Old 05-30-2003, 07:10 PM   #1
Solomon
Member#: 36587
2000 Legacy GT (BE)
Default high torque
What would be the most torque you could get from the EJ25 with a turbo bolt-on while trying to get the best displacement and comression ratio. This could include better internals?
Solomon is offline   Reply With Quote
Old 05-31-2003, 01:23 AM   #2
smacksube
Member#: 4067
01 2.5 rs
this could be a pretty open ended question....
graham hit somethingl ike 230 I think lbs of torque to the wheels with a legacy turbo at 10psi and a link ecu?
then with internals byron at b-spec had somethingl like 550 lbs of torque/
smacksube is offline   Reply With Quote
Old 06-01-2003, 11:32 AM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
a CR of around 8.5:1-9.0:1 will give you enough reliability and low end torque. Fitted with a big turbo, you can get more torque too. Your torque numbers and HP numbers (assuming reading in HP and ft. lbs) will most likely be near to each other as in 500hp, 525 lb ft tq.
Internals is always needed if looking at FI. Especially if going for like say, 300hp at the crank.
FuJi K is online now   Reply With Quote
How To Deal With Really High Torque Bolts williaty Service & Maintenance 22 11-27-2006 11:33 PM
Clunk sound like a tight bolt being broken under high torque?! zaarin Brakes, Steering & Suspension 5 05-24-2006 01:28 PM
Kevlar high torque clutch that will play nice with tranny Quantum-Racing.com Transmission (AT/MT) & Driveline 6 08-07-2002 08:55 AM
Subaru's high torque numbers. FuJi K Normally Aspirated Powertrain 23 05-28-2002 02:14 AM
Tuning hp and torque curve w/ low compression and high compression pistons FuJi K Normally Aspirated with bolt-on Forced Induction Powertrain 22 10-14-2001 07:25 PM
