Old 05-27-2003, 11:56 PM   #1
houston1
Member#: 36384
Default JDM STI GC8 to US GC8
I have a complete JDM 1996 STI driving GC8 4 doors, do I need other parts to transfer the drivetrain to my 1997 Brighton 2 doors?
thanks
houston1 is offline   Reply With Quote
Old 05-28-2003, 12:12 AM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Time and desire? The more car the better... and, well, it looks like you got the whole car. Is this the red wagon from AZ or a different one?
-Jon
Old 05-28-2003, 01:21 AM   #3
houston1
Member#: 36384
Is it worthy, or just transfer all the parts from my wreck 2000 RS, the car is at FL. What about the one from AZ, how much do they want? the FL one is 8,500 .
Old 05-28-2003, 09:56 AM   #4
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
The one in AZ is an STi wagon. IIRC, it's a V2 or V3.
It's also $8500.
-mykr.
mykrrrr is offline   Reply With Quote
Old 05-29-2003, 12:29 AM   #5
stentorian
Member#: 12959
2008 Scion xB
houston1: So I take it you have the complete JDM car in tack? And you want to put everything off that frame and onto your wrecked RS??? So are you doing the complete drivetrain and body parts or what?? More info on your swap please ?
-Joe
stentorian is offline   Reply With Quote
Old 06-04-2003, 12:32 PM   #6
C-daleRidr
Member#: 18074
2008 Speed3
-Joe
I'm guessing that you're asking if he has the complete care intact rather than 'in tack'?
Sorry if I seem rude, but that's enough to confuse someone.
C-daleRidr is offline   Reply With Quote
Old 06-08-2003, 11:44 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you'll run into problems with the gauge panels
This a problem many people are havin gwhen using a digital gauge cluster with the older mechanical. I'm not sure if the slightly changed 97 will be mech or dig. just a heads up but the 96 should slide into the 97 slot so just get use to km/h. Sounds like an awesome swap
take it easy, Micah
Old 06-09-2003, 04:10 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Micah, and just what is this problem?
-Jon
Old 06-10-2003, 05:11 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
the problem deals with how the info is relayed fromt the tranny to the ecu. the 93-96 97's? is that the mechanical speedo goes from the tranny to the speedo and then sends a signal to the ecu. the 97? 98-01 send a electronic signal to the speedo and one to the ecu bi-passing the speedo.
I read a whole thread on it. if you're mechanical it shouldbe no trouble from what I understand.
I hope this has helped some, Micah
Old 06-10-2003, 06:43 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
As far as I can tell, if you want to use the digital gauge panel then you just need to swap over the electronic speed sensor. If you want to keep your mechanical then you just need to swap your mechanical speed sensor over to the tranny going in.
-Jon
SoCal : JDM STi HID Head Lights, JDM STi Hood Grill for GC8 & Subaru 6 Stars Ornament outcast Exterior/Styling 3 09-19-2007 01:04 PM
contemplating a jdm sti in to gc8 swap. rallyblues Subaru Conversions 8 06-30-2004 04:12 AM
JDM STI Cluster IN US WRX ty_roni Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-02-2004 02:16 PM
JDM BG5 EJ20tt to US BG5 2.5 Conversion - Info Please bg5wagon Subaru Conversions 9 07-23-2003 01:56 PM
Euro GC8 STi gauges in US GC8 SSLegacyGT Subaru Conversions 13 07-12-2003 06:30 PM
