Old 05-27-2003, 10:51 PM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default going to get my car dynoed late next week or early after. what do you think ill get
i am going to dyno the car with my stock turbo, stock injectors, autronic ecu, my 2.5 liter 9:1 compression built block with wrx heads, 4-1 turbo manifold, and all of the other bolt ons. this will be on 91 octane c.a. gasoline. what do you think is the most i can get. i am thinking about 250-275 at the wheels at most. any ideas. i am hoping for the best.
STEALTH-WRX is offline   Reply With Quote
Old 05-27-2003, 11:05 PM   #2
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
2whp I think you are about right in the 250-275 range. As long as the place you are going to is good with the Autotronic then you should get some nice numbers.
ShaggyGT is offline   Reply With Quote
Old 05-27-2003, 11:07 PM   #3
STEALTH-WRX
Member#: 7822
do you think i can pull some extra power if i put some 600cc injectors in. the guy tuning it is good so thats not even a factor for me.
Old 05-27-2003, 11:11 PM   #4
ShaggyGT
Member#: 19221
Possibly. The fact that you are going to tune with 91 octane is going to hold you back but you should definitely tune with what you would run everyday. Have you done any datalogging of your injector duty cycles? It would be hard for me to say since I have no idea where you are at with your current injectors.
-Matt
Old 05-27-2003, 11:12 PM   #5
ShaggyGT
Member#: 19221
Also when you say stock injectors do you mean stock WRX injectors or STi injectors?
Old 05-27-2003, 11:14 PM   #6
STEALTH-WRX
Member#: 7822
i mean 420 cc wrx injectors
Old 05-27-2003, 11:16 PM   #7
ShaggyGT
Member#: 19221
Then yes I would definitely upgrade the injectors to be on the safe side. You dont want to be at the dyno and have to be limited on power due to lack of fuel, especially on 91 octane.
-Matt
Old 05-27-2003, 11:51 PM   #8
STEALTH-WRX
Member#: 7822
cool. sounds good. i hope i make some decent numbers
Old 05-28-2003, 01:33 AM   #9
Matty
Member#: 13408
2008 LGT
black
Default 250 whp ??
250-275 whp with a stock turbo ??
Matty is offline   Reply With Quote
Old 05-28-2003, 03:11 AM   #10
Bardiel
Member#: 11435
2002 Sleeper Impreza
Blackie:)
Cool Heehee
Stealth's WRX has a "Special" engine
Bardiel is offline   Reply With Quote
Old 05-28-2003, 03:23 AM   #11
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
how much did it cost you to get to where you are at now..
scoobyimpreza is offline   Reply With Quote
Old 05-28-2003, 06:24 AM   #12
unmprezivwrx
Member#: 16801
2009 Murano SL AWD
Deep Sapphire Metallic
Man another sweet project going on
I wouldn't go over 600cc injectors right now. Chris (strklybidnis) had 800cc injectors on his sweeet ride (1820 txs stg4 if i rmemeber right), and the tuner couldn't pull enough fuel on the utec to make it work.
unmprezivwrx is offline   Reply With Quote
Old 05-28-2003, 09:42 AM   #13
STEALTH-WRX
Member#: 7822
where i am at right now in this stage is about $15,000. once i finish everything with all of the bigger parts then i am looking into the $20,000 range.
Old 05-28-2003, 10:11 AM   #14
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
got any more info about ur autronic ECU?
stickman is offline   Reply With Quote
Old 05-28-2003, 10:32 AM   #15
STEALTH-WRX
Member#: 7822
its a plug and play, and its a stand alone. thats about all i know. i can snap some pictures of it tonight.
Old 05-28-2003, 01:11 PM   #16
ShaggyGT
Member#: 19221
Too bad you are so far away!! I would love to check out your setup in person, the pictures just dont do it just I am sure. So did you decide to go with larger injectors or are you going to see what it can do on the stockers? Good luck with the dyno tuning, I hope you get the numbers you want.
Old 06-01-2003, 07:52 PM   #17
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
You are braver than I am - I wouldn't run a big turbo without fuel control. Too many guys destroying engines by running lean/detonation.
I would get at least an AF computer...I would also get at least STi injectors and a FPR...
Good Luck.
AntiochCali is offline   Reply With Quote
Old 06-01-2003, 08:23 PM   #18
dorifto88
Member#: 17684
1989 pathfinder
rusted red
Default Re: Heehee
haha, thats an UNDERSTATMENT!!
dorifto88 is offline   Reply With Quote
Old 06-01-2003, 11:12 PM   #19
nmyeti
Member#: 4980
That's a problem with the tuner, not the tuning tool.
Been there, done that.
nmyeti is offline   Reply With Quote
Old 06-01-2003, 11:18 PM   #20
STEALTH-WRX
Member#: 7822
tuning is everything. period.
what kind of power do you think ill get from this set up? mr_silas Built Motor Discussion 12 03-17-2010 03:06 AM
Have you gone from Utec to Ecutek or vice versa? What do you think? JM530 Engine Management & Tuning 5 05-13-2005 03:32 AM
What do you think I'd get for my WRX? scoobdo Texas Impreza Club Forum -- TXIC 6 03-04-2003 12:45 PM
link ecu or tec 3. what do you think STEALTH-WRX Engine Management & Tuning 17 10-20-2002 10:05 AM
what do you think ill run? NateDogg Normally Aspirated Powertrain 18 09-17-2001 03:59 AM
