Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-30-2003, 12:51 PM   #1
sonicblue
Member#: 25227
2012 Escape
Default Removing brake pads/caliper brackets
I'm going to paint my calipers and I want to just remove the whole assembly to make the cleaning easier and avoid masking the car since I'm spraying. I know which bolts to remove to take the caliper bracket off the rotor, but what about details on removing the brake line? Is it just a small nut? I assume the line will need to be plugged (with what?) so fluid doesn't leak out? I know I'll have to bleed after reinstalling, so I'm not concerned about a little fluid loss, I just don't want it getting everywhere.
Do the pads just slide/pop out easily (and back in)? Do I have to do anything special upon reinstalling besides just pushing the piston back in (and opening the reservoir)? Once the pads are out, I'll mask any obvious non-metal/rubber areas (I've gotten the tip to put some grease on those areas to avoid getting paint on them), but can I pretty much paint everything else?
Much thanks in advance......
sonicblue is offline   Reply With Quote
Old 05-31-2003, 01:49 AM   #2
WillysPU
Member#: 25994
2003 WRX wrb stage 4
What would Scooby do?
Yep, the entire assembly can be taken off by removing the two 17 mm bolts located on the back side of the brake assembly. The pads are removed by removing the two 14mm bolts near the center of the brake assembly. Remove the brake line and plug it up. You will see the pads come out and go in very easily.
Make sure to clean the entire assembly with brake cleaner at least two times. The brake cleaner will remove all the brake dust and gease. The two rubber boots can stay in place while you paint, just cover them with tape so you don't get paint on them.
Take your time and make sure everything is clean before you start.
Have fun!
ps I assume you are using caliper or exhaust maniflod paint, other paints including engine paint will burn off.
WillysPU is offline   Reply With Quote
Removal of rear caliper bracket bolts on a 2000 Legacy GT demonicrabbit Brakes, Steering & Suspension 1 07-13-2009 10:59 PM
05 Wrx Rear Brake Discs, Caliper Brackets, Pads, Clips advanracing62 Suspension/Brakes/Handling 3 10-19-2006 04:57 PM
Brake pad caliper housing very hard to swing upward Kansai Subaru Brakes, Steering & Suspension 2 10-18-2006 12:25 PM
WTB: 4-pot fr brakes, 02 caliper brackets kbahus Private 'Wanted' Classifieds 0 03-16-2005 01:09 PM
Stock WRX wheels/tires, front brake pads/calipers, struts/springs akoshy Private 'For Sale' Classifieds 33 12-31-2003 03:41 AM
