Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 05-29-2003, 06:55 PM   #1
Solomon
Member#: 36587
2000 Legacy GT (BE)
Default CUSCO and TEIN
Can anyone give me some insight on what would be better for a race setup for auto-x. I am looking at the TEIN FLEX and the CUSCO Comp L Zero 2 coilovers. The TEIN are around $1300 and the CUSCO are at $2000. I have the coin now to get the TEIN, and have gotten the correct FLEX coilovers part numbers from 2 different vendors, and a yes they will fit. Just 2k seems like a **** load of money to spend on something that reads the same as the TEIN.
Solomon is offline   Reply With Quote
Old 05-30-2003, 01:11 AM   #2
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
I think the Teins would be a good value, IMHO I don't think the Cusco's are worth the extra dime. I know JoeT is running Teins, not sure if they are of the FLEX line, seems to me they were CS or something like that, and I think there are a few others running with the Teins on here as well with happy results. I would check the spring rates and adjustability, and go from there. If they are relatively the same then go with the Tein's.
AKSubie is offline   Reply With Quote
Old 05-30-2003, 01:36 AM   #3
Solomon
Member#: 36587
2000 Legacy GT (BE)
I found out that the JIC are looking good. JoeT has the CS, and I know that I can get the FLEX, or the CUSCO. Someone else pointed out to me that what if I have to rebuild them down the road..CUSCO is out of the game just for that. So if I do have any problems I am thinking that the JIC would be a safer bet. They are more than the FLEX or the CS, around 19k. ugh.
Old 05-30-2003, 08:13 AM   #4
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
If you ever want to re-build the JIC's you'd have to send them out to Japan to get done.
Tein has a distribution facility in California, and they will rebuild and revalve the CS or the Flex to your specifications to suit whatever spring rates you want.
I'm getting my rears revalved for 7 KG springs (compression) and about 30% more rebound. That's why I chose Tein's.
JoeT is offline   Reply With Quote
Old 05-30-2003, 02:28 PM   #5
Z1 Performance
Member#: 9327
Not true on the JIC's..they have a distribution office in the USA as well, and will do custom valving, etc as well. There is also a huge step up in performance between the JIC amd the Tein's offered for your Legacy.
Solomon - check my reply in the suspension forum
Adam
Z1 Performance is offline   Reply With Quote
Old 05-30-2003, 03:14 PM   #6
Solomon
Member#: 36587
2000 Legacy GT (BE)
some what of a dumb questions but how does the weight thing work with the coilovers ie."7 KG springs (compression) and about 30% more rebound" on the rear or the front?
Old 05-30-2003, 11:54 PM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Well 7kg is short for 7kg/mm of compression rate and implies a linear spring. If you multiply the kg/mm rate times 56 thats pretty close to the lbs/in rating we use in the US. So 7kg/mm = 392 lbs/in.
I will let someone more qualified discuss the rebound settings.
ss
subysouth is offline   Reply With Quote
cusco and tein edfc controllers debadgedtr North West Impreza Club Forum -- NWIC 11 03-21-2009 11:53 PM
LeeC's STi: Now with more Advan, Cusco and Tein =) LeeC Member's Car Gallery 156 09-22-2008 01:41 AM
Ultimate Coilovers Sale!!! Ohilins, Cusco, and Tein!!!!! RallySport Direct Suspension/Brakes/Handling 8 11-06-2006 07:27 PM
JDM GC8 STi, CUSCO, and TEIN take offs: gr8wheels Suspension/Brakes/Handling 36 08-17-2004 09:43 PM
WA FS: Cusco and Tein Suspension goodies (WRX) HiFiWRX Private 'For Sale' Classifieds 23 03-09-2004 02:59 AM
