Old 06-05-2003, 04:46 AM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default What is the conversion factor to go from Wheel HP to Crank HP?
makofoto is offline   Reply With Quote
Old 06-05-2003, 08:10 AM   #2
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
there is no fixed conversion, but X 1.3 will be reasonably close. But some dynos give higher losses, meaning lower WHP figures.
Paul
Pavlo is offline   Reply With Quote
Old 06-06-2003, 01:27 AM   #3
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Take wheel hp and add 25% to that number. That's pretty accurate for the WRX.
Jay
Diversion is offline   Reply With Quote
Old 06-06-2003, 01:35 AM   #4
makofoto
Member#: 25243
2006 Legacy Outback
I like 1.3X better ....
Old 06-06-2003, 01:20 PM   #5
Flat420
Member#: 35455
07 LGT Spec.B Stg2
WHP/.74 = FWHP
Example = stock WRX claims 227 FWHP, dynos 167 WHP on average. That's about a 26% drivetrain loss. Dividing the WHP by .74 is the same as multiplying the FWHP to estimate the WHP.
I'm pretty sure this is fairly accurate, but since I'm not a rocket (or automotive) scientist I may be off base a bit...
Flat420 is offline   Reply With Quote
Old 06-06-2003, 05:54 PM   #6
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
Mattr762 is offline   Reply With Quote
Old 06-06-2003, 11:28 PM   #7
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Flat420.. Same as my technique.. 25% to 26% seems most accurate for WRXs.
Jay
Old 06-07-2003, 05:48 PM   #8
Pavlo
Member#: 23015
95-> GC8
It seems that some people aren't clear of what's being said here.
whp/0.76 = flywheel hp
is the same as
whp *1.32 = flywheel hp
The above represents 24% losses, so take 24% from the flywheel figure to get wheel hp, OR add 32% to the wheel hp to get flywheel.
Paul
Old 06-07-2003, 07:57 PM   #9
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
That would mean a stock 2.5 RS is puttin 122.1 hp to the wheels?! Hmm, I didn't think we put down that much...
Ruff is offline   Reply With Quote
Old 06-08-2003, 08:03 AM   #10
Pavlo
Member#: 23015
95-> GC8
Depends how you measure it.
But you could be right, those conversion factors seem to fit with cars that have power levels in the stock WRX to 300whp region.
It's also dependant on road speed, so the losses I mentioned are typically in 4th gear at the power peak, which equates to about 110mph.
THe losses aren't that simple, but the conversion is pretty good when looking at setups within a specific range.
Paul
Old 06-09-2003, 07:04 PM   #11
DoinkMobb
Member#: 3787
2008 Gay
Car
So if an AWD Impreza has about a 25% loss, would it be safe to say my FWD Impreza has about a 12.5% loss?
DoinkMobb is offline   Reply With Quote
Old 06-11-2003, 03:19 AM   #12
Pavlo
Member#: 23015
95-> GC8
DO you only have 2 wheels? Only have half a gearset?
Drive line losses also include a considerable amount of tyre losses. Not to mention bearing drag of free running wheels.
My guess would be higher, but less than 20%. The 4wd system adds a propshaft, rear diff and shafts, not a massive extra.
Paul
Is it worth it to go from a EJ20t to a EJ25t? Cxracer1 Newbies & FAQs 11 03-18-2009 01:58 AM
Whats needed to go from 5x114.3 to 5x100 browniesti04 Brakes, Steering & Suspension 22 01-09-2008 10:55 PM
What is the Ver. 2 lip made from? yankdanger Interior & Exterior Modification 2 08-14-2006 05:41 PM
What is the next video standard going to be after DVD? StuBeck Off-Topic 32 10-09-2004 07:54 PM
What is the STi and XT going to mean for us? imprezive Normally Aspirated with bolt-on Forced Induction Powertrain 7 05-14-2003 10:22 AM
