PM   #107
rkkwan
Member#: 5596
2010 Honda Fit Sport
Date: 6/29/01
Mileage: ~6500
Allocation: 1st
CEL: Don't know the code, but it's a cam sensor. Dealer replaced sensor and it's been okay so far.
rkkwan is offline   Reply With Quote
Old 07-09-2001, 12:38 PM   #108
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
*Manual Transmission
*light came on July 5, 2001 @ 3494 miles; went off with no intervention on my part on July 7, 2001 @3605 miles
*no code has been pulled
*Carlsen Subaru, Redwood City
*I talked to the dealer's service department on the phone. Since the light had already gone off he said not to worry about it unless it comes on again. He mentioned that sometimes people don't get the gas cap on tight enough (not the case for me). He also mentioned that some of the cars have had a vacuum hose which was not attached (would not tell me which one). Finally he said that if it goes off again I should definitely bring it in because "any number of things can go wrong" with emissions systems these days...
Edit - January 15, 2002
Manufacture date: February 2001
*light reappeared on January 11, 2002 @ 10,800 miles; turned off with no intervention by me after approximately 100 miles
*P1443 code pulled
*Santa Cruz Subaru
*Made an appointment to drop off car so that the ECU can be sent to Japan for reprogramming. Loaner car will be provided. Santa Cruz has my business from now on.
Stanley is offline   Reply With Quote
Old 07-09-2001, 02:57 PM   #109
Psi-Fire
Member#: 6498
* transmission (auto, manual)
* what date/mileage it went on/off
* what code was retrieved by the dealer (e.g. P1443)
* name of dealer
* what action the dealer took (e.g. ordered O2 sensor, drain solenoid)
Manual Transmission
2275 miles
no code yet, in shop as we speak
Flemington Subaru
none yet, but will be covered by warranty
Good thing I was already bringing the car in for service on tail lights that came dead on arrival, so they should be able to fix both in one shot.
Psi-Fire is offline   Reply With Quote
Old 07-18-2001, 12:40 PM   #110
Surf WRaX
Member#: 4550
2002 WRX Wagon #4321
transmission: manual
mileage on: 4500
mileage off: 4550 (dealer reset)
code: P1443
dealer: Barber Subaru (Ventura, CA)
action: dealer didn't know what to do, i told him to order new Vent Control Solenoid (but looks like ECU needs programming?)
Surf WRaX is offline   Reply With Quote
Old 07-18-2001, 01:46 PM   #111
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
A while back I had a cel on my 5-spd wagon. Gotta love my.subaru.com
Service Provider: Bertera Subaru, Inc.
Service Date: 6/12/01
Mileage: 773
Repair Order #: 45887
Service Description: Warranty ORVR Evaporative Vent Control Solenoid Valve <--- They found water in the solenoid valve.
I asked them if they did anything to prevent it in the future and they kinda gave me a vacant stare and said" "uhhh... no".
So if some of us are taking it to the dealer and they find water in the solenoid.. shouldn't that mean that SOA should be trying to prevent crud from getting in there.. instead of reprogramming ECU's?
lenyx is offline   Reply With Quote
Old 07-18-2001, 03:19 PM   #112
KC_057
Member#: 8457
2002 WRX Sport Wagon
* Manual
* 7/16/01 CE turned on ~6500 mi
* P1443
* Stevens Creek Subaru
* Pulled ECU out, sent it to SOA for reprogamming of the flash
Note: There are 4 WRXs at Stevens Creek Subaru with their ECUs pulled and sent to SOA for re-flashing. The front man for the garage said that they are sending every ECU with the P1443 code back to SOA for re-flashing.
KC_057 is offline   Reply With Quote
Old 07-18-2001, 03:34 PM   #113
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
* Manual
* 7/13/01 CE on 5525 miles
* P1443 (pulled myself)
* 7/15/01 CE light went off(or didn't come back on after starting car) ~ 5650 miles
* 7/17/01 inadvertantly cleared computer(I assume) when disconnecting battery to install TT.
If it comes back on I'll pull it again and contact dealer.
Zahnster is offline   Reply With Quote
Old 07-23-2001, 02:56 PM   #114
daverup
Member#: 3708
2015 WRX Ltd Sedan
ISM
First CEL
5-speed Wagon
7/21 8200 Miles
Code 1443
Superior Subaru called SOA for guidance. Dealer says that my ECU must be sent in for mods.
I know someone else posted details of SOA having extra ECMs floating around. Now I have to dig for one.
Reset code, light out for now.
3/4 tank of Amoco 93 octane
93 degrees in traffic slowing down when light came on.
No other problems noted
daverup is offline   Reply With Quote
Old 07-24-2001, 09:01 AM   #115
lexwrx
Member#: 7808
2002 WRX 5spd Sedan
Platinum Silver
* First CEL
* 5spd sedan
* silencer w/K&N
* occured @ 450 miles on 7/24/01, 8a EST
* no code yet (I suspect it's 0303) edit: P0304
* Beechmont Subaru, Cincinnati
Comments:
* CEL went on, off, on, off in space of 1.3 miles to work
* happened both times in 1st b/t 2000 & 3500 RPM
* ~ 75 degrees with high humidity, dry roads
* car noticably mis-fired (lurched) a couple times for each CEL
* 3/4 gas tank with 94 Shell
* checked gas cap (it was tight); unscrewed & re-tightened
* will drive it some more before taking to dealer for diagnostics
Edit: The CEL actually started FLASHING later in the day ... took it immediately to the dealer and they got a "P0304". They changed the plug and I'm back in business ...
lexwrx is offline   Reply With Quote
Old 07-25-2001, 12:16 PM   #116
poostik
Member#: 5414
* manual
* 07.19.01 (CEL came on)
* P1443 (VENT CONTROL)
* Flemington Subaru (NJ)
* Cleared Code (Light was off the day I brought it to them; it was on for 3 days before). They said they were waiting on information from Subaru
poostik is offline   Reply With Quote
Old 07-26-2001, 10:58 PM   #117
briank
Member#: 3568
2002 WRX EcuTek
* 5 speed sedan
* 7600 Miles
* Got CEL upon start up on a HOT (95 F) and humid day.
* Reset ECU myself and light went off.
-BrianK
briank is offline   Reply With Quote
Old 07-27-2001, 12:33 AM   #118
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I haven't had my CEL since a few months ago (touch wood) but I noticed while installing my hitch that one of the three hoses to the evap cannister was missing a clamp.
Anyone else's like this?
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 07-30-2001, 01:00 PM   #119
Herbie
Member#: 415
2002 WRX Wagon
2002 BMW Z3 3.0i Coupe'
AAAaaargh! Guess who finally threw a CEL this weekend?
Man, I thought I'd dodged the bullet and got a first-allocation WRX that WASN'T going to code-out like many others have.
Well, it finally happened:
~4400Miles
First Allocation WRX Wagon 5MT
Going ~70 light cruising (off boost)
Code: 1443 (yep...)
Dealer was impressed that I predicted the code before it was pulled. They were starting to give me a big line about "Well its saturday and you don't have an appointment so you might have to leave it for a few days..."
Well, anywho code is cleared and hasn't come back yet, they've ordered a replacement drain valve-whatchamacallit.
Cheers.
Herbie is offline   Reply With Quote
Old 07-30-2001, 10:31 PM   #120
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
You should have them call the techline and get the ECU reflashed.
Old 07-30-2001, 10:41 PM   #121
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Glenn
Mine is like that too. I've had 2 CE lights
Old 07-30-2001, 11:27 PM   #122
Austin
Member#: 7089
2016 STi
5spd Sedan
7600 miles
2nd time, p1443
Austin is offline   Reply With Quote
Old 07-31-2001, 11:39 PM   #123
SixGirl
Member#: 7767
Lucky me, I get to join up
* transmission manual 2002 wrx sport wagon
* what date/mileage it went on/off -- 828 Miles on, Reset by dealer at 848ish
* what code was retrieved by the dealer - P1443 - Big surprise!
* name of dealer - Vanbortel Subaru
* what action the dealer took - Was very familiar with this error, was stating that they would probably be replacing / reflashing the ecu. Said if I had any further problems with it that they would replace the vent. (Basically that this meant on occassion that I was venting fuel) Nice guy, saw the car on a Saturday when closed just to pull the error code. Really appreciate that!
SixGirl is offline   Reply With Quote
Old 08-01-2001, 09:05 AM   #124
bedabi
Member#: 4825
2013 BRZ
CBS
Default Just an Update...
Now at just over 7,700 miles.
5-speed manual, sedan. Only mod is a K&N filter panel.
Try to use Sunoco 94 octane exclusively.
The car is driving far better than pre- or post-break-in periods.
No CEL light at all.
bedabi is offline   Reply With Quote
Old 08-30-2001, 07:30 PM   #125
aov
Member#: 7193
MY02 WRX
* manual
* 3500miles
* P1443
* Austin Subaru
* They sent it back to SOA, and then it was temporarily lost in the mail for a week. Got a Enterprise pos car that stunk so bad I made them replace it, got a Jimmy in stead. When I got the car back it had a bent license plate and scratched bumber (underneath) that I can't prove happened while at the dealer...
The CE light has not come on again, thankfully!
Not looking forwad to next service.
Oh, I washed the car before I turned it in so they wouldn't send it through a car wash. Instead they just sprayed tons of gunk on the tires that was thrown on the paint when I drove it away.
-Anders
aov is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 10:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 05:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 04:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 11:45 AM
