Old 06-02-2003, 01:04 AM   #1
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Default RS-T question
Im thinking about buying a stock WRX turbo and installing it on my RS. The one question I have is will i need a new ECU?
JewPac42 is offline   Reply With Quote
Old 06-02-2003, 01:49 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
it all depends on how much boost you are planning to run, but if you want to do it the right way, i would get a new ecu.
Ben
Old 06-02-2003, 09:41 PM   #3
JewPac42
Member#: 23260
Patr ick Willis
I dont think i could run much more then 6-7 without endangering my engine. Would a link suffice?
Old 06-02-2003, 09:44 PM   #4
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
I'll let ya know in a week,
My car is running good with just a voltage clamp and a RRFPR,but I decided to go Link+ and 440's to get it better
Old 06-02-2003, 10:15 PM   #5
OKRS25
Member#: 36533
2005 STi
I am doing the same thing and running and am going to run an e-manage, I know of at least one other who is doing this and am sure there are more... Should provide enough management to hit some high boost levels. I think our goal has gone from 8 psi to 12 to 15 psi and I think it is attainable...
OKRS25 is offline   Reply With Quote
Old 06-02-2003, 11:31 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
jewpac- a link plus will do just fine,its actually the norm for most RS-T's, plus there are a lot of guys here that have them and are basically experts so they can help you tune.
Ben
Old 06-03-2003, 01:10 AM   #7
JewPac42
Member#: 23260
Patr ick Willis
Excellent, thanks for the help guys. Now I just gotta find someone to put it in and help me tune.
Old 06-03-2003, 03:11 AM   #8
PHATsuby
Member#: 13617
2001 Legacy GT back
you can get a plug and play harness so all you do is literally unplug the 3 factory harness plugs and plug in the 3 harnesses on the Link Plus, makes install much easier, and depending on what you are gonna run and what your set up is i bet one of the guys on here has a map that you could use that would start you off great as a base map, maybe even the same setup so that you dont have to tune much to get optimum performance, plus you dont have to deal with figuring out how to get your idle for the most part it would just be tweaking their map a little.
Ben
anyone have an rs w/upgraded cams i can get a ride in sometime? and rs-t question... legacy2003 New England Impreza Club Forum -- NESIC 0 04-26-2005 02:54 PM
EJ22T swap into RS, tranny question? ImprezedRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-05-2002 09:16 AM
Looking to buy a used Impreza RS - have questions VIPR1AB General Forum Archive 6 01-12-2001 10:56 AM
Want to buy Cobb Tuning Edition RS, have questions... Subecowboy General Forum Archive 26 12-21-2000 10:45 PM
Minnam 2.5 RS Turbo Question! VA_ACCORD Technical Forum Archive 9 08-05-2000 01:39 AM
