Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 06-04-2003, 05:12 AM   #1
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
Default Rough idle at 8000 miles on WRX could it be the fuel injectors?
02 WRX sedan with 8000 miles. Bought my car wrecked. I think that maybe from the time it was crashed, went to auction, I got it and replaced bent valves and frame that maybe a year went by where it didn't run. I'm concerned about the idle. Seems a little shaky to me. No CEL engine runs strong just don't like the idle.Thinking about cleaning the fuel injectors and not with some gas additive. Could this be the solution? Any advice?
Thanks -Scott
cky211 is offline   Reply With Quote
Old 06-04-2003, 10:59 PM   #2
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Mine is the same way except for not being wrecked. This is my 4th subie and they all idled a little rough.
Mike Wevrick is offline   Reply With Quote
Old 06-05-2003, 02:25 AM   #3
tdxflex
Member#: 13634
you buy it stock w/o any mods? it might have sti engine and tranny mounts, my idle got a bit rougher after putting those on. try resetting your ECU and see if that changes anything.
tdxflex is offline   Reply With Quote
Old 06-05-2003, 12:16 PM   #4
cky211
Member#: 31129
02 WRX MPB
No It was pure stock when I got it.
-Scott
Old 06-05-2003, 11:09 PM   #5
Mike Wevrick
Member#: 24654
1957 Taggart Comet
There's no harm in trying some fuel system cleaner.
Old 06-06-2003, 12:37 PM   #6
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
Default welcome to subaru
most likely there is nothing wrong with it mine does the same thing....AND I LIKE IT....but that is just the way it feels from the pistons going side to side on the flat 4 boxer motors.
AutoSpeedWRX is offline   Reply With Quote
Old 06-06-2003, 01:04 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's normal for the idle not to be perfectly smooth. Does it shake or miss occasionally, or is there a regular miss or lumpiness?
Might be worth pulling the plugs to see what they look like, also check fuel pressure and maybe change the fuel filter since it's easy to do and the car has been sitting around.
Also are you positive the valve timing is correct? It is possible for one or more cams to be off a bit and not set any codes.
Old 06-06-2003, 02:23 PM   #8
cky211
Member#: 31129
02 WRX MPB
It is a steady slight shake. After reading peoples comments I think it might be normal. Other people that get in the car aren't going to notice it. I notice because I'm always in it and I'm picky about stuff like that.
When you say valve timing are you talking about putting the timing belt on correctly?
Thanks -Scott
Old 06-06-2003, 02:55 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes.
Old 06-06-2003, 10:34 PM   #10
cky211
Member#: 31129
02 WRX MPB
Timing belt was damaged So I put on a new one which had all the marks which made it very easy to install. Also studied service manual very closely.
Thanks
Old 06-28-2003, 06:23 AM   #11
mrazntre
Member#: 30156
2003 WRX Sportwagon
MBP
wut kind of motor oil are you running ?
mrazntre is offline   Reply With Quote
Old 06-28-2003, 01:57 PM   #12
cky211
Member#: 31129
02 WRX MPB
Wow I thought this thread was gone.
I have Valvoline 5-30 synthetic blend and it works great.
I think I was making a big deal out of nothing. Car runs great. Now I'm dealing with grease looking stuff coming out of my transmission. See picture here http://forums.nasioc.com/forums/show...9&goto=newpost
Thanks -Scott
Old 07-01-2003, 02:33 AM   #13
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Yummy, That would be a bad seal there in that pic.
Tim Sanderson is offline   Reply With Quote
Scion to Unveil Micro-Subcompact Concept at New York Show - Could it be the iQ? AVANTI R5 Non-Subaru News & Rumors 23 03-22-2009 12:31 PM
Tuning problem.... Could it be the injectors wrxphantom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-03-2007 10:16 PM
Losing bust at WOT? after removing silencer.. could it be the tune? elsanto Engine Management & Tuning 6 09-09-2005 02:02 PM
Could it be the spark plug wires? SubaruImpreza_power Forester Forum 0 06-03-2003 01:26 PM
Getting a CEL. could it be the ej22T? subiekid Legacy Forum 31 02-07-2003 11:35 AM
