Old 05-29-2003, 06:29 AM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default WRX rear sway bar on a GC body
im gonna be using a WRX exhaust for my turbo and i was wondering if i can still use the GC rear swaybar or if i have to change it to the WRX swaybar. if so, which droplinks do i use? thanks!
Brent
scoobyimprza is offline   Reply With Quote
Old 05-29-2003, 06:34 AM   #2
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Brent, you should be able to use your existing GC8 swaybar with no problems.
- Trent
peepshow is offline   Reply With Quote
Old 05-29-2003, 07:02 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
thanks!
Old 05-29-2003, 11:32 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yup a swaybar is a sway bar is a sway bar (except the GDF version)... but you will need to change the latteral links
Old 05-29-2003, 02:22 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
the lateral links because of the exhaust or because they arent made for the sway bar. if its because i dont have a sway bar, i already knew that.
Brent
Old 05-29-2003, 03:22 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Old 05-29-2003, 04:41 PM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
see, i are smart
Old 05-30-2003, 01:05 PM   #8
codemunky
Member#: 1804
Change it to the WRX swaybar. The GC swaybar is only 13mm, I believe.
codemunky is offline   Reply With Quote
04 WRX Rear Sway Bar on an 03 WRX Wagon profall Brakes, Steering & Suspension 6 09-27-2008 12:23 AM
WRX rear sway bar on 95 L? cmiovino Brakes, Steering & Suspension 10 04-02-2007 11:59 PM
'03 WRX Wagon Rear Sway Bar fit '97 GC? GonzoWRX Brakes, Steering & Suspension 2 10-17-2006 02:56 PM
05 WRX Rear Sway Bar on 05 2.5RS shortysman999 Brakes, Steering & Suspension 1 10-28-2005 05:07 AM
Rear sway bar on a sway bar-less car? chip4761 Brakes, Steering & Suspension 0 07-24-2004 12:18 PM
