Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 10-16-2001, 07:35 PM   #151
Member#: 8463
15 Impreza Hatch
Base - CWS - 5MT
Thumbs down
*approx. 400 miles on July 23rd, two days after picking up car
*P1443 (Evap. Control Module)
*Brewster Subaru, although bought at Rye Subaru.
*Brewster Sub. sent computer to SOA, re-programmed, and shipped
back after 5 days. Dealer's service Tech. drove the car HARD in front
of my face, made me mad. No Complaint filed.
*~7200 miles, no issues since.
phatride01 is offline   Reply With Quote
Old 10-17-2001, 12:27 PM   #152
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
manual trans
12,000 miles
no CEL noticed
Carter Subaru
1. Rough idle at startup, feels like a cylinder or two is not working. Severe hesitation during acelleration.
2. While driving car it loosses all power for a split second like either fuel of spark has been cut off.
Goes in Friday the 19th of Oct
Greg Downing
gpd323 is offline   Reply With Quote
Old 10-18-2001, 01:27 AM   #153
Member#: 7089
2016 STi
5MT, 9100 miles P1443 fuel evap solenoid
MIL was on shrieden's wrx. Checked/cleared w/obd-2 scanner.
Austin is offline   Reply With Quote
Old 10-18-2001, 07:43 PM   #154
Member#: 6743
~3000 km - vent control solenoid (P1443)
~6800 km - vent control solenoid again (P1443)
Westboro Auto Imports, Ottawa.
Didn't experience any problems driving car after check engine light illuminated. Check engine light turned itself off ~100 km later.
Dealership will flash ECU. Very easy, no arguing needed.
Dave99 is offline   Reply With Quote
Old 10-23-2001, 06:06 PM   #155
Member#: 6862
Default WRX Check Engine Light Log
12000 km - (P0303) Misfire cylinder #3
15000 km - (P0303) Misfire cylinder #3
Both occured after having used the car for about 10-20km and then turning the car off and then restarting the car withing 10min of shutoff. Both times happened at idle and i did notice the car was idling a bit rough both times. Both times dealer reset ECU.
Last time (10/23/01) they told me it might have something to do with the "aftermarket" alarm system which is tied in somehow in some fashion to cylinder#3's wiring. They siad this could be causing the problem as it an aftermarket alarm (even though i ordered the car with the alarm and they either installed it themselves, or shipped it somehwere to have the alarm installed) They said the will be contacting Subaru to determine an appropriate course of action.
CanadianWRX is offline   Reply With Quote
Old 10-24-2001, 12:08 PM   #156
Member#: 11096
Auto Sedan
on at 1000 CEL on for the hole week.
the dealer turn it off.
no code shown.
at 5000 and turn of by it self after 3 days.
dealer sent computer to SOA for reprogram.(took them 3 days to come back. got a loaner car)
over 6000 now, no CEL yet
Manassa Subaru, Manassas, VA
4Runner is offline   Reply With Quote
Old 10-26-2001, 09:42 PM   #157
Member#: 7958
09 GH B+
Default P0340
manual transmission
10/20/01; 9,200 miles on, off next morning
no symptoms
P0340 camshaft position sensor
Homestead Subaru
pulled code, checked sensor- tested OK, but replaced it anyway to play it safe, reset ECU
Big Sky WRX
Old 10-29-2001, 12:25 PM   #158
Member#: 10737
2003 Infiniti G35 SC
Laser Red. 99 Chevy Sub.
CEL on at around 5700
Codes: 0301 and 0303.
Dealer cleared codes and did 4 driving cycles. Said there wasn't any thing else wrong. That they were erroneous codes.
Dealer: Frederick Motor Co., Frederick MD
The CEL has come on 4 other times since.
once around 7000 ( I took off gas cap and then put it back on, light was gone when started it up again).
once around 8800 ( could not get it go off, so I tried the 4 key cycle)
once around 10000 ( again it would not go off. did the 4 key cycle).
and the last time was around 11500 ( this time around 11600 it went off after it had sat for awhile).
Unfortunately I didn't get the exact mileage and haven't had the codes pulled yet for the other 4 times.
discord is offline   Reply With Quote
Old 10-29-2001, 06:27 PM   #159
Jon [in CT]
Member#: 2992
02 WRX Sedan
* transmission = manual
* date/mileage it went on = 10-30-01 / 8847
* code I retrieved = P1443
* name of dealer = unimportant
* what action the dealer took = diagnosis turned up no problems, so ECM mailed off to distributor for re-programming.
Jon [in CT] is offline   Reply With Quote
Old 10-31-2001, 01:47 PM   #160
Dr. All Surface
Member#: 5647
2005 OBXT
second allocation WRX wagon
date/mileage it went on = 10-30-01 / 11005
name of dealer = Burlington Subaru, Burlington, VT
what action the dealer took = service appt scheduled for 11-9-01 to have the ECU reflashed, said that SOA is so backed up reflashing the ECUs that they don't want to see it for a week. The dealer also stated that they have seen a few of the same problem with the 6cyl legacys. My wife is not pleased with the check engine light having been on, especially since the WRX was purchased to replace an Outback that she thought was a "death mobile".
Dr. All Surface is offline   Reply With Quote
Old 11-07-2001, 08:17 AM   #161
Member#: 11794
* last week with 1500 miles
* code was "system to lean"
* Grand Prix Subaru of NY
* reset computer and advised me to remove my aftermarket intake and blow off valve
STEVESblueWRX is offline   Reply With Quote
Old 11-07-2001, 09:17 AM   #162
Member#: 5268
03 Honda Blue Egg
Toyota Silver Shoe
* manual
* 11/2/01, approximately 10830 on, 10986 off
* PO457
* Kelly Subaru
* cleared code and road tested
* 11/7/01, 11374 miles
* unsure of taking to dealer yet (too far) - how do you pull the codes yourself?
* considering resetting ECU myself
bliu is offline   Reply With Quote
Old 11-11-2001, 08:57 PM   #163
Member#: 6375
2004 STi
Java Black Pearl
MFG DATE = 03/01
* date/mileage it went on = 11/11/01 / 10500
* name of dealer = did not go
* I cleared the code, will monitor it over next few days, if it re-appears I will call dealer or SOA and see what they want to do.
Kenneth2000 is offline   Reply With Quote
Old 11-13-2001, 12:24 PM   #164
Member#: 7991
* 02 Sportwagon, 5MT
* CEL on at 7002, 11/11/01. Off at 7080 11/12/01
* P0303, Misfire on #3 Cyl.
* Burt Subaru, Littleton, CO
* ECU sent to SoA for re-flash
* CEL came on during low-speed parking lot driving
* Dealer tech staff knowledgeable about the P0303, still contacted SoA to be sure.
* OBW provided as loaner
* Back in service 11/14/01
jds is offline   Reply With Quote
Old 11-15-2001, 12:37 PM   #165
Member#: 442
16 SS
00 S2000
* CEL on at 22015, 11/14/01. Off following morning at startup.
* P1443, Fuel Evap Solynoid.
* Metro Subaru, Somerset MA
* Reset and followed instructions per Service Manual
This is the 3rd time I've gotten a P1443. All they do is reset it.
KC is offline   Reply With Quote
Old 11-21-2001, 09:20 AM   #166
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
2002 Sport Wagon
13,260 miles
code: P1443-vent control solenoid
Dealer: Carter Sube, Seattle Washington
CEL popped on while crusing at 60mph, scanned with pocketlogger.
Will call Carter this morning to see what the game plan is and how
they are addressing this problem. Hopefully they have gotten smart and have replacement ECU's instead of pulling the ECU and sending it away for reflashing which means no WRX for a while.
Greg Downing
Old 11-26-2001, 01:27 PM   #167
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
*02 WRX sedan Manual
*~7000 miles, three times so far
*2nd time, P0303, Misfire - haven't checked for the 3rd time. This apparently was the only code stored, even though it was checked during the second CEL.
*Purchased at Dwyer, haven't returned for CEL
*A friend pulled the code while the CEL was on the 2nd time. All three times the CEL came on when the car was started hot, and operating less than 5 minutes. The CEL is on right now, but the first two times it went of after a couple driving cycles.
SlideWRX is offline   Reply With Quote
Old 11-28-2001, 08:18 PM   #168
Member#: 12362
Platinum Silver
*WRX sedan manual tranny
*sub 1000/2948
*P0457(Evaporative Emission Control System Leak Detected (gross leak)/P0303 (misfire cyl. 3)
*cleared them both with my scan tool
*no mods, Mobil 93 used for every tank since new, except this tank which is Exxon 93 during which I got the misfire code
I did get the P0303 after hot-starting my car, but I had not been driving hard any time reasonably near that time (maybe not driving hard was the problem! )
scoobybrande is offline   Reply With Quote
Old 11-28-2001, 09:20 PM   #169
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Post Exxon-Mobil
Since Exxon now owns Mobil, I wonder if they'll keep separate gas refineries? (things that make you go "hmmm")
Darryl is offline   Reply With Quote
Old 11-30-2001, 10:22 AM   #170
Member#: 5556
2002 Sedan
4,769 miles
code: P1443 - vent control solenoid
CEL came on while crusing at 50mph. Dealer needs to remove ECU and have it reflashed. Car will be left at dealer for approx. three days while ECU is shipped some place. Free rental will be provided by dealer. No modifications, car well taken care of, no other problems.
Jimbaru is offline   Reply With Quote
Old 12-04-2001, 08:35 AM   #171
Member#: 8021
Blaze Yellow
WRX Sedan
5 speed
5073 miles
P0303 mis-fire no. 3 cyl
cleared while I waited. Suggested bad tank of gas.
mrmjohn is offline   Reply With Quote
Old 12-04-2001, 09:26 AM   #172
Member#: 7347
2002 Impreza WRX
WR Blue
transmission: manual
what date/mileage: August @10k
what code: vent control solenoid
dealer: Metric Subaru
action the dealer took:scanned, and reset...did not come back.
Although...yesterday, CEL came back on. Haven't brought to dealer yet.
Both times, CEL came on in 4th gear, while picking holes through traffic, with lots of rapid on and off throttle. Will post when this CEL diagnosed.
andygold is offline   Reply With Quote
Old 12-04-2001, 09:49 AM   #173
Member#: 12189
2002 WRX sedan
Lightbulb CEL Light
Wrx sedan 5spd
1500 miles
went mysteriously off 200 miles later
wrxguy is offline   Reply With Quote
Old 12-04-2001, 01:39 PM   #174
Member#: 12727
Its got internal
combustion ftw!
2002 5 spd wagon
CEL ON: ~1000 mi 11/30 after KK meet driving around 70 mph on the Freeway, tank about 3/4 full
Code: P0453 (Fuel Tank Pressure Sensor Circuit High)
Dealer: Irvine Subaru (only one open Sat, 12/1)
Dealer suggested poor quality gas and recommended Chevron and 76. Cleared code and test drove.
Filled up with Chevron 91 12/3. Light went off after fill up; CEL came back on after about 50 mi of driving (1200 mi), again on the highway. Taking it to the dealer Friday (next open appt).
Always used 91 oct. First fill up @ Shell, second @ Chevron.
UPDATE 12/7: Light was off, ASSAEL pulled code, got P0453, did emission test, found no defect.
UPDATE 12/10: Filled up gas with Shell (service director at ASSAEL said I can put any gas brand I want, as long its 91). Light came back on after about 50 mi. Took car to dlr on Tues. 12/11. Dlr claims there is short somewhere, and they need to keep car. Got Chevy Metro rental (just shoot me now) w NO POWER STEERING! I want them to fix the CEL, but I don't want to drive a POS metro.
UPDATE 12/13: Dlr called and told me something is loose in the ECU, so they ordered a new ECU. I'll get the WRX back till they get the part.
UPDATE: 12/27: New ECU is installed, 12/28 Check engine light is back on. Had dealer check it again!! This time they think it's a Fuel Pressure Sensor. New Part is ordered.
UPDATE: 1/14/02: Fuel Pressure Sensor part has arrived. 1/15: I took the car to the dealer. He quoted me 2-3 hours, but the technician says, "No Way! That sensor is in the fuel tank. We have to drop the rear driveshaft, and the fuel tank to get to it. It'll be at least a day to do it. The dealer didn't want to give me a rental for 2-3 hours, but agreed to get me a rental. Enterprise didn't have any Chevy Metros (thank the lord!) and so I got a Park Avenue. It's a far cry from the WRX, but it's nice. Hopefully this is the end of my CEL woes.
UPDATE: 1/26/02: The car hasn't been driven much because I'm driving my old MX6 to make sure stuff still works. CEL is back on today after putting gas and driving about 60 miles. AARRGH!! Those idiots at Assael are quite incompetent at fixing this problem. SOA is going to get an angry call from me Monday AM.
narenji is offline   Reply With Quote
Old 12-04-2001, 07:36 PM   #175
Member#: 7906
04 Sti Black
02 WRX Red
Trans: Manual
Date On: 12/01/01 (8367 miles - came on when I started car)
Date Off: 12/04/01 CEL reset (8409 miles)
Code: P1443
Dealer: Morristown Subaru
- Reset CEL and ordered new vent valve. They will let me know when it comes in. Service manager indicated that nearly all the WRXs they have sold generated this code. They have made SOA aware of it but to their knowledge SOA was not going to issue a recall.
- 12/10 : Reset eliminated CEL, dealer cleaned out evaporative canister and sealed with silicon. Found lots of cob webs in canister and hoses. Dealer said this was a common problem with Subarus. Retested ECU and found no further codes. Did not replace vent valve.
rakman is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 10:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 05:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 04:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 11:45 AM
