Old 05-31-2003, 05:43 AM   #1
jbogli
Member#: 26006
2002 Impreza WRX
Default Help, Boost install gone bad
I tried to install my boost gauge last night . Greddy 52mm electro in 3 gauge pod with egt and oil press. I was tapping the clock and i could only get boost or lighting. I am using the clock harness. I have 2 questions. Which wires go to what color wires on the clock? Also i think i have blown something, hopefully fuses. Now if i plug clock back in it won't turn on, interior lights won't turn on, locking throught the key fob doesn't work and the trip odometer reset everytime i turn the car off then back on. Please help me out. I am hoping i just have to replace the fuses. I know there is a clock, security and lighting fuse do you think that is what the problem is?
Thanks
Justin
jbogli is offline   Reply With Quote
Old 05-31-2003, 09:15 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
For fuses, check the fuses in the drivers side kick panel, and in the engine compartment - if ones blown, you'll find it. In the kick panel, check #8 (this is the likely one - the others are upstream) In the engine compartment check fuse #1 and SBF#1
For the wires, the back of the clock is labelled with which wire does what - one is ground, one is illumination (goes to +12V when the lights are on), one is switched power (ACC) and one is constant power.
Connect the illumination lead to the illumination one (labelled illum on clock)
Connect ground to ground (labelled gnd on clock)
Connect main power to the ACC lead (labelled ACC on clock)
Old 05-31-2003, 09:18 AM   #3
jbogli
Member#: 26006
2002 Impreza WRX
Default Holy crap
Holy crap i feel dumb i didn't even think to check there. Thanks alot i will try that when i get home from work. I will check those fuses as well. Thanks so much
Justin
Whiteline instal gone bad, need help! edge Brakes, Steering & Suspension 15 03-24-2006 11:30 PM
Help! HID install gone bad? Gin Electrical & Lighting 9 06-30-2003 12:04 PM
Help, Spring Install Gone Bad EJ205rulezall Brakes, Steering & Suspension 17 11-19-2002 01:14 AM
help! spring install gone bad! AzWRX1 Brakes, Steering & Suspension 11 09-20-2002 12:10 AM
Cam installation gone bad! Blown motor- now what? wistful Normally Aspirated Powertrain 71 08-11-2002 12:27 AM
