Old 06-02-2003, 07:57 PM   #1
quietgiroth
Member#: 19375
Default cruise control (not working)
Hello,
My cruise control isn't working. The light goes on when I press the button, but the cruise control doesn't engage when I activate it. This is on a 97 2.2L Sedan Impreza.
My CEL light isn't on. The only things that I can think of that has been done to my car since it worked was:
1. An oil change at a Subaru dealership.
2. I accidently plugged my rear brake (3rd brake light) light into the connector in the trunk that isn't connected to anything.
I've checked my brake lights and they all work.
The cruise contol fuse is fine.
I'm stuck, any advice? Things to check/look at. Also if anyone has a diagram of how to install the cruise control so that I could check to see if a wire has come loose that would be great.
quietgiroth is offline   Reply With Quote
Old 06-02-2003, 09:57 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default something to check
Check the vacuum lines going to the CC unit. Perhaps one of them worked its way loose or developed a hole/leak in it.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 06-03-2003, 12:02 PM   #3
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Cruise control won't work if you have a brake light out. Yousaid that your brake lights work, but also that your 3rd brake light wasn't working, right? Or did you fix that, and all three brake lights are working?
HondaH8er is offline   Reply With Quote
Old 06-03-2003, 07:34 PM   #4
quietgiroth
Member#: 19375
Cheers,
All three brake lights are working. I'm down to looking at the sensors. I've followed all the wires, and they look in good shape.
Old 06-05-2003, 12:29 PM   #5
AWDrivin
Member#: 1687
99 2.5RS
Default Re: something to check
LaterZ!
Darren!!
I'll second this. Follow the vac line going from/to the CC. Mine was pulled off while messing with my intake once and the indicators were A) rough idle and B) CC light comes on but doesn't actually work.
- Chuck
AWDrivin is offline   Reply With Quote
Old 06-05-2003, 08:59 PM   #6
NC2.5RS
Member#: 19313
2007 Scion tC
Black Sand Pearl
LaterZ!
Darren!!
When I found out that my cruise control wasnt working, thats what I checked, and sure enough, one was off.
NC2.5RS is offline   Reply With Quote
Old 06-05-2003, 09:51 PM   #7
Roy
Member#: 32241
1998 Impreza L Coupe
white
Also check the switches on your clutch and brake pedals. If they are not tight and adjusted properly the cruise will not work.
Roy
Roy is offline   Reply With Quote
Old 06-10-2003, 01:01 AM   #8
Penphoe
Member#: 269
Default Re: cruise control (not working)
hehehe. That empty plug is probably the trunk light plug!
Fix your CC yet?
LaterZ!
Darren!!
Cruise control not working? whatawgn Texas Impreza Club Forum -- TXIC 11 11-16-2006 02:29 PM
Cruise control not working? whatawgn Texas Impreza Club Forum -- TXIC 6 11-16-2006 09:18 AM
Cruise Control not working (light comes on fine tho) neko Electrical & Lighting 5 09-17-2006 12:35 AM
'02 WRX Cruise Control NOT WORKING 02RallyWRX Service & Maintenance 8 06-26-2006 11:28 AM
