Old 06-04-2003, 10:40 AM   #1
NotFast
Member#: 10119
Default Okay, what does "turning rotors" mean?
It's been bugging me for awhile. Why is it called "turning"? Because they put the rotor on a lathe and "turn" it while removing a thin layer of metal?
Or is this one of those misnomers? 'Cause, in reality, my rotors turn every time I drive my car. Or maybe I'm "spinning" my rotors when I drive?
Thanks.
NotFast is offline   Reply With Quote
Old 06-04-2003, 10:43 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Default Re: Okay, what does "turning rotors" mean?
You answered your own question
Brian
Old 06-04-2003, 12:41 PM   #3
Mean
Member#: 12116
2002 Impreza WRX
Sedona Red Pearl
Something not known very well is that rotors need to be broken in again after turning them. That is, heat them up with some firm 60-5 mph non-ABS braking exercises and then let them cool. It's not just brake pads that need breaking in.
G
Mean is offline   Reply With Quote
Old 06-04-2003, 01:19 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
G
that's a great way to glaze them on the first use.
drive it normally, no excessively hard breaking, but you don't have to drive it like grandma.
Jeremy
Old 06-05-2003, 09:09 AM   #5
Mean
Member#: 12116
2002 Impreza WRX
Sedona Red Pearl
From Stop Tech:
"Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid. Game over.
In terms of stop severity, an ABS active stop would typically be around 0.9 Gs and above, depending on the vehicle. What you want to do is stop at a rate around 0.7 to 0.9 G's. That is a deceleration rate near but below lock up or ABS intervention.
A newly ground disc will require the same sort of bedding in process as a new disc."
G
Old 06-05-2003, 11:30 AM   #6
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Actually, you might be interested to know that when you put something on a metal lathe and reduce its outside diameter, that is also called "turning". This might have something to do with the origin of the term.
ws6fiero is offline   Reply With Quote
Old 06-05-2003, 03:18 PM   #7
CosmoTheCat
Member#: 3409
The instructions that came with the Brembo rotors I just put on my GF's truck said to take it easy, avoid heavy braking for the first 200km.
PS. A slight bump can set my ABS off with ~.2g braking forces. Which might by why the fuse is now in the ashtray.
CosmoTheCat is offline   Reply With Quote
205/55-16's 215/45-17's what does it all mean? Matey Brakes, Steering & Suspension 10 04-06-2001 12:43 AM
what does this noise mean? IMPREZAmike Normally Aspirated Powertrain 6 01-28-2001 12:31 AM
what does ST X mean? v6scoobie Newbies & FAQs 3 11-19-2000 01:19 PM
what does SUS 304 means? antonRS Newbies & FAQs 7 11-02-2000 06:06 PM
What does the rabbit mean? chyisan General Forum Archive 17 08-22-2000 12:01 AM
