Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 11-20-2000, 09:31 AM   #1
svxxx-26
Member#: 1645
Question idle problem - with A/C on
I flogged this for as much as I could on Yahoo, with little sucess:
Simply put, my SVX developed (overnight) an erratic idle with the Climate Control system "on". Rises and falls continuously. Does not do it when system is on "off" or "econ". Someone suggested the "IAC" was malfunctioning. I have replaced the O2 sensors and the MAF sensor, to no avail. Any ideas, anyone?
svxxx-26 is offline
Old 11-20-2000, 09:36 AM   #2
CRZ_MSL
Member#: 1610
Post
Perhaps your AC compressor is going bad. If the compressor is putting a varying load on your engine, your engine will vary the RPM to counteract it. But then the load on the engine changes again, and the RPM of the engine chases after it.
Sounds to me like either your AC is going bad, or the system that adjusts engine idle under load is going bad.
CRZ_MSL is offline
Old 11-20-2000, 09:47 AM   #3
glenstiles
Member#: 2827
2002 WRX wagon
Silver, baby, silver
Post
I know that this is a long shot, but did you try disconnect/reconnecting the battery to clear the memory?
Glen
glenstiles is offline
Old 11-20-2000, 09:55 AM   #4
svxxx-26
Member#: 1645
Post
Since the A/C system itself seems to be working fine, I'm assuming for the moment that it is the unit that controls the idle speed under load. Problem is, I don't know what it is called and/or where it is located.
As for resetting the ECU, I've tried that many times. I wonder though if I've given it enough of a chance - does it require many cycles to truly reset itself?
Thanks for the responses!
svxxx-26 is offline
Old 11-20-2000, 12:17 PM   #5
XT6Wagon
Member#: 524
04 STi
Post
I would bet that the Idle air control valve is gettign clogged, or burning out. I don't know the specifics on the SVX, but the problem sounds like what happens on other cars when the IAC goes bad.
XT6Wagon is offline
Old 11-20-2000, 12:33 PM   #6
svxxx-26
Member#: 1645
Post
It seems like the IAC valve is the most likely culprit. Anybody have an idea where this thing is located?
Appreciate all the feedback!
svxxx-26 is offline
Old 11-20-2000, 03:48 PM   #7
zensvx
Member#: 1704
1992 SVX LS-L
Post
Don't know how much help this will be but...
"On the Loyale, the IAC valve is located on top of the engine in front of the intake air duct. On the Justy, it is in-line between the air filter housing and the intake manifold. On the Impreza, Legacy and SVX, the IAC valve is incorporated into the throttle body."
If you look toward the passenger side and under the "H-6" plastic cover you should see 4 bundles of wires. I believe it is one of those. This book does not gives pictures for the SVX so I am somewhat guessing here.
This book also gives a 13 step process for testing your IAC (should you find it). Let me know if you need that info.
zensvx is offline
Old 11-21-2000, 07:43 AM   #8
svxxx-26
Member#: 1645
Post
Thanks, I'll look. Someone else suggested that the throttle body might need to be cleaned. If the IAC is incorporated into the throttle body, he may have a good point.
I was hoping it would be something along the lines of the MAF or O2 sensors, meaning something that I could replace myself.
svxxx-26 is offline
HTML code is On
Idle Problem with 2.5L HEKTIC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-15-2006 06:27 PM
idling problem with 2006 wrx mdd1986 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-03-2006 07:27 PM
Idle problems with light crank pulley? Anyone Stiguy247 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-18-2005 11:08 AM
For anyone that has been having idle problems with the link 2. Chav Normally Aspirated with bolt-on Forced Induction Powertrain 11 06-27-2002 02:41 AM
If you have idleing problems with the link 2 look here. Chav Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-24-2002 10:49 PM
