Old 01-15-2002, 01:52 PM   #201
aspera
Member#: 7879
* 5 speed
* 01/14/02...8,400
* P0442 (evaporative emission control system malfunction)
* Jack Miller Subaru, KCMO
* tightened fuel cap, reset light
Light came on at a steady 55MPH and stayed solid.
aspera is offline   Reply With Quote
Old 01-15-2002, 03:19 PM   #202
Flesher
Member#: 7921
Sliver
So Far I've had the CEL come on 4 times.
MT WRX Wagon
#1- Early Sept, ~5000 mi
Code -? (Loose Gas Cap, guessing P0457)
Dinneen Subaru (Cheyenne, WY)
Tightened Cap
#2- Late Sept., ~6000 mi
P0457
Me and my OBD-II Scanner
Decided to pay more attention to gas cap tightness
#3- Late Nov., ~10000 mi
P0457
Carlsen Subaru (Redwood City, CA)
ECM reprogrammed
#4- Early Dec, ~10500 mi
P0457
Put plastic hose ties on hoses leading to/from charcoal
canister in the rear and on some vac. lines up front under the hood
Flesher is offline   Reply With Quote
Old 01-16-2002, 11:26 PM   #203
stacarter
Member#: 4634
WR Blue
Manual
January 15, 2002; 21,248 (this time)
P0340
Subaru of Thousand Oaks, Thousand Oaks CA
Reset
I pull these quite often it seems. It is most often in hard acceleration during cornering with less than 1/2 a tank of gas. They usually reset/go off when I fill up.
This one occurred with a full tank. The service advisor told me I needed to slow down. He said it was a cam shaft position sensor going off at 6200 rpm. I said, "but the redline is 7200 rpm" He responded that I was only going 25mph. That was a bit confusing to be honest. I think 25mph is about right for that rpm in 1st gear.
We'll see how this goes.
stacarter is offline   Reply With Quote
Old 01-17-2002, 12:21 AM   #204
Godmal
Member#: 4934
2007 White STI LTD
Grey Mazda 5
- Manual
-9600 miles
-P0420 Catalyst efficiancy fault
- occured while cruising on highway, part throttle, Sunday night.
-- took to dealer Monday, they cleared and sent me on my way, said "its a computer glitch and there is no fix, I cleared it, it probably won't come back." Came back on tonight, Wednesday.
Godmal is offline   Reply With Quote
Old 01-20-2002, 05:19 PM   #205
wrxsta
Member#: 14445
04 WRX sti
Black Pearl
Default engine light
*manual tranny
*7500 aprox mi went on and off twice
*didn't tell me the code just said it had a bugg
*betera subaru
*replaced whole circiut board under dash
wrxsta is offline   Reply With Quote
Old 01-20-2002, 06:22 PM   #206
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
Default WRXSTA
Which circuit board? That's a new one--I don't think anyone else has reported that fix.
sajohnson is offline   Reply With Quote
Old 01-22-2002, 07:31 PM   #207
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
* manual
* 1/21
* 13052 miles
* P????
* William's Autoworld(MI dealership)
* Said something about the vent control solenoid and the evaporative emission control system as well as mentioned the charcoal canister for emissions(?), and possibly caused by an overfull gas tank...had only 1/2 tank!! Said it could have also been a glitch. Ahhhh man....come on. I want a new WRX!!! It's a lemon!
-JR
WRX34 is offline   Reply With Quote
Old 01-25-2002, 07:01 PM   #208
Bugsie1
Member#: 72
2008 BMW Z4M Coupe
P0457 - Lots of them. (already logged)
Current Dealer explanation is a "blocked Fuel Ventilation system " (rear of the car?) from going off road (it was "full of dirt".)
More info as I find out.
- Richard
Bugsie1 is offline   Reply With Quote
Old 01-26-2002, 09:21 PM   #209
rhino
Member#: 14668
02 WRX
BLACK
3000 miles- - "No Code" On-while cruising on highway
Off-in 2 days
-Dealer states probably gas cap loose (happened with a 1/4 tank of gas)
4000 miles- - P0303 On-while accelerating in 3rd- not redline
Off- in 3 days
-Dealer states likely bad fuel(Mobil 93 octane?). He states next time he will do further diagnostics.
Here's my dilemma... I just bought an AEM intake, and want to install it, but I don't want the dealer blaming my new intake for my next CEL. Do any of you guys with these CEL problems already have mods on your cars that the dealers are giving you a hard time for?
rhino is offline   Reply With Quote
Old 01-27-2002, 06:00 AM   #210
SammyDFG
Member#: 6891
'02 Impreza WRX
Safe 'n Sexy ASPEN WHITE
mines was just a loose-gas cap
phew
SammyDFG is offline   Reply With Quote
Old 01-30-2002, 04:24 PM   #211
Giljorak
Member#: 13128
'02 WRX
chmod 111 /bin/laden
Manual
1/27/02 - ON
~13,500 miles
P0303
Burt Subaru (Englewood, CO)
Ship ECM to NJ for reprogramming
Giljorak is offline   Reply With Quote
Old 01-31-2002, 11:37 AM   #212
WRXURV8
Member#: 14848
2007 Tribeca
TS w/ 20" OZ's
Manual
About 22,000 miles
Came on 3 times
The dealer blaimed my Exhaust
Finally admitted a mis-firing cylinder when another WRX came in with the same problem
Glanzman (Philadelphia Suburbs)
Sent ECU to NJ, had back within hours due to close location
WRXURV8 is offline   Reply With Quote
Old 02-09-2002, 09:09 PM   #213
scoobybrande
Member#: 12362
Platinum Silver
Default My third CEL
*manual
*02/08/02
*~6600 miles
*Code: P0303 Misfire in Cylider 3
*I pulled the code myself, and reset it, don't have time to f*ck around with a dealer
Came on almost immediately after I started the car after it had been sitting for 10 minutes after just being driven. Ambient temp was in the 40's F, 93 AKI from Mobil always, only "mod" is cold Denso Iridiums.
scoobybrande is offline   Reply With Quote
Old 02-16-2002, 04:42 PM   #214
Sophocles
Member#: 7794
8750 miles, too many mods to list.
P0303 cylinders 3 AND 4.
Came on within 1 minute of start of hot engine. It had been sitting less than 15 minutes after a long hard drive. I had cooled the car down w/ 10 minutes of slow driving and a 2 minute idle before shutdown.
When facing the front of the car, are the cylinders labeled:
turbo..3 4
.........1 2
.......radiator ?
Sophocles is offline   Reply With Quote
Old 02-16-2002, 04:56 PM   #215
Austin
Member#: 7089
2016 STi
Yes. Cylinders 1 and 2 are in the front (closest to the bumper), cylinders 2 and 4 are on the driver's side.
Austin is offline   Reply With Quote
Old 02-20-2002, 11:46 AM   #216
mturmel
Member#: 2473
World Rally Blue
* transmission: manual
* what date/mileage it went on/off: 19/02 at 18750 miles (30000 km). Came on right after wife started the car. Wet/damp weather, around freezing, very humid.
* what code was retrieved by the dealer: P0303 Misfire Cyl 3
* name of dealer: Subaru Gatineau, QC
* what action the dealer took: Reset code, no other action
No Engine Mods.
That's a change from my friend P1443...
Matt
mturmel is offline   Reply With Quote
Old 02-20-2002, 01:36 PM   #217
Turboy
Member#: 5933
2004 WRX STi
Java Black Pearl
Default WRX Check Engine Light Log
Transmission: Manual
Date: Wednesday, 13 February. On-10145 miles, Off-10170 miles (reset by dealer)
Code: P0303 - Misfire, cylinder 3
Dealer: Farrish Subaru - Fairfax, VA
Action: Checked/cleaned plug, cleared code and road rested
Appeared on warm restart (15 minutes off) half way through Shell 93 octane filled tank. No other symptoms.
Turboy is offline   Reply With Quote
Old 02-20-2002, 06:00 PM   #218
rhino
Member#: 14668
02 WRX
BLACK
Default Another light- update
1. 3000mi- "no code" says dealer
2. 4000mi- P0303- reset
3. 6000mi-"this is a code we don't understand"... later that day they determined an ECU reprogramming was necessary.
So I will have to give them my car to trade in for a rental for 3-5 days. Hope this takes care of it.
Old 02-21-2002, 07:04 PM   #219
TinyIvan
Member#: 7995
2002 WRX Wagon
Unhappy This one seems more worrisome...
Well, I am now a member of the club here:
* Manual Tranny (STi short throw, factory installed)
* 1-29-02, *93* miles on the odometer!!
* P0546, Exhaust Temp Sensor High Output
* Paul Brothers
* Tech found that connector #4 on the ECM was loose so he connected it. They had to replace the tranny (well, parts of it) before I took delivery due to buzzing I heard during my checkout drive. I now think that's the buzz talked about elsewhere in the forum. I just hope this is it, I want to break the car in and have some fun!!
By more worrisome, I mean it seems like a build quality issue. I sold an American truck due to quality issues, this doesn't give me warm fuzzies!
<EDIT>
* 2-23-02, 155 miles on the odometer
* P0456
* Paul Brothers
* Foudn root of same problem, defective wiring harness in the firewall, causing intermittent short on that sensor. Replaced sensor and either replaced or repaired harness. Working like a champ now. I hope I have now fulfilled my statistical amount of defects (~2 per car for Imprezas)
TinyIvan is offline   Reply With Quote
Old 02-22-2002, 09:59 AM   #220
lgkahn
Member#: 9793
2002 2010 legacy gt
red
That seems like total BS to me..
If that connector was unplugged there would be major hell to pay or the car wouldn't even run correctly .. and it locks in place with a tab.. Doesn't seem to me like they are dealing straight with you.
lgkahn is offline   Reply With Quote
Old 02-22-2002, 11:46 PM   #221
pace
Member#: 11606
2004 Pilot
1995 Miata
* manual WRX wagon
P???? - Boost solenoid malfunction
~2500miles
Dealer reset.
Symptom: Triggered a boost/fuel cut.
~3000miles
Dealer reset & ordered new solenoid.
Note: Was actually my fault for boosting to 16psi which you can't get away with at 8000ft asl.
P0420 - Catalyst system efficiency below threshold.
~10,000 miles.
I pulled code and reset.
Symptom: CEL came on while coasting. No change in performance.
Note: This is the first catalyst related CEL since I installed my uppipe 7000 miles ago.
P0303 - Cylinder 3 misfire.
~10,500 miles.
Symptom: CEL came on shortly after starting the car and flooring it in 2nd (motor was already warm, and had only been sitting for about 15 minutes). No change in performance.
-Pace
pace is offline   Reply With Quote
Old 02-25-2002, 03:42 PM   #222
Avedis
Member#: 8171
2005 WRX STi
Blue / Gold
Default Re: WRX Check Engine Light Log
* what date/mileage: Feb 20 2002: 10,010 miles
* Engine status: light load, partial throttle, sustaining speed
* what code was retrieved by the dealer: p0303 - cylinder 3 misfire
* name of dealer: Carter Subaru
* what action the dealer took: reflashing ECU
* What shipment: First allocation, off the lot on March 15
--jeff
Avedis is offline   Reply With Quote
Old 02-27-2002, 06:17 PM   #223
OnTheGas
Member#: 3807
2002 WRX Sedan
Silver, tinted
Post Re: WRX Check Engine Light Log
* what date/mileage: 02/23/02 @ 14,640 miles... steady light for a day or so...
* what code: P1443 - vent control
* Dealer: Irvine Subaru in California
* Dealer's action: Reprogramed ECU by shipping it to Atlanta, gave me a rental, took 3 days
* What shipment: 1st allocation... took delivery March, 2001
* Bone stock wrx... (I think it's the last stock wrx in southern california)
OnTheGas is offline   Reply With Quote
Old 02-27-2002, 09:57 PM   #224
TinyIvan
Member#: 7995
2002 WRX Wagon
Default Don't make assumptions
Just a warning to the wise, don't make too many assumptions on what's causing those pesky CELs. I brought mine in after another experience with the P0546 code and they found it was due to an intermittent grounding problem on the wiring harness.
Looks like it's probably in the splice in the main wiring harness coming through the firewall. Should be fixed by tomorrow though, but I just about assumed it was a faulty sensor.
Sooo, just make sure not to put off the trip to the dealer like 1000 miles if you don't know, for sure, why you're seeing the CEL.....
-TI
Old 03-02-2002, 01:19 PM   #225
isit24
Member#: 13404
2002 WRX Hybrid
Platinum Silver Metallic
02wrx 5speed
2700 miles cel light
2790 off
P0303 Cylinder 3 misfire detected, cleared
isit24 is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 11:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 06:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 05:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 12:45 PM
