Old 05-30-2003, 02:12 PM   #1
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Question How much - camber in the rear is too much?
All right, driving style aside, why some one would want lots of - camber aside etc... How much - camber in the rear is too much.
I define too much as "causing 300 tread wear tires to wear excessively or excessively unevenly." My next post will be about the same thing adversly affecting handeling. I know, a can of worms.
That is, a 10,000 mile tire turned into a 8500 mile car is not excessive. To me.
A 10,000 mile tire turned into a 5000 mile tire is excessive. To me.
Yeah I know driving style and what not and this is sort of subjective, but it is good to have some reference from those who know.
Stock is what -1.7 or so. I have read -1.3 but stuck a camber guage on many a WRX and found -1.6, -1.7 to be common with stock springs.
Here is a list of values to select from
  • 1.5
  • 1.75
  • 2.0
  • 2.25
  • 2.5
  • 2.75
  • 3.0
  • 3.25
  • 3.5
  • 3.75
  • 3.5
  • 3.75
  • more than these
ebeck is offline   Reply With Quote
Old 05-30-2003, 02:20 PM   #2
fengshui-fu
Member#: 21847
2002 WRX Sedan
World Rally Blue STX#555
Try -1.0 in the rear. Its what whiteline recommends for sporty driving. Otherwise -0.75 in the rear for daily driving and least tire wear.
chris
fengshui-fu is offline   Reply With Quote
Old 05-30-2003, 03:02 PM   #3
enduroshark
Member#: 24058
How much is too much?
When you are getting uneven wear for your own driving.
Have people really measured -1.6 from the factory?
Cool! I thought my camber gauge needed to be recalibrated!
enduroshark is offline   Reply With Quote
Old 05-30-2003, 03:05 PM   #4
Silver Bullet 02
Member#: 37486
Since rear camber is not adjustable camber plates or bolts are required for any significant camber changes in the rear.
If you have adjustment I think the best setting for maximum tread wear is probably around -1 degree. Best performance for a daily driver is going to be somewhere near that number. Considering how much the WRX naturally understeers you want more negative camber up front than in the rear.
Silver Bullet 02 is offline   Reply With Quote
Old 05-30-2003, 03:19 PM   #5
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
The impetus for this post is the fast that I have Tein coilovers. No tein does not make adjustable camber plates at all. For any model. Since I have the Flex units I can lower the car to road racing levels. Woo Hoo!
Here is how the conversastion goes from there.
Q - Oh, but what about that knarly rear camber?
A - Just replace the rear mounts with adjustable camber plates. Q - Great, does any body know of some that fit the 5 mm wider threaded nut of the Flex units?
A- This should, that should.
Q- Have you ever tried.
A-No but it should. Brand X plates work with brand Y coilovers.
Problem Brand Y also works with stock mounts which Flex does not. As near as I can tell, the Flex units are absurd. Why lower if you can not correct -camber. You can not even buy something else that fits. I have camber bolts and am still at -2. Seems goofy to have double adjustable units that have to be stock height. Oh, forgive me Tein .5 inch lower. Wow!
Old 05-30-2003, 03:26 PM   #6
Silver Bullet 02
Member#: 37486
The Tein RA's come with camber plates up front. I have them and only have -0.7 to -0.8 camber in the rear at the recommended settings. I know everyone expects that it would be more but that's what the computer printout says. I don't know if their mounting plates are made to compensate or what but I'm right where I want to be.
I know this is a long shot but are you sure you have your camber bolts adjusted in the correct direction? Sometimes those eccentrics can be confusing if you aren't concentrating when you adjust them. Probalby not but -2 with camber bolts seems like way too much.
Old 05-30-2003, 03:51 PM   #7
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Helpfull response.
I thought so too and put another post out there. Many responded that that seems correct though. Some say with just Prodrive springs they got -3.2. I do not know about that.
I agree -2 seems extreme. The car is not too low either. That was the most common response. I will have the bolts chacked although the installer asures me they ae in correctly.
Old 05-30-2003, 03:55 PM   #8
Silver Bullet 02
Member#: 37486
SCCA rules allow autocrossers to slot the strut mounting plate holes to alter camber for some classes. You may consider that as a last resort. If the rears are like the fronts you have to move them around a half inch for every degree of camber change. I'm working from memory but I think that is in the ballpark for the fronts.
Old 05-30-2003, 04:25 PM   #9
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Exclamation I autoX twice a month and.....
I run around -1 in the back....so the rear will come around still
Team ARG!
Scoobyslack1 is offline   Reply With Quote
Old 05-31-2003, 09:42 AM   #10
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
right now I'm running -1.5 up front, and -1.5 in the back, even with my whiteline camber bolts we couldn't get any less camber in the rear. I am lowered however via JIC FLT-A2s.
for AutoX, I plan to move the front's on the adjustable plates to get like -3.0 camber, and then move them back afterwards....
ScreaminFast is offline   Reply With Quote
Old 05-31-2003, 01:10 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Lightbulb
Ideally, you'll want to check tire temps for your given driving style to determine the right camber, pressure, and alignment. If you're worried about adverse wear, make sure your toe is at or near 0 since that will effect wear more than camber alone.
The flex units came with mounting plates that should be able to be adapted to their camber adjustable plates. You shouldn't have any problems using camber bolts to adjust your rear camber. If you can't seem to get it right, I'd take to someone who can.
Jay Storm
www.sourcemotorsports.com
How can I add positive camber in the rear? EarlQHan Brakes, Steering & Suspension 5 03-21-2007 02:50 PM
need help...positive camber in the rear [email protected] Brakes, Steering & Suspension 17 11-20-2004 10:12 PM
How much oil in the exhaust is normal? stevenh Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 08-20-2004 08:16 PM
Situation with negative camber in the rear Fish Brakes, Steering & Suspension 13 05-11-2001 09:19 PM
OH man, the embarasment is too much! SCRAPPYDO General Forum Archive 17 02-24-2001 12:55 AM
