Old 05-28-2003, 02:12 AM   #1
morpheous
Member#: 37122
94 legacy
Default wher can i buy hi flow injectors?
i have an ej22t legacy.
thanks
-Jose
morpheous is offline   Reply With Quote
Old 05-28-2003, 02:53 AM   #2
spacemonkey
Member#: 16435
This should be your ONLY choice if you want it done right.
RC Engineering
hope that helps ya out!
monkey-
spacemonkey is offline   Reply With Quote
Old 05-28-2003, 01:20 PM   #3
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
Rev-lab makes injector adapters for the WRX and STi injectors. This is for the 2.5L, but you could ask them.
http://forums.nasioc.com/forums/show...revlab+adapter
Cajual is offline   Reply With Quote
Old 05-28-2003, 05:36 PM   #4
Z1 Performance
Member#: 9327
RC would be the last place I call actually, unless there are no other options (which there are!)
There are plenty of injectors offered for your car by Denso (the OEM injector manufacturer). What size are you after?
Adam
Z1 Performance is offline   Reply With Quote
Old 05-28-2003, 05:52 PM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
that is if you can ever get ahold of them, i have been for like the past 2 weeks, apparently they are traveling with some rally team, or that is the story so they havent returned my emails for weeks, and apparently they redid the original design of the injector adapters so that now there are fitament issues, i dont understand why they would redo something that works and fits perfectly, but thats just me.
Ben
Old 05-28-2003, 06:34 PM   #6
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
just get some injectors for an ej22T, i think they are 360cc
subiekid is offline   Reply With Quote
Old 05-28-2003, 06:55 PM   #7
kelley
Visiting NASIOC Timeout
Member#: 5681
94 legacy turbo
04 sti
the stock size are 360cc
pe makes some. pretty expensive. I am checking on others.
rc will only rebuild yours and only a 10% increase.
I am getting 850's so there may be others available in a smaller size. the stock ver4 sti are 460's and are side feed.
kelley is offline   Reply With Quote
Old 05-29-2003, 01:11 AM   #8
morpheous
Member#: 37122
94 legacy
Thanks to all for replying. I have the factory ones which are to small at 360cc. im looking for 600 cc or 700cc. 800cc is to big.
i will be using an sds programable efi system.
adam you say denso makes them? how many cc's.
remember these are side feed.
-Jose
Old 05-29-2003, 03:45 PM   #9
subiekid
Member#: 25516
sorry, i did not see that you wanted injectors for an ej22T. that is why i said get the turbo ones because i thought you were using some for a n/a ej22. sorry, i am dyslexic. umm try and pm serious, he found injectors from nissan that are way bigger then the 360 and they fit.
Old 05-29-2003, 04:06 PM   #10
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
morpheous - Ok, you've got a few options, all of which are quite expensive:
(1) STi V5 Side feed injectors (yellow top) 440cc
(2) Blitz Injectors (Any that'll fit a SR20DET, 550, 650 + injectors
(3) Apex-i Injectors (again same specs as above).
(4) Denso OE injectors for Supra (some Supras IIRC were side feed high impedence).
(5) Buy a set of OE 280cc injectors, have RC mod them to double the flow.
I've got the STi V5 injectors that I'll be using with an AIC set-up of 4 OE WRX top feeds in the manifold. So I'll essentially have up to 850-860cc/ cyl of fuel when required.
GTBGUY is offline   Reply With Quote
Old 05-29-2003, 06:50 PM   #11
morpheous
Member#: 37122
94 legacy
GTBGUY
All these options will fit? wow! easier than i thought.
these are direct replacements right? bolt on and go?
Subiekid thanks.
thanks to everyone!
-Jose
Old 05-30-2003, 02:29 PM   #12
Z1 Performance
Member#: 9327
What alla re you guys doing with 800cc worth of fuel on a 4 cylinder car? Going for 600 hp?
Adam
Old 05-30-2003, 04:38 PM   #13
GTBGUY
Member#: 2003
'99 BGP Legacy GT
morpheous - the injectors for the SR20DET motor will require you to use their harness plugs too. Same with the Supra.
If you want to keep w/ the stock ones, I'd suggest having some 280cc EJ25 injectors modified by RC. Other then that, if you want more fuel, fit an additional injector kit or even water injection.
Z1 Performance - how'd you know? soon my black beast will awaken
BTW, drop me an email Adam, looks like the risers won't get done until the end of next month
Old 05-30-2003, 04:42 PM   #14
Z1 Performance
Member#: 9327
hahahaha....I LOVE it! Very cool guys!
end of next month is cool..I can wait till then..going to be driving the Z and GVR4 now anyway, since both are now done I'm a happy camper once again
Old 05-31-2003, 09:14 AM   #15
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Running rich, I'd say.
When I was on a Nissan 240 forum, there was a guy who had two extra injectors plumbed directly into his intake. He was running huge amounts of boost in his SR20DET, and really, really wanted to avoid running lean. I'm pretty sure flames came out his exhaust
-Brian
KD7000 is offline   Reply With Quote
Old 05-31-2003, 03:37 PM   #16
Z1 Performance
Member#: 9327
Additional injectors....man thats retro!
wher can a buy a 1.5 mm head gasket JDM Importers Built Motor Discussion 1 07-19-2006 03:46 PM
Venom Uiversal Hi Flow Fuel Injectors JJD92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-05-2005 03:44 PM
Where can I buy WRX Stock injectors? samwY Private 'Wanted' Classifieds 9 01-15-2005 05:04 AM
Hi-flow stock injectors?? sjl1614 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-16-2004 01:30 PM
Wher can I buy clear corners? CoolWRX Interior & Exterior Modification 3 12-21-2002 12:51 AM
