Old 05-28-2003, 02:55 AM   #1
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Default Turbo XS BOV problems/questions
I just bought a used Type H BOV from a local guy. I installed it in about two minutes and it was working fine. I had nothing to do the other day so I took it apart, cleaned it and re-greased it. It looked like it needed it.
I think I might have put it back together wrong. Every once in a while it doesn't release. It happened twice in 5 miles of stop and go suburban driving. It happens when I'm at about 4000-6000 rpm and let off the gas. I don't hear it release and my engine climbs another 500rpms or so after I let off the gas comletely.
Does anyone have detailed pictures on how to put one together? I didn't get any instructions with it. I used lube for rebuilding suspension forks on mountain bikes. I had some lying around and I figured it worked in the same way. (Two metal cylinders, one sliding inside the other)
Should I have used a different type of grease? WD-40? Astroglide?
I'm going to put my stock bypass valve back on tomorrow and wait until I have detailed insructions on how to put it back together before re-installing it.
Thanks,
Pete
eastcoastbumps is offline   Reply With Quote
Old 05-28-2003, 09:54 AM   #2
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
anyone?
Old 05-28-2003, 10:06 AM   #3
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
I don't have any detailed pics, but it's got to be one of the most easy things to do. hold the 'head' upside down, put in as many washers as you needed for the right amount of release, then put in the spring. Compress the spring in with the main body, and screw in with the two screws.
When you installed it, make sure you put the vaccuum hose back on, that's pretty important. Also, after you let off the gas, the extra 500 RPM or so of rev is normal.
As for it not releasing. Most of the time (for me anyway) in stop and go traffic, I'm not on throttle enough to build much boost. Boost isn't dependant ONLY on revs, so while you may be at 4000-6000 RPM, if your foot wasn't planted, you're not building boost (if you have a boost gauge you can see exactly how much you are or are not building)
gjhsu is offline   Reply With Quote
Old 05-29-2003, 05:13 PM   #4
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
I know that just a little rise in revs is normal. What my car is doing is not. It used to do that once in a while. Now it revs WAY higher when the BOV does not release the pressure. I know that I'm in boost because I'm still accelerating at a good clip when it does this.
Does TurboXS recomend a certain number of washers? Or do you guess and check? What is the 'right amount of release?'
I know I should get a boost guage. Thats next on the list. I've removed it. It will sit on a shelf until I get a boost guage.
Turbo Xs Fmic, Hks Exhaust, Godspeed Fmic, Aem Intake, Two Turbo Xs Bovs, wrxcrver Engine/Power/Exhaust 20 01-28-2009 10:41 AM
turbo xs bov question gotparts? Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-02-2006 08:48 PM
turbo xs bov question..running too rich? wrxdrftr2002 Tri-State Area Forum 5 12-20-2004 06:54 PM
Turbo xs bov question? DUBSPEED Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-09-2004 03:53 AM
Turbo xs bov problem raucky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-16-2004 09:41 PM
