Welcome to the North American Subaru Impreza Owners Club Thursday October 23, 2014
Old 06-04-2003, 11:30 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default No hood scoop
would it be safe to run an a/a intercooler without a scoop for a month or two before i upgrade my hood? i'd be using a stock WRX TD04 on 5 psi
Brent
scoobyimprza is offline   Reply With Quote
Old 06-04-2003, 11:51 PM   #2
Shinji N
Member#: 3987
1999 Miata
is it worth risking? Why not wait until you've gotten your hood?
Shinji N is offline   Reply With Quote
Old 06-05-2003, 09:50 AM   #3
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I wonder if it will actually fit without the clearance from the scoop?
You could remove the rubber gasket at the front edge of the hood to increase air flow but that may not help enough.
It seems enough people have enough problems with getting the initial set up right without adding to your potential issues.
linsavy is offline   Reply With Quote
Old 06-05-2003, 12:04 PM   #4
Puckaveli
Member#: 1518
00 2.5RS
Don't bother, your intake temps will be so high you wouldn't be able to run 2lbs of boost.
I sent you a PM about something that might help.
Puckaveli is offline   Reply With Quote
Old 06-05-2003, 01:09 PM   #5
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
need a CF hood? i have one for sale...
HOK is offline   Reply With Quote
Old 06-05-2003, 03:52 PM   #6
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
You could just cut a hole in the flat hood for now, Just make a U shaped cut and bend the metal up to force air in the IC.
Anthony C
Bobalouy is offline   Reply With Quote
Rexy spoilers with no hood scoop??? SubieSG2057 Newbies & FAQs 43 01-18-2010 01:26 PM
07 2.5I hood Painted WRB no hood scoop subaru222 SCIC Private Classifieds 29 08-28-2007 09:22 PM
WTB: OBP HOOD - scoop, no scoop, doesnt matter. SubyPunk Private 'Wanted' Classifieds 16 07-10-2007 11:04 AM
Where can I find a RS Carbon Fiber hood... IE no hood scoop. dj_booduh Interior & Exterior Modification 2 04-29-2006 09:36 AM
white GC6 w/no hood scoop, no wing, Nevada temp plates, CosmoTheCat North West Impreza Club Forum -- NWIC 0 05-20-2004 08:43 PM
