Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 12-05-2001, 03:48 AM   #176
andygold
Member#: 7347
2002 Impreza WRX
WR Blue
Trans: Manual
Date On: 12/03/01 (15K miles - came on while shooting through traffic (rapid on and off throttle )
Code: vent controll solenoid
Dealer: Metric Subaru
Action the dealer took: scanned, and reset...did not come back. Dealer also noticed that there was next to no pressure in the fuel tank (read about .01 psi)with about 1/2 tank. Opening and closing gas cap did not cause any change, as if locked up. After ECU reset, CEL went away, and fuel tank- pressure function returned to normal.
andygold is offline   Reply With Quote
Old 12-05-2001, 10:58 AM   #177
ssmv650
Member#: 9723
2009 wrx hatch
Default cel 1443 code
had at 968 miles and again at 2450
took it to dealer explained that SOA will recode ecu these. dealer sent ECU away it came back no issues to date...
ssmv650 is offline   Reply With Quote
Old 12-07-2001, 11:23 AM   #178
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Trans: 5 speed
CEL on at 9430 miles
misfire of cylinders 1 & 3
bad injectors....
CEL off at 9435 miles...
Old 12-14-2001, 03:08 PM   #179
Bugsie1
Member#: 72
2008 BMW Z4M Coupe
I got 2 CELs in the space of about 90 miles, first was reset by the dealership, they reported it to be an evap leak code (P0437?)
Next one was the same thing and they replaced my fuel cap (they said it was cracked)
We'll see if that was it, hopefully so.
- Richard.
02 WRX Wagon
9600 miles
Both CELs in 5th gear, Freeway cruising about 65mph.
Bugsie1 is offline   Reply With Quote
Old 12-17-2001, 08:26 PM   #180
Bugsie1
Member#: 72
2008 BMW Z4M Coupe
Got the CEL again yesterday!
Again I was cruising the Freeway 70mph, still awaiting a callback from SOA about my ABS and CEL problems.
I'm guessing it's the same code (Evap leak) Can't believe I have to take the car in again!!
That's 3 times in 3 tanks of gas.
-Richard
DEC 27th UPDATE: turns out there was a loose hose on the "drain valve" in the rear of the car (guess they didn't spot it the first 3 times!) The hose was reattached but I still got the CEL, so they tellme my ECM needs recalibrating. I have to take the car in Jan 2nd and leave it there while my ECM is shipped back to SOA, recalibrated, shipped back and reinstalled. I get to drive some crappy Taurus or something meanwhile.
Old 12-20-2001, 12:15 AM   #181
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I got a flashing CEL for like 15 seconds after I had installed a Unichip and Uppipe, went for a drive then slammed on the gas in second gear. I think I took it to 6500rpm it was running fine and stong but the light blinked at me then went away. *WEIRD*
djerickd is offline   Reply With Quote
Old 12-21-2001, 12:21 PM   #182
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
Car: WRX Sedan
Trans: 5MT
Miles: 5557
Conditions: 4th gear highway on the way to work, just cruising
Code: P1443 Vent Control Solenoid
Dealer: Austin Subaru
Scheduled to reprogram the ECU after the holidays. CEL went off a few days later at 5670 miles
Xio is offline   Reply With Quote
Old 12-24-2001, 01:36 PM   #183
SammyDFG
Member#: 6891
'02 Impreza WRX
Safe 'n Sexy ASPEN WHITE
6600 miles
my first CEL
god its annoying
i noticed it on the highway
before I got on i did a sharp right turn where the ABS kicked in
maybe thats why?
what do i do
PM ME
SammyDFG is offline   Reply With Quote
Old 12-26-2001, 05:47 PM   #184
Scooby do
Member#: 1217
2005 9-2X
Artic Silver
After 5 check engine lights they are reprogramming the ECU they say it will take three days. No codes given, the other times it reset itself.
Scooby do is offline   Reply With Quote
Old 12-28-2001, 11:46 AM   #185
royzwrx
Member#: 9542
2002 WRX Sportwagon
Car: WRX Wagon 5-spd
Mileage: ~8500 on ~8650 off ~8700 on
Dealership: Royal Moore Subaru, Hillsboro OR
Code: P0303?? Misfire
They want to send my ECU for "reprogramming" next week. They will provide a rental as part of my warranty service.
BTW, these guys took my car in this morning with no appointment on my way to work. They have a really great service department.
royzwrx is offline   Reply With Quote
Old 12-28-2001, 03:52 PM   #186
Giamilton
Member#: 8002
2013 WRX 5dr/Abarth
WR Blue/Nero
6200 miles p0303
I have hesitation on boost in all gears. SOA is going to have my dealer (Wentworth) take a look at it when I have the oil pump leak taken care of.
In what cases do dealers seem to be sending the ECU back for reprogramming? I was under the impression it was for p1443 not p0303?
VIN ********2G508621
PM with any info, thanks!
Giamilton is offline   Reply With Quote
Old 12-28-2001, 10:59 PM   #187
binderm
Member#: 13645
2002 Subaru WRX
Cool CEL Problems
CAR: WRX Sedan
VIN# 506295
Peninsula Subaru in Gorst Washington
Occurred between 6500 and 7300 miles so far.
Transmission: Automatic
Five times into the dealership, each time I got the CEL I also had an Automatic Transmission Temp light start blinking.
Four Cures so far:
1st Replace the Mass air flow sensor
2nd Replace the O2 sensor
3rd Replace the ECM and TCM - Transmission Control module
4th Remove the mask from the hood
Since all of the problems occurred in the rain the dealership has decided that the mask is holding water and dumping water into the engine when I accelerate. This is even though the problem occurred at 20 mph with no acceleration the first time and at approximately 30 mph and slowing the last time. I am going to talk to them about getting the ECM reprogrammed. I hope that will be the final cure.
binderm is offline   Reply With Quote
Old 12-29-2001, 10:20 AM   #188
andygold
Member#: 7347
2002 Impreza WRX
WR Blue
Trans: Manual
Date On: 12/17/01 (17K miles - came on while cruising @ 70 mph(steady throttle), blinked 3 times then extinguished. About 100 miles later, CEL came back on, but steady. CEL extinguished on it's own about 400 miles(4 days) later.
Code: vent controll solenoid...AGAIN
Action the dealer took: SOA Tech re-flashed the Eprom, while at the dealer. Dealer setup date for many WRXs to gather for massive flash session. IMHO, much much better than sending ECM back to SOA. ECM had to be accessed for flashing...not done through OBD II port.
Old 12-29-2001, 10:47 AM   #189
WagonMaster
Member#: 6445
2002 WRX Wagon
WR Blue
Car: WRX 5spd Wagon
Miles: 6800
Code: P0303
Diag: Misfire in cyl #3.
The dealer reset my ECU and sent me on my way. He said it could be due to water in my gas tank or some dodgy gas. I only ever fill up with premium though...
WagonMaster is offline   Reply With Quote
Old 12-31-2001, 08:27 PM   #190
supermarkus
Member#: 6971
2008 WRX STi
SSM
Car: WRX sedan
Tranny: 5 MT
Miles: 3870
Dealership: Carter, Seattle WA
Code: p0303, misfire in cylinder #3
Action: Checked connections and cleared the code. Claimed nothing was unusual upon inspection. Fixed under warranty. I noted that the CEL came on as I was idling on a really rainy evening.
supermarkus is offline   Reply With Quote
Old 01-02-2002, 12:35 PM   #191
bgsntth
Member#: 3441
05 OB XT
Blk
Mileage: 6342 on a Manual
Code P0303-misfire on # 3 cylinder
Came on also while idleing in a steady downpoar. Dealer ordered a #3 cylinder coil, which is a different fix than I've read on this thread. Will update when part comes in.
bgsntth is offline   Reply With Quote
Old 01-05-2002, 08:20 PM   #192
CoachTim56
Member#: 13948
2005 Impreza WRX STi
WR Pearl Blue
Default WRX ECU problems
I have a 2002 WRX with 7500 miles on it....about a week ago I had an oil change, and the threads in the oil pan were toast, so Auburn Subaru helped me tremendously by changing the pan out in 24 hours...GOOD JOB GUYS!!!
Then the really bad thing happened; I was sitting at a stoplight, when the Check Engine Light came on. As I started accelerating from the stoplight, I noticed a definite lack of power...I drove home, then back to the Subaru dealer in Auburn.....now this was at 4pm on a Friday afternoon, and I had no idea what to expect...apparently the computer dropped #3 cylinder, and the code that came out told the guys in Service to send the ECU back to Subaru for re-programming. This is the first time I've had any problems with this car, and the 7500 were not easy miles.....but lo and behold the Auburn Subaru guys came through....they gave me a 99 Impreza to drive until my car gets fixed.....although it sure doesn't do 0-60 in 5.4 seconds....and it's an automatic...but at least I have a car till mine is fixed.
I was wondering if anyone else has had the same problem....I have heard about resets, but never taking the computer out to reprogram it.
Thanks...and a tip of my hat to the guys in the service department at Auburn Subaru.
CoachTim56 is offline   Reply With Quote
Old 01-06-2002, 01:47 AM   #193
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
Default Oil Pan Threads
You said the oil pan threads were toast--please explain. Who changed the oil previously? Why were the drain plug threads stripped?
sajohnson is offline   Reply With Quote
Old 01-06-2002, 02:37 AM   #194
CoachTim56
Member#: 13948
WR Pearl Blue
The first oil change at 3000 was done at a Subaru dealer in Yakima.....the last one at Auburn Subaru...when the mechanic pulled out the drain plug, he noticed rips in the threads....so I asked if I could look at the threads, as I am a journeyman machinist. I looked at the threads on the drain plug, and they were about 30% gone....the pan side showed double-crested threads, which leads me to believe it was either a factory defect, or on the first oil change, the plug wasn't threaded into the pan properly. But I would probably believe it was a defect from the factory...could have been soft steel in the plug material...a number of things could cause thread galling...unless they missed the tolerance between the plug and the pan.
BTW...the dang computer going out is the first electronic problem I've had, and I've put some hard miles on the car already.
Old 01-10-2002, 01:33 AM   #195
fluffybunny
Member#: 5408
2002 Impreza WRX
WR Blue
coach,
not me but i've heard of numerous people getting their ecu's flashed. do a search and you might come up with something.
the bunny
fluffybunny is offline   Reply With Quote
Old 01-11-2002, 01:57 PM   #196
vizor
Member#: 13851
2002 WRX Wagon
WRBP
* WRX Wagon
* Dealership: Austin Subaru in Austin, TX
* Miles: 11 and again at 120 (brand new car)
* Codes: P0171, P0301, P0302, P0303, P0304
P0171 - engine is running lean
P030x - cylinder misfire (x = cylinder number)
Both CELs had all the above codes; the first time the dealership thought it may just be some minor just-fresh-from-the-factory thing and cleared the codes without further diagnostics.
The second time the dealership wanted to look. A disconnected vacuum line was found and once reconnected, the engine ran better of course, and the CELs stopped occuring. The CEL has not triggered since the fix.
Being a brand new car, this was a frustrating experience but I figured it was something minor. Luckily it was!
vizor is offline   Reply With Quote
Old 01-14-2002, 12:59 PM   #197
Bugsie1
Member#: 72
2008 BMW Z4M Coupe
Oh dear God.
Almost lost count of the number of P0457 CEL's:
CEL... Reset by dealer
CEL... New Fuel Cap installed by dealer
CEL... Drain Pipe fixed by dealer
CEL... SOA reprogrammed my ECM
and now guess what, less than 200 miles after my new ECM...
CEL.
Do I have any constructive comments or advice for others?? No, I'm just really upset, my WRX is not well and SOA can't fix it.
- Richard.
Old 01-14-2002, 09:00 PM   #198
1ofeach
Member#: 8641
2002 WRX DayGlo Blue
2001 S2000 Silver/Black
Angry misfire
WRX Sedan 5-speed w/3000 miles
CODE: P0303 (misfire in #3 cylinder)
The CEL was steady-on, not on-off-on
Dealer: Dellenbach Motors, Fort Collins, CO
Action: Dealer took a look, stuck his thumb in his ass (where his head was) and said nothing was wrong. He said it might be a problem with the gasoline in the winter time around here (additives and stuff). Suggested maybe a fuel injector cleanor or octane booster. Yeah right. Not gonna pay extra on top of the price of supreme gas. If something is wrong with the engine, they better fix it next time.
I'll check the spark plug wires like I've seen in other posts, and maybe get some sealant against moisture for them (although it's pretty dry here).
1ofeach is offline   Reply With Quote
Old 01-14-2002, 10:47 PM   #199
Jess
Member#: 10612
2015 WRX STi Launch
WR Blue Pearl w/ Gold BBS
WRX wagon 5MT
CEL at 7700 Mi, OFF at 7800 and ON again at 7900.
Code P0303, misfire cyl.#3
Wentworth Subaru
Action: ECU sent for reprogramming. They are also checking on the decelleration noise issue.
Jess
Jess is offline   Reply With Quote
Old 01-15-2002, 01:13 AM   #200
70 CUDA
Member#: 14249
2005 WRX STI
5 Speed Man
3100 miles
Code ?
Throttle Sensor
Reset by Wentworth- Portland OR
CEL came on at a steady 60mph. There was a pulse (loss of power) when the light came on. There was a loss of power in the high-boost range, 3000-6000 rpm, which went away after several days (without reseting). CEL light went off the day after it came on.
Wentworth said it only needed to be reset not reflashed.
70 CUDA is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 10:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 05:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 04:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 11:45 AM
