Old 07-21-2009, 12:22 PM   #26
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Originally Posted by [email protected] View Post
Rotors ...
Slotted or drilled ????
slotted rotors maintain approx. 96% of the friction surface
drilled rotors maintain approx. 85-93% of the friction surface
drilled and slotted only maintain 80-91% of the friction surface
For many years most racing rotors were drilled. There were two reasons - the holes gave the "fireband" boundary layer of gasses and particulate matter someplace to go and the edges of the holes gave the pad a better "bite".
Unfortunately the drilled holes also reduced the thermal capacity of the discs and served as very effective "stress raisers" significantly decreasing disc life. Improvements in friction materials have pretty much made the drilled rotor a thing of the past in racing. Most racing rotors currently feature a series of tangential slots or channels that serve the same purpose without the attendant disadvantages.
the process of drilling rotors and slotting rotors was done for 1 reason and 1 reason only it is to disipate the gases that build up between the pad and the rotor which occurs under extreme heat ( when braking very aggressively like on a road course) and it has absolutely nothing to do with heat disipation.
So is there any reason to use drilled rotors on a family car or are they just for looks? The reason I ask is that our MB S500 needs new front brakes. The rotors on it now are drilled but I am thinking of replacing them with "regular" ones.
Mike Wevrick is offline   Reply With Quote
Old 07-21-2009, 03:21 PM   #27
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Drilled are always bling and always a bad idea. Cross drilling can and will lead to premature cracking of the rotor.
Slotted only are even remotely reasonable if the brake pads are having issues with hydroplaning. I've heard this can happen to the STi Brembos but I've never experienced it myself.
In other words, get blanks.
Old 07-21-2009, 03:44 PM   #28
Mike Wevrick
Member#: 24654
1957 Taggart Comet
So how come Mercedes and other high-end companies use drilled rotors?
Old 07-21-2009, 04:00 PM   #29
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Bling.
Uninformed consumers equate cross-drilled rotors with performance.
Old 07-21-2009, 09:43 PM   #30
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Actully, crossdrilled discs offers improved performance over non-crossdrilled discs. They not only help to remove the brake gases produced under hard/extreme braking, but also help to lower disc and pad temps as a result, which helps to keep pads at their optimal operating temps and limit them from fading due to excess heat. There is also the benefits of less rotational mass.
BUT, and it is a big but, the biggest problem is that they tend to crack from irregular expansion from all this hard/extreme braking - so if you use them on the track, you'll need to have the budget to replace them when cracks appear.
Also, some manufacturers do try to limit cracks by reducing the drilled hole count and not drilling too close to the edges, as well as drilling after the discs are heat treated, and although these steps may prolong the life of the crossdrilled discs, eventually cracks can (and still do) form.
Leslie.
wrxsti.l is offline   Reply With Quote
Old 07-21-2009, 10:18 PM   #31
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Originally Posted by wrxsti.l View Post
Actully, crossdrilled discs offers far greater performance then non-crossdrilled discs. They not only help to remove the brake gases produced under hard/extreme braking, but also help to lower disc and pad temps as a result, which helps to keep pads at their optimal operating temps and limit them from fading due to excess heat. There is also the benefits of less rotational mass.
Dude, you're 50 years out of date. Yes, a very long time ago pads had problems with outgassing. However, there's this amazing called science and it does this thing called make progress. Modern pad compounds no longer have problems with excessive outgassing at high temperatures. However, because "high performance cars" used to have cross drilled rotors in the Dark Ages, everyone still thinks they do something useful now. They don't. They are complete and utter fail.
Additionally, reduced mass, in an iron rotor, is a bad thing. Rotors exist for the purpose of storing and then dissipating heat. For a given rotor material (iron, ceramic, carbon, etc), the heavier rotor ALWAYS can store more heat meaning it ALWAYS offers better performance.
Old 07-21-2009, 10:20 PM   #32
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Ow. Rotational mass, okay. A little better bite from the cheese grater effect and maybe a touch better in the wet, okay. The other stuff... ehh.
http://forums.nasioc.com/forums/show...85&postcount=4
It's all there, from smarter people than me. Baer answers the gas thing. Wilwood says they reduce cooling capacity. Stoptech says they don't take abuse and don't work on track.
http://corner-carvers.com/altimathread.php.html
Carbotech engineer arguing the same points.
"far greater performance", definitely not.
Old 07-21-2009, 10:27 PM   #33
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Sorry about wording (fixed it btw), but there are performance gains to be had.
Old 07-21-2009, 10:29 PM   #34
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, there really aren't. Did you even read anything BD linked to or that I wrote?
Old 07-21-2009, 10:57 PM   #35
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
True to a point, but gas is still produced - even if lower then it used to be And removing that gas and heat has its advantages.
I do understand what you are saying, but my post was based on actual results and not just from being blinded by bling on a few exotic street cars with drilled rotors.
Yes, but it is not just about storing heat, it is about dissipating heat. And this can be improved with more surface area exposed to cooler air - hence one of the benefits of drilled rotors. Also, on a track when you are trying to save every bit of weight, compromises are made - hence everyone uses light-weight aftermarket rotors and not heavy rotors - and it is of even more benefit.
Also, just so you know, only about 20% of your brakes cooling comes from conduction (ie, the ability of the rotor to remove heat), however over double the amount is removed from convection - so the more surface area and better the airflow around the brakes, the better the cooling
On a track car, any improvement is better then no improvement
I changed the wording, but regardless, it still imrpoves performance.
Leslie.
Old 07-21-2009, 10:58 PM   #36
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I have read it before (and just went over it again). However no scientific or convincing information was provided, just feedback.
Old 07-21-2009, 11:06 PM   #37
Butt Dyno
Member#: 17301
is the "dark side"
Did you see the part where Stoptech, Wilwood, Baer and AP Racing recommended against them for track use?
Old 07-21-2009, 11:46 PM   #38
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
You have to look at it from their perspective to see why they would suggest general consumers to not use them.
In all probability, the main reason they recommend against them is for longevity - ie. they don't want to suggest customers use crossdrilled rotors on a track and have to deal with an influx of complaints because of cracking and/or warping after a short period and/or incorrect cooling down proceedures.
From a cooling point of view, it is a fact that cross-drilled rotors have greater cooling ability (somewhere in the region of upto 20%) over non-drilled rotors. Go ask any one of those manufacturers and they will have to agree. And from a performance point of view, improved cooling equates to improved braking performance.
What I hope you understand from my posts is that my comments are purely focused on the misunderstanding across the web that crossdrilled rotors offer no improvement to braking performance, when in fact they do.
And that I do understand that even though their are improvements to braking performance, that alone doesn't make them suitable for the weekend track star or low budget race team looking for suitable brake package.
Leslie.
P.S. Regardless of what Baer, Wilwood, stoptech reps may post, their top of the line rotors are still crossdrilled, which says to me they still offer an improvement over non-crossdrilled or slotted only rotors
Old 07-21-2009, 11:50 PM   #39
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Considering that all the major players in the braking industry are contradicting you, the burden of proof is on you (I'll even accept you getting someone from StopTech or Baer to post here). Until then, you're just some crazy guy clinging to outdated ideas.
Seriously, some dude on the internet vs MechE's that design brakes for a living?
Old 07-21-2009, 11:59 PM   #40
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
lol, but you have to admit, crazy ppl are fun
I guess physics doesn't rate high as proof these days
And as I posted above (P.S comment), the top of the line rotors from those manufacturers, who comments you hold dear, are still crossdrilled - and I'm not talking just the "street" rotors, I'm talking race, track, and drag rotors too - where the look or bling means sfa over braking performance. If it wasn't of any benefit, they wouldn't have it. So I guess I'll use that as proof too.
Old 07-22-2009, 07:39 PM   #41
ESmooth
Member#: 118082
There are benefits of drilled rotors but they dont really have anything to do with reduced weight or cooling since those are minimal at best. Drilled rotors will add more bite to a brake system by offering an increased number of leading edges for the pads to bite into. Drilled rotors also offer improved performance in wet weather by allowing an evactuation point for water and steam. A place you may not expect to see drilled rotors is on carbon ceramic systems on vehicles like Porsches and Ferraris. This is again to aid in adding bite to the system since the pads used in those applications need heat to operate properly. Without the drilled surface, the cold performance is pretty dismal.
As far as the "drilled rotors are evil" mantra that gets spewed so often, its mostly caused by the influx of inferior quality parts that are sold online and on ebay for rock bottom prices. These parts are most often crap and should be avoided but high quality parts should not offer any issues, especially on a car that will never see a racetrack.
As a StopTech employee since 2005, I will go on record as saying that on an autocross car where brake temps are never really an issue and getting heat into the system can be difficult, I would purposely run drilled rotors for their added bite. Since the runs arent long enough to cause any kind of temperature issues, I would not have any problems with the parts prematurely cracking.
On a street car that might see some canyon runs or performance use, maybe 1 or 2 light track days a year, I would go with what I preferred the look of most as that will have the biggest impact. In most cases, the driver would not be able to notice any difference in feel between blanks, slotted, drilled or drilled/slotted rotors becuase the tires dont offer enough grip and the pads dont have high enough levels of friction.
On a track driven car, I would only run slotted rotors. They add bite to the system and keep the pad suraface from glazing with no discernable difference in crack related failures. To those who claim that blank rotors are the only way to go, I disagree as the added performance of the slots are well worth it. There is a reason that all of the top level race teams in World Challenge, GrandAm Cup and LeMans use some sort of a slotted rotor in their brake systems, they really do work. That being said, there are some teams that also have great experience with drilled rotors. For example, TriPoint Mazda who have been champions in World Challenge TC and are always top contenders prefer to run drilled rotors in their Mazda 6 race cars for the added bite. These cars can run a full season on one set of our drilled rotors and not experience any kind of cracking issues..this includes all of their practices and qualifying. The same can be said about the StopTech time attack EVOX which his drilled rotors for the sole purpose of proving they can be run on track successfully without premature cracking issues. Other than a small group of people on this message board, these cars are faster on the track than yours, driven by better drivers than you, and put through more abuse than you have the ability to match. Not all drilled rotors are evil and they do have their merits.
Theres a lot of misinformation for and against drilled rotors, and way too much of the "I saw it on the internet so it must be true" followers in both camps. My recommendation is to go with what you prefer knowing possible risks involved. Be realistic...if you plan on doing a lot of track days, dont get drilled rotors since yes, they are more prone to cracking at extended high temperatures. Are you going to die in a fireball on your way to work in your daily driver because your drilled rotors cracked while getting off the freeway, not very likely unless you ended up with some really low quality garbage.
ESmooth is offline   Reply With Quote
Old 07-22-2009, 07:46 PM   #42
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Kudo's Erik - well wrote
1 - You have too much time on your hands
2 - You forgot the worst part about drilled rotors - getting harassed on NASIOC.
KNS Brakes is online now   Reply With Quote
Old 07-22-2009, 08:05 PM   #43
Butt Dyno
Member#: 17301
is the "dark side"
Aye, thanks Erik. I figured you would get the bat-signal eventually. I was actually going to try drilled rotors when my first set of Stoptech BBK rotors wore out but I needed them *that weekend* and couldn't wait, JSC had the slotted ones in stock. I was hoping to experiment.
I will say that, given the fact that most people do buy the crappy ebay ones (as evidenced by the weekly "hey guys, I found these rotors on ebay, what do you think" posts) I would think the general rule would be to avoid them unless you have a real reason to run them or you buy them from a reputable manufacturer.
And in williaty's defense, hearing about drilled rotors being better because of pad gas does get a little old
john
Old 08-20-2009, 01:59 PM   #44
gling
Member#: 122654
2002 v8 STI w/ GT30R
2013 GTR & M-Sport 335xi
1) The brakes don't stop the vehicle - the tires do. The brakes slow the rotation of the wheels and tires. This means that braking distance measured on a single stop from a highway legal speed or higher is almost totally dependent upon the stopping ability of the tires in use - which, in the case of aftermarket advertising, may or may not be the ones originally fitted to the car by the OE manufacturer.
School me a bit on this matter. Say Identical cars are equipped with different tires - one stickier than the other. Assuming that no slip occurs between the tires of both cars and the road, won't both cars stop in an equal distance?
I understand that brakes are only as good as how much grip your tires get with the road. However, if the car with the less sticky tires was equipped with better brakes, won't it stop in a shorter distance than the other car with stickier tires assuming that the tires don't loose grip?
Thanks.
Gerald.
gling is offline   Reply With Quote
Old 08-20-2009, 02:10 PM   #45
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Thanks.
Gerald.
You're confusing several factors here.
What Luke was saying is that 99% of factory braking systems can deliver more brake torque than 99% of the typical tires people buy can hold. If the tires can't grip the road any harder, then upgrading the brake hardware won't make a damned bit of difference.
However, if you picked up the drum brakes off of a 1940s British roadster and then put R-compound tires on it, yes, upgrading the braking hardware can make a difference because the R-comps would have more grip than the crappy old drum brakes can overcome.
This is why you need to focus on the tires, and on keeping the tires in proper contact with the ground (suspension), rather than on making the braking system develop more braking torque. The point of upgrading brake hardware is to better deal with the heat of repeated stopping, not to make a single stop shorter.
Old 08-20-2009, 02:33 PM   #46
gling
Member#: 122654
Understood. It just wasn't clear to me what Luke meant by tires is the factor that stop vehicles. It just came across as it being the sole factor and that's what confused me. I've seen a lot of people here repeat in verbatim that tires stop a car but when asked for an explanation, they can't come up with it. It just annoys me when a statement is taken for a fact without support. Thanks for the reply regardless; much appreciated
Cheers.
Gerald.
Old 12-24-2009, 02:10 AM   #47
funky monk
Member#: 143094
08 LGT
DBM
Great thread. Answered many of my questions. Now I just have to decide which pads to get! I've been eyeing the Akebono ProACT pads. Anyone with these care to share their opinion?
funky monk is offline   Reply With Quote
Old 12-27-2009, 03:39 PM   #48
blukar
Member#: 220917
06 wrx
blue
hi just need some help i bought some drilled and slotted rotors and just was wondering , should i leave the brake shield on or have them removed?? any help would help.
blukar is offline   Reply With Quote
Old 02-11-2010, 11:23 AM   #49
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
In my quest to find good rotors/break pads I came across this article.. It seems very informative:
http://www.zeckhausen.com/bedding_in_brakes.htm
ericsson is offline   Reply With Quote
Old 03-18-2010, 08:06 PM   #50
schrack
Member#: 241576
2002 WRX Stage2
Sodona Red
Bought my drilled & slotted rotors & ceramic pads from ebay for $180 shipped.
schrack is offline   Reply With Quote
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS MWSOC Vendor Classifieds 10 09-10-2007 10:43 AM
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS Suspension/Brakes/Handling 10 08-13-2007 01:43 PM
Brakes Brakes Brakes cool13b Legacy Forum 2 03-22-2002 05:08 PM
Brake Lines, Brake Lines, Brake Lines: Rate malaki Brakes, Steering & Suspension 0 05-03-2001 06:55 AM
brakes! brakes! brakes! greg Mid West Subaru Owners Club Forum -- MWSOC 16 12-07-2000 08:36 AM
