Old 05-29-2003, 11:00 AM   #1
jeffg
Member#: 2958
2001 WRX (GC8)
Default MIL eliminators - cat efficiency, do they really work?
It looks like I need to buy one of the O2 sensor resistor packs for my car. Can anyone tell me that they bought one and it worked?
Also, does anyone make one that plugs into the stock O2 sensor harness. I dont want to have to chop any more of my ECU harness to install it.
Thanks for the opinions.
J
jeffg is offline   Reply With Quote
Old 05-29-2003, 11:20 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
pony Express no more light for me. the only issue is if you are using it to pass emissions it takes FOREVER for the Catalyst monitor to run.
Jeremy
Old 05-29-2003, 11:23 AM   #3
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Are Pony express plug and pray?
I'd be all about getting one if they were. I didn't have a problem passing emmisions in ma w/ it... I think they only pull your code if your CE light is on.
AO
m750 is offline   Reply With Quote
Old 05-29-2003, 11:29 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
nope, you have to hack up the O2 to get it in
Old 05-29-2003, 01:03 PM   #5
jeffg
Member#: 2958
2001 WRX (GC8)
So there are no plug and play versions?
Are the O2 sensor plugs that hard to get? Could I make my own plug and play by going to a junk yard, or ordering the parts from somewhere?
J
Old 05-29-2003, 01:16 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
nope no plug and plays the connectors are not hard to get the problem is they use some type of anti-corrosive wire that doesn't take to soldering at all so you'd have to replace al the pins/wires. i just hardwired mine with heat shrinked connectors.
jeremy
Old 05-29-2003, 02:42 PM   #7
jeffg
Member#: 2958
2001 WRX (GC8)
so you just cut and crimped and it seemed to work okay?
I think what I might do is still go to a junk hard and just cut off the 2 halves of the connector from a late model subaru. I could then crimpt he MIL eliminator on those wires and plug it into my sotck harness.
Where do I get one of the pony express mil elminators?
Old 05-29-2003, 03:56 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yeah i cut and crimped it with weather pack connectors(heat shrink aroundthe outside)
you get them Here
Old 05-29-2003, 10:35 PM   #9
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Jeremy
I second that motion. Although not on anymore The link handles it all.
EvasionOfTruth is offline   Reply With Quote
Old 06-12-2003, 09:17 PM   #10
paulatwork
Member#: 18407
'02 PSM WRX wagon
NESIC Trackh0z # 456
you don't need to install it at the rear o2 sensor - you can put it next to your ECU.
I don't know about instructions for an RS but I used these for a WRX.
http://webpages.charter.net/baraboo_...x/MIL/fix.html
paulatwork is offline   Reply With Quote
Old 06-12-2003, 09:30 PM   #11
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
ALthough Pony Express recomends installing it 2" from the sensor....
http://www.ponyexpressperformance.com/SMILinstall.html
Old 06-13-2003, 11:02 AM   #12
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Evail Motorsports fix - Worked for 2 months then shorted the O2 sensor, very difficult to install.
Xceleration Mecanical CEL fix - Did not work at all.
Pony Express CEL fix - Been working great. Pre-connected wiring make install much easier, still must solder or crimp connections.
Opie is offline   Reply With Quote
Old 06-14-2003, 11:40 PM   #13
mileliminators
Member#: 10967
Send us some pictures and testimonials!
Thanks for the kind words.
Dan Smith
PEP
mileliminators is offline   Reply With Quote
Old 07-08-2003, 11:48 AM   #14
m750
Member#: 2278
8Sti | 07 allez
White | Comp
any chance you could make a plug and play version? I'd rather not have to solder either my wiring harness, or my o2.
thanks
AO
Old 07-08-2003, 04:02 PM   #15
cvalle-sd
Member#: 420
2001 Cr-V
I have a smog coming up - if I just reset my ECU before the test, will I still fail? I have gone more than a week w/out the CEL light coming on. I have an Evail kit, but haven't put it on yet.
cvalle-sd is offline   Reply With Quote
Old 07-08-2003, 04:47 PM   #16
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I passed MA emmissions, but I think CA is a bit more strict. good luck.
AO
Old 07-08-2003, 07:34 PM   #17
svxr8dr
Member#: 1702
2001 2.5 RS-T
Blueridge Pearl
ponyexpress worked for me and was darn easy to install.
svxr8dr is offline   Reply With Quote
O2 Simulators. Do they really work? allensaldi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-26-2010 03:03 PM
Resonated Exhaust Tips... do they really work? BeBop86 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-18-2009 12:04 AM
De-humidifiers: Do they really work? BigWrecKs Off-Topic 25 09-22-2008 10:33 AM
Penis Pumps: Do they really work? Impreza_RX Off-Topic 19 11-23-2005 11:31 AM
Timex Helix watches, Do they really work? HomerJay Off-Topic 5 01-08-2004 07:49 AM
