Old 06-04-2003, 12:13 PM   #1
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Default Turbo sizing for EJ22T hybrid help
ok, swaps all done and I'm going to be putting a WRX stocker on it for a little while to work out the turbo bugs without pushing the engine to hard. How do I calculate the ideal CFM for the engine? It's a stock EJ22T with stock 2.5 SOHC heads and the SOHC head gaskets. That's roughly a 7.7:1 compression ratio. I'm using a link plus and I'll be getting it professional tuned when it goes in. I'd like to get a balance between top end and as little lag a possible. My budget is about 1K and I can use turbo's designed for the WRX since I'll be using WRX plumbing.
I liked the idea of using the 16G that's popped up lately and converting it to a 18G or 20G down the road after the stroker or build up goes in. What do yall think?
seven881 is offline   Reply With Quote
Old 06-04-2003, 01:24 PM   #2
dyswtric27
Member#: 404
2000 Audi S4
endless.night
a little off topic and maybe this has been discussed before, but are you sure the CR of your motor is 7.7:1, i was thinking that with the ej22t and SOHC heads and gasket it was around the low 9's. I may be totally off.
As for turbo, it might be good to let us know what injectors you plan on running and how much hp you want to get?
Jason
dyswtric27 is offline   Reply With Quote
Old 06-04-2003, 01:44 PM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Compression Ration Link
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
I was under the assumption that injector size was dependant upon the characteristics of the turbo, but if not I'd like to stay around 550 - 650. That should be plenty for the stock motor. I can use WRX style intectors with my setup, so PE's would work.
Jason
Old 06-04-2003, 02:25 PM   #4
dyswtric27
Member#: 404
2000 Audi S4
endless.night
Thanks for that link. Very helpful actually.
This may help in terms of cfm calculations and then you can use a previous post in this forum for what the turbos flow.
CFM calc
Old 06-04-2003, 03:12 PM   #5
seven881
Member#: 8828
01 BRP 2.2T Hybrid
That link you posted was helpful as well. Time to bust out the calculator.
Thanks
Enginuity or OPENECU map for my hybrid? - HELP!! Fongers Commercial ECU Reflashes 4 10-04-2007 02:26 AM
Doing some turbo research for a friend, Help? WrxRick Newbies & FAQs 4 06-18-2007 01:06 PM
Know a list of turbo sizes for all Impreza versions? WRX, STI, Spec C etc. MarylandEcstasy General Community 9 01-01-2007 10:19 AM
Turbo sizing for the new STi (tech) Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-01-2003 03:34 AM
Turbo Sizing for Higher Boost Setups? AaronB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-21-2001 03:42 PM
