Old 06-02-2003, 04:19 PM   #1
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Default what swaybar with what x-member?
If i use a legacy turbo crossmember for a swap, can i use my stock gc8 front swaybar. If not what bar do i need.
If i use a wrx crossmember, should i get a wagon front swaybar or a wrx sedan front swaybar.
Soon2Bgreat is offline   Reply With Quote
Old 06-02-2003, 06:48 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Your current sway bar will fit; I've had it up on there so it will physically go back. However, I have not driven with it. I have heard from quite a few people that the sway bar will be quite noisy. I don't exactly know where the conflict would be. It looks like I-speed uses the USDM WRX swaybar when they do their conversions. I don't think the sway bars are different in anything but, perhaps, thickness between the sedan and wagon.
-Jon
Old 06-02-2003, 07:11 PM   #3
SCOOBER
Member#: 223
1999 Impreza 2.5RS-T
The stock front bar WILL NOT fit with a Legacy Turbo crossmember. It hits the spot where the dent for the uppipe is...trust me, it created alot of frustration during our little install project and we had to use the one from my friends '94 JDM pile. The JDM bar is straight....just like the Whiteline WRX bars...and clears perfectly. The U.S. front bar will fit if you put it on upside down...but it hangs down really low and I have doubts as to the effectiveness of it in this position (read as : don't drive it like this!)
Anyway....I also noticed in one of the listings for Whiteline bars that they use the same model front bar for the RS and the Legacy Turbo...so it is probably the straight one.
Here is the Whiteline application guide link...
http://www.whiteline.com.au/docs/cat...WSB06e_app.pdf
I looked at this chart again...the Turbo Legacy bar is actually a different number than the WRX bar....and the RS bar. You need one with a straight center section is really the goal I guess. I have not seen a USDM WRX front bar, so I am not sure what is different, but I can tell you the one from a '94 JDM WRX will work with your Legacy Turbo crossmember...no squeeks, etc!!
Hope this helps!
SCOOBER is offline   Reply With Quote
Old 06-02-2003, 08:12 PM   #4
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
All right i'll probably just get a wrx front swaybar and crossmember. Anyone have one for sale?
Actually is there a 19mm front bar that will work with usdm wrx crossmember?
Old 06-02-2003, 08:28 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Old 06-02-2003, 08:56 PM   #6
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
hehe, and i thought he was just selling junk. thanks for the link, but i thought wrx front swaybars were 20mm and RS's gc8's were 19mm, not that it matters, but just wondering. Thanks again for the help.
Old 06-02-2003, 11:06 PM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
can i use a wrx front swaybar with a turbo legacy x-member?
Brent
scoobyimprza is offline   Reply With Quote
Old 06-04-2003, 07:36 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Sure? If I-SpeedUSA does, indeed, use the front WRX sway bar for their conversions then it should also fit with the Legacy crossmember.
-Jon
Old 06-05-2003, 01:23 PM   #9
SCOOBER
Member#: 223
On the Whiteline chart they list the '94 in with the new car for the same application, therefore I would think they would fit. I am going to have to order an aftermarket bar to go on mine as my current one is going back to it's rightful owner at some point (thanks Puck!)
The other option is to order an aftermarket bar for the Legacy Turbo....you know that will definately fit!
Old 06-05-2003, 03:37 PM   #10
nizz
Member#: 188
2004 Forester XT
24k gold on white
I was told that I should use a wagon sway bar with a WRX crossmember but I got a Cusco sway bar labeled for a GDA (sedan) and it works fine. I am still not sure what the difference between a sedan and wagon sway bar is. If it is the length, it must be a very small difference. With the sedan sway bar, the endlinks seem to rest at more of an angle now.
nizz
nizz is offline   Reply With Quote
Old 06-06-2003, 11:34 AM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i am using a wrx front with a leagacy turbo crossmember it lined up ok..the end links are at a more extream angle than i would like .. i plan on replacing the end links with whitelines
Old 06-06-2003, 03:56 PM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
So the moment arm on the swaybar is slightly longer for the USDM WRX? Does that meant he swaybar itself is slightly more resistant to the torsional forces due to the larger amount of torque available by that longer arm? Sorry for the technical crap, I'm just thinking outloud.
-Jon
Old 06-06-2003, 05:31 PM   #13
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
UM............yes it will........
I am using the stock front bar from my '96 Impreza and I have a whole '93 Legacy turbo motor swap (motor, crossmember, headers, uppipe & downpipe)
it would squeek a little when it was wet, but would stop after driving a bit.
Scoobyslack1 is offline   Reply With Quote
Old 06-06-2003, 06:24 PM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
That's the exact response I have heard from a number of people. But I haven't actually driven my car with it in that configuration.
-Jon
Old 06-07-2003, 02:50 AM   #15
suberboy
Member#: 1531
2008 GRB
Red
The stock bar from my 1.8L fit when the car was on the lift but would hit the x member when the car was set down. I ended up ordering a cusco bar for a GC8 (japanese WRX from '93-'00 I recently learned that the US cars are technically GC6s) and it works perfectly. I also understand that the US WRX wagon uses the same bar but don't know if that is true.
I would think using the stock bar from our non-turbo cars would be fine if they didn't rub or hit the x member but if it is rubbing/hitting you are affecting the way your car handles in what is most likely an adverse way. If you want the proper bar you can get it through Cobb or anyone who carries Cusco or Whiteline.
suberboy is offline   Reply With Quote
Old 06-07-2003, 09:40 AM   #16
Scoobyslack1
Member#: 2780
junk yards rule!
Wink
-Jon
well, if I drive out to UT this fall you can see mine
(if your project isn't done yet)
Old 06-07-2003, 11:57 AM   #17
suberboy
Member#: 1531
2008 GRB
Red
scoobyslack i sure hope you drive out so we can all cruise to sema in our conversions and maybe even get an autox in
Old 06-07-2003, 06:09 PM   #18
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
intersting idea cept there is no way i am gonn drive the conversion though souther utah .. no A/C
Old 06-07-2003, 06:24 PM   #19
suberboy
Member#: 1531
2008 GRB
Red
what's a little sweat i'll be running no AC too.
Old 06-09-2003, 09:33 AM   #20
Scoobyslack1
Member#: 2780
junk yards rule!
Exclamation
come on.......it's late October, it won't be that bad
(now that I've said that there will be a heat wave)
Team ARG!
Baja Turbos: What works with What? honda killer Baja Forum 242 04-15-2016 03:08 AM
Bilstein Pss9 with what swaybars. huynhk Brakes, Steering & Suspension 3 04-13-2010 04:34 PM
What size swaybars with Megan Tracks? aspen_rex Brakes, Steering & Suspension 2 07-31-2007 10:28 AM
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 10:21 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
