Old 06-01-2003, 05:53 PM   #1
WRC 3X1
Member#: 340
2006 Charger SRT-8
Inferno Red
Default Side exit duals?
Just wondering if anyone has tried it...
My Uncle has a muffler shop here in Wyoming, so bay time isn't an issue.
I want to route the pipes so they exit right before the rear wheels.
Any suggestions? Tips? Hints? Pics?
There is NO vehicle inspection here in Wyoming, so...
anyways, as always all help and info is appreciated!!
The Wyoming Yeti
WRC 3X1 is offline   Reply With Quote
Old 06-01-2003, 07:20 PM   #2
Brad Pittiful
Member#: 34931
ive never seen one with that done to it...get someone to photoshop it for ya to see how it would look without spending money on it
Brad Pittiful is online now   Reply With Quote
Old 06-01-2003, 07:51 PM   #3
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
I believe it would look pretty cool, there are just a few things:
1. Although the midpipe has a hanger, you are going to have to attach the pipes to the car somewhere near the tips.
2. Where are you going to put the muffler? Unless you get a very flat one, you arent going to have much clearance under the car.
3. Most side exhausts exit in a tip which is molded into a sideskirt or something. I think it would look funny if there was just a tip there (unless it was custom fab'd).
4. You are going to need thin tips...since the car wasnt made for them, there isnt alot of clearance over there.
5. Heat shielding...just so you dont melt the underside of the car as you are going under the passanger compartment.
DDMan is offline   Reply With Quote
Old 06-02-2003, 12:35 AM   #4
TheDonPerignon
Member#: 30299
My opinion-it would look dumb. I say go for the dual exhaust instead
TheDonPerignon is offline   Reply With Quote
Old 06-02-2003, 05:37 AM   #5
liigod
Member#: 30512
01 2.5rs
black
im a huge shelby cobra fan, but even then is till thinkt hat dual exhausts would have been nicer comming out of the butt rather than the sides. Maybe its personafying/anthropormorphizing a car, i know i cant spell , but is till think dual exhausts look much better that dual side exhausts.
liigod is offline   Reply With Quote
Old 06-02-2003, 09:09 AM   #6
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
a set of true dual pipes would harmn your low end. since the firing order is 2 on one side of the engine then 2 on the other, the first pulse on each side would have no scavenging effect.
-IggDawg
IggDawg is offline   Reply With Quote
Old 06-02-2003, 11:21 AM   #7
NotAnRS
Member#: 1004
2002 Forester L
Scratch-n-Dent Blue
Thumbs down
Not to mention it will sound like total crap with the pulses exiting on different sides.
Don't do it; you'll be sorry you did.
NotAnRS is offline   Reply With Quote
Old 06-02-2003, 11:37 AM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Its been done on a Ver3 or 4 STi in England. The problems they faced were muffler location (fight fit in the driveshaft tunnel for a muffler) and even with the glasspack like muffler they went with the owner said it was still VERY loud (mind you, this is with a turbo quieting things down too). You'll have to mod the side skirts to fit and fab some heat shielding for the fuel tank... other than that go for it.
Old 06-02-2003, 11:51 AM   #9
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
as long as it went into a single pipe and then back to 2 pipes downstream, it should be alright. just remember how NA cars need to be tuned.
-IggDawg
Side exit exhausts limeylight Normally Aspirated Powertrain 6 04-25-2005 01:22 AM
side exit exhaust (not sidepipes) t3hWIT Normally Aspirated Powertrain 14 11-16-2004 10:33 AM
Side exit exhaust Stainlessmag Normally Aspirated Powertrain 26 02-03-2004 10:21 AM
side exit exhaust pipe aspera Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-08-2002 01:10 AM
Side exit exhaust pipes? ImprezedRS Normally Aspirated Powertrain 14 12-17-2001 03:54 AM
