Old 06-04-2003, 12:40 PM   #1
Edvig
Member#: 16147
no more turbo
05 Legacy, 11 Outback
Cool Hi Luke: once and for all, lets decide what tires I'm buying. Your thoughts please.
My new P7s need tires. I currently have 2 1/2 good Toyo T1s with about 10k miles on them mounted on my Rota Battles. I busted a sidewall on one of the Toyos running over an unaligned ramp joint and one tires has a pretty bad curb rash on the side wall. Unfortunately the 2 good ones are on opposite diagonals on the car, so mating those together is do-able but not optimal. I can pick up 2 new Toyos at $170 a piece from a local store or I can pick up 4 new tires from Tire Rack and keep the 2 good Toyos as full size spares.
As much as I want to pick up a set of SO3, they are out of the budget range right now. I'm looking for a good sticky summer tire, definitely one that is good in rain. I don't race or autoX.
After many agonizing hours thinking about my tires, here is what I've narrowed down to...all in the 215/45-17 size.
Dunlop SP Sport 9000: $127 @ Tire Rack
Bridgestone Potenza RE750: $136 @ TR
Yokohama AVS ES100: $97 @ TR
Thoughts? Recommendations?
Thanks Luke...you're the best.
Edvig
Edvig is offline   Reply With Quote
Old 06-04-2003, 01:01 PM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
considering your budgetary requirements you should be looking at these tires
AVS ES100 97.00
ECSTA MX 115.00
POZ RE750 136.00
P-ZERO NERO XL 144.00
FH SZ50 EP 145.00
SPORT 9000 127.00
and the vaunted S-03 @ 159.00
since you mentioned the S-03 is out ..... the P-Zero and SZ50 should also be out as well as the RE750
that leaves 3
out of those three for your driving requirements I would recommend the ES100's
While the MX is a better performer the ride quality is bad and the Sport 9k tends to tramline too much for my taste
NASIOC tire search page
Old 06-04-2003, 01:08 PM   #3
Edvig
Member#: 16147
no more turbo
Thanks!
AVS ES100 97.00
POZ RE750 136.00
How do these 2 compare to each other in dry/wet handling and road noise?
Edvig
Old 06-04-2003, 01:34 PM   #4
Tire Rack Moderator
Member#: 1215
ext. 4362
the wet traction and steering response of the 750 is better and the dry handling is also marginally better ,,,, the 750 will also offer a little more tread life ..... ride quality/noise issues are very close between these 2 tires
Old 06-04-2003, 01:41 PM   #5
Edvig
Member#: 16147
no more turbo
Thanks Luke.
Old 06-04-2003, 02:43 PM   #6
slvrwgn
Member#: 32604
2003 Impreza WRX Wgn
fyi - I put some 215/45 17 Yoko AVS ES100s on my Rota Attacks a couple weeks ago, and for the price could not be happier.
They are not much louder than the stockers, but stick 100 times better. They do track the grooves a bit, but that's to be expected of any summer/sticky tire.
I know you asked Luke originally, but I recommend the Yoko's for the price.
Matt-
slvrwgn is offline   Reply With Quote
Old 06-04-2003, 02:50 PM   #7
Edvig
Member#: 16147
no more turbo
Matt-
Thanks...all opinions are welcome.
"Newbie bashing will not be tolerated here" Lets up the stakes once and for all. Davenow Newbies & FAQs 84 07-18-2014 09:49 PM
Upipe Question: What to plug this bung with once and for all BlackoutWRX Newbies & FAQs 9 04-05-2007 08:32 AM
I have FINALLY decided, once and for all, what TV I am going to get. tacomaprime Off-Topic 14 02-24-2007 03:15 PM
when to check your oil. Once and For All... BlackoutWRX Newbies & FAQs 6 06-10-2005 12:19 AM
