Old 05-31-2003, 08:52 PM   #1
98LegacyGT
Member#: 37354
1998 Legacy GT
Default Upgraded Wheels & Tires
I've got a 98 Legacy GT with stock 16"x6.5" wheels and 205/55R16 tires. I want to upgrade to Rota Sub-Zero wheels (17"x7.5" with a 48 offset) and Kumho 711's or 712's (tire size - 225/45R17).
Can anyone offer any comments re: correct offset, whether the tires are too wide (rubbing issues), whether the wheels are too wide (rubbing issues or contact with suspension parts), etc? I would really appreciate any help anyone can offer as I've been getting conflicting info from various wheel/tire retailers.
Lastly, can anyone tell me what the offset is on the stock wheels form my car? I'm having a pretty hard time getting this info (two Subaru dealerships have told me they don't know). Thanks.
98LegacyGT is offline   Reply With Quote
Old 05-31-2003, 10:42 PM   #2
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
Stock offset on the Legacy GT wheels is +55mm.
Going from a 6.5 wide/+55 to a 7.5 wide /+48 will yield the following changes:
- The clearance from stut housing to the inside of the wheel will be 6mm LESS
- The outside edge of the wheel will EXTEND an extra 20mm
Not even considering the 225/45/17 tires, you are probably going to rub. I think the widest most guys go is 7" wheels on the BD.
I noticed you're in Toronto... do you post on the TSC board?
Cajual is offline   Reply With Quote
Old 05-31-2003, 10:44 PM   #3
etam
Member#: 439
www
etam is offline   Reply With Quote
Old 05-31-2003, 10:49 PM   #4
Cajual
Member#: 12900
Old 06-01-2003, 12:25 AM   #5
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
are you lowered? my 215's didnt rub and I am lowered on whitelines.
http://forums.nasioc.com/forums/show...ht=two+tarmacs
biggreen96 is offline   Reply With Quote
Old 06-01-2003, 12:30 AM   #6
98LegacyGT
Member#: 37354
1998 Legacy GT
I haven't got any pics to put on the website . . . but if you guys post the meeting dates I'll keep checking this forum for updates.
Based on your replys, it sounds like I should scrap any plans for the 7.5" wheels and 225 tires . . . any suggestions for 7" wheels with the right offset (I guess 50-53)? I'm trying to keep the total price for 4 wheels around $1000CAN.
Thanks guys . . .
Old 06-01-2003, 02:13 AM   #7
biggreen96
Member#: 12535
vf39 06 5MT XT
my tarmacs were 7.5
Old 06-01-2003, 02:16 AM   #8
iON Performance Inc
Vendor
Member#: 7673
98LegacyGT - if you plan on lowering the car after the 17" wheels, run 215/40/17 w/ the Rotas.
That should prevent rubbing.
Otherwise, you could fit the 225's underneath if you rolled the fender and running ~1.5-2 degrees of neg. camber F&R (depending on the lowering) for the BD
iON Performance Inc is offline   Reply With Quote
Old 06-01-2003, 03:02 AM   #9
98LegacyGT
Member#: 37354
1998 Legacy GT
iON Performance - I'm new in the modification game . . . rolled fenders? Negative camber? I'm getting in over my head . . .
If I run with the stock suspension setup, can I go with the 17"x7.5" wheels coupled with the 225 tires? If not, I'll need to find 7" rims with ET50-53 . . . any suggestions?
Thanks.
Old 06-01-2003, 11:59 AM   #10
eclone
Member#: 31567
I might sell my rims depending on my future plans. You can see them in the webpage under my name or HERE
First page, second row, 1st, 2nd, & last pic. Also last page. They've only been on my car for about 2 months.
Also, if I go the different route, I'll have alot of other goodies for sale too
oh, I'm running 17x7/+48 w/215/40/17 and no rubbing...and my car is DUMPED!
eclone is offline   Reply With Quote
Old 06-01-2003, 03:01 PM   #11
Cajual
Member#: 12900
I'm running 215/40/17 on wheels with +45 offset and I'm lowered with Eibach/v5 and I'm not rubbing. The next Legacy meet will be sometime in June... I'll PM with the date once we settle it or you can check www.TorontoLegacys.com.
Old 06-01-2003, 11:33 PM   #12
biggreen96
Member#: 12535
vf39 06 5MT XT
in other words, you will be fine with stock ride height
Old 06-02-2003, 12:14 AM   #13
98LegacyGT
Member#: 37354
1998 Legacy GT
biggreen96
I have been warned by some of the wheel retailers I have spoken to that on the BD a 7.5" wheel will rub against one of the suspension arms on the rear (apparently it runs perpendicular to the ground and comes fairly close to the stock wheel) . . . was this guy just feeding me a line so that he could sell me 7" (he didn't have any 7.5" wheels that fit Subarus) or is this a legit concern.
Thanks.
Old 06-02-2003, 12:28 AM   #14
biggreen96
Member#: 12535
vf39 06 5MT XT
I would call that a line, the tire comes closer to rubbing the spring than it does that piece. Even when I set my front camber at full negative /--\ it didnt rub the spring. Go for the Subzeros man
BTW I was running 215/45 Sumitomo HTR+'s
Old 06-03-2003, 09:03 AM   #15
98LegacyGT
Member#: 37354
1998 Legacy GT
biggreen96
Thanks for the info . . . I'm going with the Sub-Zeros and 225's. I'm not sure if I will lower the suspension, but if I do, it won't be more than 1/2 inch.
Old 06-03-2003, 10:34 AM   #16
iON Performance Inc
Vendor
Member#: 7673
98LegacyGT - Hopefully you'll be going to a tire store which will allow you to exchange the tires. Unless you roll your fenders in the rear, the 225/45/17's will rub even on stock suspension. (This is when your car has 2 passangers in the rear, or in corners w & w/o passangers)
If you really want 225's, go with 18" and run 225/35/18 and you'll be able to clear the fenders fine on a 7.5" wheel & +48mm offset. (even when lowered)
Old 06-03-2003, 02:09 PM   #17
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Tirerack recently did a very good comparison of tires and the Yokohama AVS ES100 (what I plan to purchase) was better than the Kuhmo Ecsta 712 (what I currently have). Also many list members feel the Yokohama is a better tire. The weight between the two of equal size is within 1/2 pound.
Old 06-03-2003, 05:57 PM   #18
98LegacyGT
Member#: 37354
1998 Legacy GT
iON Performance
If I run 215's, should I run 215/45R17 or 215/40R17 to avoid rubbing? What if I want to lower the suspension? I'm just worried that 40's will change the wheel diameter too much. Thanks.
Old 06-03-2003, 06:39 PM   #19
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
i run 40s and dont rub, but i hate them. every time i hit a bump or anything my car feels as if i hit a bump going 90. i will be running some 16s next and a set of 50s or maybe 17s with 205/45/17 i want to try that. remember side wall is a mix of width and hight. so 225/40/17 will be taller then 205/40/17
subiekid is offline   Reply With Quote
Old 06-03-2003, 07:47 PM   #20
jkyes
Member#: 707
99 Legacy GT
Quick silver
i ran rota taramacs... 17x 7.5
i had H&R springs in. 1 inch lower.
with 225/45/17 kuhmo 712 i DID have rubbing. even with extra camber and rolling the fender.
with stock suspension in, no rubbing even with it loaded down.
tire was just too wide. i wish i could have the lowered susp and the tires, maybe the 215 would do it
jkyes is offline   Reply With Quote
Old 06-03-2003, 09:12 PM   #21
huckedup16
Member#: 20612
2012 Impreza Sedan
I have 225/45/17's on a 7.5 wheel with +48 offset. Rubbing only on extreme conering and passengers in back.
Not lowered.
huckedup16 is offline   Reply With Quote
3 08 Legacy GT Wheels & Tires, 1 08 Outback Wheel & some misc stuff. Micah04WRX NWIC Private Classifieds 5 06-14-2010 08:29 PM
Pa: WTT Stock 16" wheels & Tires + Cash for 17" wheels and tires WRXPCT04 Private 'Wanted' Classifieds 0 04-26-2007 10:48 AM
WTT: My '04 BBS's & tires for your wheels & tires Danny Boy NESIC Private Classifieds 39 10-27-2006 03:04 PM
FS/VT: Wheels, Tires, Wheels & Tires griffinstyle New England Impreza Club Forum -- NESIC 2 11-05-2004 10:51 AM
Upgrading Wheels & Tires MasterYoda Interior & Exterior Modification 1 08-02-2001 03:32 PM
