Old 05-29-2003, 07:29 PM   #1
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
Default lightweight crank pulley or lw flywheel?
looking to do one of these mods soon. which one should it be or is it alright to do both?
imprezey is offline   Reply With Quote
Old 05-29-2003, 08:57 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Think about it this way, the flywheel needs quite a bit of work. Might as well do other things at the same time. Lightened pulley is fairly simple, remove rad fans, remove drive belts, remove pulley.
Old 05-29-2003, 09:53 PM   #3
linsavy
Member#: 11620
1997 GF4-STiV3 clone
True the pulley is simple to install. The flywheel will yield better results due to the greater weight savings and about 4x the cost.
Also the lack of a weighted crank pulley to absorp harmonics can cause earlier valve float and undesirable valve control. Subies suffer less from this but it is still there. Noone has had their engine blow up so it is likely ok.
I have a light pulley which I put in recently. It is very noticeable in how quickly the engine revs when you blip the throttle.
If I go with a light flywheel, I will remove the pulley to make street launches friendly and save stress on the crank.
linsavy is offline   Reply With Quote
Old 05-30-2003, 12:21 AM   #4
imprezey
Member#: 17178
2001 2.5RS Coupe
alright. so i think the general consensus is a lw flywheel. i know its more work but i'll be putting in a new clutch soon as well so i can do it at the same time.
Old 05-30-2003, 12:34 AM   #5
Boxologist
Member#: 21118
had a lightened pulley put on over the weekend. very nice addition. pulls faster after 2.5k to redline. a flywhel is a lot of wok, and i have heard people regret having it put on because it ruins highway cruising.
Boxologist is offline   Reply With Quote
Old 05-30-2003, 12:39 AM   #6
imprezey
Member#: 17178
2001 2.5RS Coupe
how does it ruin highway driving? i heard that it makes stop and go driving a bit more difficult. i dont mind the extra work to put it in because i have to do the clutch too but i wouldnt mind doing pulley(s) either. so which one should i do because i dont think i want to do both.
Old 05-30-2003, 01:54 AM   #7
Folklorez
Member#: 1837
2000 Impreza RS -BRP
-90Accord
i would do the flywheel. if your gonna be working on the clutch might as well change the flywheel.
Folklorez is offline   Reply With Quote
Old 05-30-2003, 02:36 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I would do both. Just not get one of the super-light flywheels and instead get a 13-15lbs one (which is plenty anyhow)
I definatly noticed a difference with my pulley and I wouldnt take it off for anything (exept if I sold the car )
Old 05-30-2003, 02:37 AM   #9
imprezey
Member#: 17178
2001 2.5RS Coupe
yeah but i also dont want to lose driveability. People with lw flywheels, is it really that much harder to drive in stop and go traffic? i assume it isnt but just how much harder is it? also, i could justify spending 120 on a crank pulley but maybe not 400 on a flywheel? well actually i could.. haha but you get the point.
Old 05-30-2003, 03:48 AM   #10
joefocker20
Member#: 13745
2015 STI
I have a lw crank pulley and I'm going to be installing a Exedy Clutch and 13lb flywheel tomorrow. I'll let you know how it goes. Just do both if you can.
joefocker20 is offline   Reply With Quote
Old 05-30-2003, 05:34 PM   #11
imprezey
Member#: 17178
2001 2.5RS Coupe
sweet. let me know how it goes!
Old 06-01-2003, 04:40 AM   #12
joefocker20
Member#: 13745
2015 STI
Well it took me 9 hours to install it. I haven't really gotten on it hard yet, but the flywheel makes a pretty decent difference in acceleration, mainly in the lower gears.
Old 06-01-2003, 10:43 AM   #13
Impreza2000
Member#: 36971
2000 RS
silverthorn
I've had GFB pulleys and aluminum flywheel in for over a year and I love them. Car stutters more in stop and go but not enough to worry about. The flywheel made the biggest difference of all mods(intake, exhaust, etc..)
Impreza2000 is offline   Reply With Quote
Old 06-01-2003, 03:03 PM   #14
imprezey
Member#: 17178
2001 2.5RS Coupe
what do you mean by the car stutters in stop and go driving? is it sorta like hesitation or something else? im thinking i just might go with the flywheel instead of both.
Old 06-01-2003, 03:07 PM   #15
joefocker20
Member#: 13745
2015 STI
By stuttering, I think he means how the revsdrop so quickly when you start off in first if you dont have the revs high enough..
Old 06-01-2003, 11:15 PM   #16
imprezey
Member#: 17178
2001 2.5RS Coupe
i think i understand. how is the combo going for you? are you getting the stuttering as well?
Old 06-02-2003, 04:01 AM   #17
joefocker20
Member#: 13745
2015 STI
Actually I didnt. I broke it in today and decided to do some runs at the "track". I pulled hard on a stock WRX until 70mph, and beat up on countless Hondas, and various other cars. The only thing that sucks is learning to launch the car well.. I'm debating on Cams and Nitrous now, or turboing my car. Its a hard decision, but if I turbo it, it will take ALOT more cash to do it the way I want to.
Lightweight crank pulley + Lightweight Flywheel. OK or Not ? jobxiii Built Motor Discussion 39 05-20-2009 05:25 PM
Light flywheel w/ lightweight crank pulley problems? sabingr North West Impreza Club Forum -- NWIC 7 12-29-2008 08:05 PM
wtb--new or used COBB lightweight crank pulley--BLUE skate enjoi Private 'Wanted' Classifieds 8 08-19-2008 09:51 AM
Lightweight crank pulley and flywheel question GochYou Transmission (AT/MT) & Driveline 5 03-09-2008 07:19 AM
wtb: perrin or cobb lightweight crank pulley 04silv3rSTI Private 'Wanted' Classifieds 0 03-13-2007 11:29 PM
